| | Problem Installing Printer Driver Hi, I had to remove my printer from my laptop and when I tried to reinstall it Windows cannot find the driver. I tried adding it manually and HP does not even show up as a manufacturer. I tried contacting HP and they just said that the driver should be built into Vista and they don't have one they can provide. My printer is an HP Deskjet 5650 and my laptop is running Vista Business 32-bit SP1. Any idea? TIA |
| | Re: Problem Installing Printer Driver Did you read this: http://h10025.www1.hp.com/ewfrf/wc/d...304445&os=2093 -- --------------------------------------------------------------------------------- www.paulsxp.com www.paulsxp.com/forum www.supportspace.com/home/home.s2?aiu=paulm --------------------------------------------------------------------------------- "pgonza02" <pgonza02@xxxxxx> wrote in message news:89EC0BE7-894D-4DA4-83AD-44375C7D6904@xxxxxx Quote: > Hi, > I had to remove my printer from my laptop and when I tried to reinstall it > Windows cannot find the driver. I tried adding it manually and HP does not > even show up as a manufacturer. > I tried contacting HP and they just said that the driver should be built > into Vista and they don't have one they can provide. > My printer is an HP Deskjet 5650 and my laptop is running Vista Business > 32-bit SP1. > > Any idea? > TIA |
| | Re: Problem Installing Printer Driver What are the hardwareIDs of the device? start --> run --> devmgmt.msc --> device properties --> details --> "Hardware IDs" and "Compatible IDs" "pgonza02" <pgonza02@xxxxxx> wrote in message news:89EC0BE7-894D-4DA4-83AD-44375C7D6904@xxxxxx Quote: > Hi, > I had to remove my printer from my laptop and when I tried to reinstall it > Windows cannot find the driver. I tried adding it manually and HP does not > even show up as a manufacturer. > I tried contacting HP and they just said that the driver should be built > into Vista and they don't have one they can provide. > My printer is an HP Deskjet 5650 and my laptop is running Vista Business > 32-bit SP1. > > Any idea? > TIA |
| | Re: Problem Installing Printer Driver I finally fixed the problem. After some thinking, I realized that my desktop had the printer configured fine so I shared it and connected to it from the laptop. This forced the drivers to be copied down to the laptop. After that, I was able to connect the printer directly to the laptop (or through my NAS) and the HP printer drivers were available once again. I should email HP and let them know so they can think a little themselves. Thanks for the ideas from the group. "pgonza02" <pgonza02@xxxxxx> wrote in message news:89EC0BE7-894D-4DA4-83AD-44375C7D6904@xxxxxx Quote: > Hi, > I had to remove my printer from my laptop and when I tried to reinstall it > Windows cannot find the driver. I tried adding it manually and HP does not > even show up as a manufacturer. > I tried contacting HP and they just said that the driver should be built > into Vista and they don't have one they can provide. > My printer is an HP Deskjet 5650 and my laptop is running Vista Business > 32-bit SP1. > > Any idea? > TIA > |
| Installing Windows Generic Printer Driver | Vista General | |||
| Error Installing Printer Driver | Drivers | |||
| Trouble installing printer driver | Vista print fax & scan | |||
| Printer Driver - keeps installing copies of driver | Vista print fax & scan | |||
| Driver hp 3500 printer not installing as should | Drivers | |||
