| | #11 (permalink) |
| Guest | Re: Webcam with error 39... no solution... help!! Just for example, i've just installed the java virtual machine and restore has created a 700MB file in c:\system volume information !!!! this is not acceptable!!! |
| | #12 (permalink) |
| Guest | RE: Webcam with error 39... no solution... help!! Did you try to install the LifeCam software from Microsoft website http://www.microsoft.com/hardware/do.../default.mspx? That should re-install the driver for VX1000. "Jiegen" wrote: Quote: > Hi all i am desperade, this time i am afraid i will have to format my laptop > with Viista 32 genuine. > A week ago i awake my laptop from standby mode, and as usual my mouse > logitech mx 510 worked too slow, so i disconnected it to reconnect, usually > this fixes problem. However, this time i reconnected mouse and it did not > work at all (bottom red LED off) so i rebooted machine and... then mouse was > ok BUT... webcam(s) did work no more!! all with a nice (!) yellow and error > code 39 driver missing or corrupted. I am referring to 3 different devices: a > Microsoft vx1000, a microsoft vx6000 and also the laptop internal webcam. I > have tried EVERYTHING, i have reinstalled all possible drivers, also in > rescue mode, i even disinstalled and reinstalled all usb controllers and > hubs, i have followed the KB articles referring to upper aln lowerfilters, > there is no filter in the webcam class. Even the virtual webcam driver of the > MANYCAM appllication is not working. the only working thing is the webcam for > XBOX 360 that uses a generic vista driver (usbvideo.sys) > Usb is working good, the usb flash drives work correctly. > WHAT CAN I DO?? PLEASE SUGGEST SOMETHING > Thanks all |
| HP Dv6920ea webcam error | Drivers | |||
| Webcam Driver Error | Drivers | |||
| Webcam not connected error | Live Messenger | |||
| WebCam error message | Vista music pictures video | |||
| Error message for WebCam | Vista mail | |||
