| Newbie | Vista 64 Bit Business is giving me the business... Want to fire it but need help!!! Ok Ill start off by giving my specs of what I have then I will go into my problems.... Asus Crosshair Motherboard BIOS 1103 AMD Athalon X2 4600+ @ 2.64GHZ 8 GB Corsair XMS2 DDR2 800MHZ 4-4-4-12 Ram Primary OS HDD Seagate 500GB 7,200RPM,32MB Cache (Primary Partitioned to 100GB OS ONLY, 400GB Programs Only) RAID 5 Array, 5 500GB Seagate 7,200RPM, 16MB Cache - Array is 1.82TB Two: BFG 7900GS 256MB DDR3 Video cards (not running SLI but four monitors) Monitors are Viewsonic 22" LCDs (four) DVD Drive LG Coolmaster CPU Fan, & Stock Fans Case, Thermaltak Armor JR, plus 3.5" drive cooler PROGRAMS: Vista 64-bit OEM Business (legit version) Office 2007 Small Office Adobe Dreamweaver CS3 Adobe Photoshop CS3 Extended Adobe Lightroom 2.0 Adobe Acrobat 8 Sony Vegas Studios Pro Pinacle Ultimate 12 Nikon Capture NX2 Quickbooks 2007 Microsoft Vista Experience lieometer is 5.2 out of 5.9 Microsoft User Access Control TURNED OFF!!! (Antivirus Not installed Yet was before complete system wipe, Kapersky Internet Security) SOOOOO Now that the list is there, My equipment under XP Pro 64-bit RAN Perfect!!, Running Vista 32-bit is fine. (But wont use the 8GB of RAM and WAY to slow when working with RAW NEF format files or compiling AVHCD formats) Now the problem lays with installing any program with Vista 64-bit takes anywhere from 45 min to an hour! Dreamweaver CS3 took just over an hour! Problem one, I can only do one thing at a time IF I TRY to do anything more than one task at a time the computer slows down to a snails pace, cpu utilizations shows one core is at 35% while the other core is 7%. And Always if I try to click on a folder, program or any function it says NOT RESPONDING. Gives me that wonderfull Microsoft message program not responding would you like to close program or wait for it to respond, I click the latter and wait. Sometimes 3-5 min other time 10-15 min. Thats it, I cant do anything without MS throwing a coneption fit on me, and telling me its not responding. Boot up takes anywhere from 7 to 10 min deppending on what it feels like doing and shut down is about the same. XP Pro 64-bit less than two min either way. Soooim confused whats the problem, Ive installed the Nvidia Drivers from the Nvidia downloads for Vista 64-bit, same for the video, no missing device drivers. Everything works just painfully slow. Any help would be GREATLY APPRECIATED!!!! PS I ahve also tried to download all 93 Windows Vista Updates... Still to NO surprise no change |
| Guest | Re: Vista 64 Bit Business is giving me the business... Want to fire it but need help!!! "2L8IWON" <guest@xxxxxx-email.com> wrote in message news:56cc445741c2e9434def97dc9edc75f0@xxxxxx-gateway.com... Quote: > > Ok Ill start off by giving my specs of what I have then I will go into > my problems.... > > Asus Crosshair Motherboard BIOS 1103 > AMD Athalon X2 4600+ @ 2.64GHZ > 8 GB Corsair XMS2 DDR2 800MHZ 4-4-4-12 Ram > Primary OS HDD Seagate 500GB 7,200RPM,32MB Cache > (Primary Partitioned to 100GB OS ONLY, 400GB Programs Only) > RAID 5 Array, 5 500GB Seagate 7,200RPM, 16MB Cache - Array is 1.82TB > Two: BFG 7900GS 256MB DDR3 Video cards (not running SLI but four > monitors) > Monitors are Viewsonic 22" LCDs (four) > DVD Drive LG > Coolmaster CPU Fan, & Stock Fans > Case, Thermaltak Armor JR, plus 3.5" drive cooler > > PROGRAMS: > Vista 64-bit OEM Business (legit version) > Office 2007 Small Office > Adobe Dreamweaver CS3 > Adobe Photoshop CS3 Extended > Adobe Lightroom 2.0 > Adobe Acrobat 8 > Sony Vegas Studios Pro > Pinacle Ultimate 12 > Nikon Capture NX2 > Quickbooks 2007 > > Microsoft Vista Experience lieometer is 5.2 out of 5.9 > Microsoft User Access Control TURNED OFF!!! > > (Antivirus Not installed Yet was before complete system wipe, Kapersky > Internet Security) > > SOOOOO Now that the list is there, My equipment under XP Pro 64-bit RAN > Perfect!!, Running Vista 32-bit is fine. (But wont use the 8GB of RAM > and WAY to slow when working with RAW NEF format files or compiling > AVHCD formats) > > Now the problem lays with installing any program with Vista 64-bit > takes anywhere from 45 min to an hour! Dreamweaver CS3 took just over an > hour! > > Problem one, I can only do one thing at a time IF I TRY to do anything > more than one task at a time the computer slows down to a snails pace, > cpu utilizations shows one core is at 35% while the other core is 7%. > And Always if I try to click on a folder, program or any function it > says NOT RESPONDING. Gives me that wonderfull Microsoft message program > not responding would you like to close program or wait for it to > respond, I click the latter and wait. Sometimes 3-5 min other time 10-15 > min. > > Thats it, I cant do anything without MS throwing a coneption fit on me, > and telling me its not responding. Boot up takes anywhere from 7 to 10 > min deppending on what it feels like doing and shut down is about the > same. XP Pro 64-bit less than two min either way. > > Soooim confused whats the problem, Ive installed the Nvidia Drivers > from the Nvidia downloads for Vista 64-bit, same for the video, no > missing device drivers. > > Everything works just painfully slow. Any help would be GREATLY > APPRECIATED!!!! > > > PS I ahve also tried to download all 93 Windows Vista Updates... Still > to NO surprise no change ![]() > > > -- > 2L8IWON You probably have, but no mentioned... Have you installed the full set of Vista 64 motherboard drivers after installing the OS and before installing other software? |
| Newbie | Re: Vista 64 Bit Business is giving me the business... Want to fire it but need help! Yeah I have installed the Nvidia Drivers originally the newest 64 Bit drivers, now I fianlly got fed up with the computer did a full wipe, re and re Vista 64 I have only installed the Nvida Grapgics drivers this time the ones that were shipped with the two cards, I have yet to installed the Nvida Raid Drivers as I just finished the graphics.. All in all now its working perfectly no windows updates as of this moment, Photoshop CS3 installed in about 15-20 min and loads up in less than 5-8 seconds. Renders a raw nef 90mb file in less than 20seconds. Sooo Now im terrified if I should install the Nvidia Raid controller from Microsoft, or if I should use the current version or the one I originally had at time of purchase. But the computer is super fast as in Xp BUT Shutdown is Painfully slow 20 to 30 seconds vs XP 10 or 15. What is it doing that it takes so bloddy long. Should I tweak anything?? I have tonns of ram and hdd space and they are faily quick drive or is this just Vista 64??? Oddly though my "windows experience" rating is up to 5.2 vs 5.1... More details about my computer ComponentDetailsSubscoreBase scoreProcessorAMD Athlon(tm) 64 X2 Dual Core Processor 4600+5.25.2 Determined by lowest subscoreMemory (RAM)8.00 GB5.9GraphicsNVIDIA GeForce 7900 GS 5.9Gaming graphics2287 MB Total available graphics memory5.8Primary hard disk45GB Free (98GB Total)5.9Windows Vista (TM) Business System ManufacturerSystem manufacturer ModelSystem Product Name Total amount of system memory8.00 GB RAM System type64-bit operating system Number of processor cores2Storage Total size of hard disk(s)2329 GB Disk partition (C 45 GB Free (98 GB Total) Disk partition (D 1431 GB Free (1863 GB Total) Disk partition (I 363 GB Free (368 GB Total) Media drive (J CD/DVD Media drive (K CD/DVDCD/DVDGraphics Display adapter typeNVIDIA GeForce 7900 GS Total available graphics memory2287 MB Dedicated graphics memory256 MB Dedicated system memory0 MB Shared system memory2031 MB Display adapter driver version7.15.11.6375 Primary monitor resolution1680x1050 Secondary monitor resolution1680x1050 Secondary monitor resolution1680x1050 Secondary monitor resolution1680x1050 DirectX versionDirectX 9.0 or betterNetwork Network AdapterNVIDIA nForce Networking Controller Network AdapterNVIDIA nForce Networking Controller Network AdapterMicrosoft Tun Miniport Adapter Network AdapterBluetooth Device (Personal Area Network)You probably have, but no mentioned... Have you installed the full set of Vista 64 motherboard drivers after installing the OS and before installing other software?[/quote] |
| Cannot connect Vista Business to Small Business Server | Vista General | |||
| Upgrade Vista Home Premium to Vista Business using FULL Business C | Vista installation & setup | |||
| IE7 in Vista business is giving problem | Vista security | |||
| [Vista Business] Not recognize 4GB Ram - SonyVaio VGN-SZ57N/C + Vista Business | Vista performance & maintenance | |||
| [Vista Business] Not recognize 4GB Ram - SonyVaio VGN-SZ57N/C + Vista Business | Vista General | |||
