| | Samsung 957p Monitor All, I have a Samsung SyncMaster 957p 19" monitor. Although the monitor is performing just fine, I have a question about what it does after Vista shutdown - the monitor displays the 'No Signal' dialog box that moves around the screen. I consequently turn the monitor off. The monitor did not do this with XP. Is the problem the generic pnp monitor driver, or a setting in Vista somewhere that can fix this? The specific monitor driver is not available in Vista or the Samsung site. Cheers, |
| | Re: Samsung 957p Monitor You had the monitor connected to the "same" computer for these tests? Or, did you have Vista on one computer and XP on another computer - and use the same monitor with each computer? -- Regards, Richard Urban Microsoft MVP Windows Shell/User (For email, remove the obvious from my address) Quote from George Ankner: If you knew as much as you think you know, You would realize that you don't know what you thought you knew! "Roman" <Roman@discussions.microsoft.com> wrote in message news:44E2DD2A-F903-453E-802B-D7754E73B4C8@microsoft.com... > All, > > I have a Samsung SyncMaster 957p 19" monitor. Although the monitor is > performing just fine, I have a question about what it does after Vista > shutdown - the monitor displays the 'No Signal' dialog box that moves > around > the screen. I consequently turn the monitor off. > > The monitor did not do this with XP. Is the problem the generic pnp > monitor > driver, or a setting in Vista somewhere that can fix this? The specific > monitor driver is not available in Vista or the Samsung site. > > Cheers, |
| | Re: Samsung 957p Monitor Hi Richard, Same computer, upgraded from XP to Beta 2 to RC1. The monitor issue arose after installing Beta 2. I didn't comment expecting the issue may be resolved in RC1. Cheers. "Richard Urban" wrote: > You had the monitor connected to the "same" computer for these tests? Or, > did you have Vista on one computer and XP on another computer - and use the > same monitor with each computer? > > -- > Regards, > > Richard Urban > Microsoft MVP Windows Shell/User > (For email, remove the obvious from my address) > > Quote from George Ankner: > If you knew as much as you think you know, > You would realize that you don't know what you thought you knew! > > > > "Roman" <Roman@discussions.microsoft.com> wrote in message > news:44E2DD2A-F903-453E-802B-D7754E73B4C8@microsoft.com... > > All, > > > > I have a Samsung SyncMaster 957p 19" monitor. Although the monitor is > > performing just fine, I have a question about what it does after Vista > > shutdown - the monitor displays the 'No Signal' dialog box that moves > > around > > the screen. I consequently turn the monitor off. > > > > The monitor did not do this with XP. Is the problem the generic pnp > > monitor > > driver, or a setting in Vista somewhere that can fix this? The specific > > monitor driver is not available in Vista or the Samsung site. > > > > Cheers, > > > |
| Samsung T220 Monitor | Drivers | |||
| Samsung DLP via VGA as second monitor? | Graphic cards | |||
| Problem with Samsung 226BW monitor? | Vista hardware & devices | |||
| Help with my Samsung 913t LCD monitor, please ... | Vista hardware & devices | |||
| SamSung monitor drivers | Vista hardware & devices | |||
