Vista Tutorial - Microsoft Laser Mouse 8000 Cradle Problems
Old 08-23-2008   #1 (permalink)
Mark Stonecipher
Guest
I have a Microsoft Laser Mouse 8000 which recharges on a cradle. Actually
have 2 which or having this problem. When placed on cradle for charging it
will blink 7 times and then go to a fast blinking red light. According to
Microsoft's Web site this is a charging problem (battery, etc.). These are
brand new rechargeable batteries and I have tried different ones same
problem. I have tried both cradles, plugged the cord in different places,
and tried everything I can possibly do. Have checked the web, and it seems
other people are having these cradle problems. Any ideas..
PS: Remember these are bluetooth devices and they work just fine, but will
not charge on the cradle, but you can manually charge these batteries...
Old 08-23-2008   #2 (permalink)
JW
Guest
Re: Microsoft Laser Mouse 8000 Cradle Problems
I have found that if I left click the mouse once or twice when it is in the
cradle and flashing Red that it will stop and recharge normally.
"Mark Stonecipher" <markst@xxxxxx> wrote in message
news:%23Twa7iXBJHA.3496@xxxxxx
Old 08-26-2008   #3 (permalink)
_Mark_
Guest
Ill give that try thanks..
"JW" <JW@xxxxxx> wrote in message
news:5692209D-D949-439C-8D89-28E999E6899D@xxxxxx
>>it will blink 7 times and then go to a fast blinking red light. According
>>to Microsoft's Web site this is a charging problem (battery, etc.). These
>>are brand new rechargeable batteries and I have tried different ones same
>>seems other people are having these cradle problems. Any ideas..
>> will not charge on the cradle, but you can manually charge these
>> batteries...
Old 08-26-2008   #4 (permalink)
Mark Stonecipher
Guest
Nope, that doesnt work either..
Old 09-04-2008   #5 (permalink)
Newbie
Windows Vista x64 based system
Quote  Quote: Originally Posted by Mark Stonecipher View Post
Mark,
I found this thread looking for answers for the same problem. The above solution didn't work for me either, so in an atempt to get some charge so I could work I kept picking the mouse up from the cradle each time it started flashing red, on about the 4th or 5th try it never started flashing red. I think the battery supply was so depleted it couldn't get a good start for a charge. I will see if this works later in the day but I must get back to work.
Good luck,
Lisa
Old 09-07-2008   #6 (permalink)
etch
Guest
I actually did the clicking things and it worked. I think the power
switch should be on ON position. Try it and let me know
etch
etch's Profile: http://forums.techarena.in/members/etch.htm
View this thread: http://forums.techarena.in/vista-har...es/1025883.htm
Old 09-18-2008   #7 (permalink)
dfoster
Guest
I have recently had this probelm after my son start playing with my
mouse. I tried replacing the battery but that resulted in the same
problem of the red light flashing after a minute or so.
I checked the drivers on the keyboard the charger and the mouse and
they were not changed. So I decided to re-connect my mouse and keyboard.
This seems to have stopped the problem where the mouse would charge for
a minute or so and then start to blink red.
dfoster
dfoster's Profile: http://forums.techarena.in/members/dfoster.htm
Old 09-18-2008   #8 (permalink)
Curious
Guest
The problem with the red light appears to be due to a unchangeable battery
or to the battery not making a good connection within the mouse itself and
therefore will not charge. One user has reported that just rolling the
battery in the mouse around that it apparently made a better connection and
the red light went away.
"dfoster" <dfoster.3fy6rc@xxxxxx> wrote in message
news:dfoster.3fy6rc@xxxxxx
> dfoster
> View this thread:
Old 09-19-2008   #9 (permalink)
dfoster
Guest
Curious
That was what I thought was the problem with my mouse. So I rotated it
in the battery slot, I tried removing it and rubbing the terminals, I
tried replacing it with a different battery to no avail. In the end I
just re-connected the wireless connection by resetting the wireless
bluetooth connection using the wizard.
The problem has now disappered.
Curious;3982105 Wrote:
> battery
> and
> the
> and
> keyboard.
> for
> > dfoster
dfoster
Old 11-15-2008   #10 (permalink)
warlord
Guest
My problem i faced was with the laser mouse 7000. it has only a single
NiMH AAA. Every time i would go to charge it, after 10-30 seconds it
would start blinking red. I eventually used it to the point of needing a
critical charge and still had this problem. Working with NiMH high cap
batteries in the past gave me a simple idea, do a high amp discharge on
the battery for a short time. (connect a wire to each electrode or use a
resistor) This fixed my problem (I had tried the checking the battery
contacts, etc). I imagine what the problem was is known as a false peak
where the battery when applied current to charge false peaks for a short
period of time before or during the charge. Cheap chargers cannot handle
this and a possible solution can be to (near) fully discharge the
battery to level out its voltage.
**Do not leave it to discharge TOO long, you can reverse the polarity
of the cell**
warlord
warlord's Profile: http://forums.techarena.in/members/warlord.htm
Problem Microsoft Wireless Laser Mouse 8000 - Bluetooth Vista hardware & devices
Re: Microsoft Wireless Laser Mouse 8000 .NET General
Microsoft Wireless Laser Mouse 8000 Vista hardware & devices
Microsoft Wireless Laser 8000 Bluetooth Mouse Vista hardware & devices
