| | Microsoft Wireless Optical Mouse 2.0 Double Clicks when Clicked Once. Upon moving from Windows XP to Vista, a new PC, the Microsoft Mouse has taken up a bad habit of double clicking when it is only clicked once. This is so prevalent that we are hesitant to use it to click on certain items. For example, the delete button in mail. We delete two messages instead of the one we clicked on. For fun try playing solitaire, flipping two cards, instead of one, after a while it really gets annoying. I have tried to adjust the settings and checked with Microsoft and downloaded the latest drivers for this but it has not improved. It may actually be getting worse. Any suggestions? Is it time to get a new mouse? Thank, Richard.. |
| | Re: Microsoft Wireless Optical Mouse 2.0 Double Clicks when Clicked Once. "Richard B" <rbillingsley@xxxxxx> wrote in message news:uATcEKDCJHA.524@xxxxxx Quote: > Upon moving from Windows XP to Vista, a new PC, the Microsoft Mouse has > taken up a bad habit of double clicking when it is only clicked once. This > is so prevalent that we are hesitant to use it to click on certain items. > For example, the delete button in mail. We delete two messages instead of > the one we clicked on. For fun try playing solitaire, flipping two cards, > instead of one, after a while it really gets annoying. > > I have tried to adjust the settings and checked with Microsoft and > downloaded the latest drivers for this but it has not improved. It may > actually be getting worse. > > Any suggestions? > > Is it time to get a new mouse? > > Thank, > > Richard.. Try a different mouse and see if it exhibits the same behavior.. -- Mike Hall - MVP How to construct a good post.. http://dts-l.com/goodpost.htm How to use the Microsoft Product Support Newsgroups.. http://support.microsoft.com/default...help&style=toc Mike's Window - My Blog.. http://msmvps.com/blogs/mikehall/default.aspx |
| | Re: Microsoft Wireless Optical Mouse 2.0 Double Clicks when Clicked Once. > Upon moving from Windows XP to Vista, a new PC, the Microsoft Mouse has Quote: > taken up a bad habit of double clicking when it is only clicked once. microswitch going "noisy". If you're OK with a soldering iron you could swap it with the microswitch under the right-click button - I've done this several times over the past several years. The right mouse button is used far less often, and double clicks on it rarely do any harm. Alternatively, you might just want to buy a new mouse. Logitech mice seem slightly less prone to it, although still not immune. Presumably they have better 'debounce' built in. SteveT |
| XP | Re: Microsoft Wireless Optical Mouse 2.0 Double Clicks when Clicked Once. I had the same frustrating problem develop on my Microsoft mouse with the left-click developing a random double click. I took the mouse apart to look at the solders and cleaned out a little bit of dust that had collected in the mouse around the front near the culprit microswitch. I then put it together and it now works perfectly. There must have been some dust specs causing some sort of short in the device. Anyway, saves me $30+ for the time being. |
| Mouse Double-Clicks instead of single | Drivers | |||
| Microsoft Wireless Optical Mouse 2000 stops responding | Vista hardware & devices | |||
| trouble with Microsoft wireless notebook optical mouse 4000 | Vista hardware & devices | |||
| My mouse double clicks frequently when I single click it | Vista hardware & devices | |||
| Intellipoint Microsoft Wireless Notebook Optical Mouse 4000 | Vista hardware & devices | |||
