Vista does not recognise my monitor but XP does
  1.    18 Sep 2006 #1
    =?Utf-8?B?U3BpcmVmbQ==?= Guest
    I have an NEC LCD monitor. XP recognised it and yesterday automatically
    updated the driver for it. Vista only sees as 'PNP'. I sthere some way I can
    force Vista to use the right drive.
    Colin
  2.    18 Sep 2006 #2
    JW Guest
    Re: Vista does not recognise my monitor but XP does
    Since your dispaly is connected to you grahics card and not to your MOBO it
    is graphics card and drivers that may need to recognize your moniotr if you
    are unable to use custom resolutions. Both NVIDIA and ATI have released new
    RC1 Vista drivers which also may make a difference.
    "Spirefm" <Spirefm@discussions.microsoft.com> wrote in message
    news:6E186105-CFA9-4CCC-A670-20866EAE9728@microsoft.com...
    > can
    > Colin
  3.    18 Sep 2006 #3
    =?Utf-8?B?Q2FybG9z?= Guest
    Nope.
    Monitor driver is supplied by the monitor manufacturer.
    All he needs is the inf file for the proper installation.
    Go to NEC's website and find the driver there.
    I installed my LG 1740B LCD monitor using the Windows XP x64 inf file.
    That is all you need.
    Carlos
    > > can
    > > Colin
  4.    18 Sep 2006 #4
    All settings work fine even though its PNP. IE its just a very minor
    annoyance. I've been to the NEC site and downloaded the driver but Vista
    won't instal it because it doesn't see it as a NEC monitor.
    Colin
  5.    18 Sep 2006 #5
    Use the manual method for installing the driver.
    Go to Device Manager and right click on your monitor.
    Click on Update Driver, Browse my computer..., Let me pick...., Have Disk.
    Now point to your downloaded inf file.
    That should do it.
    Carlos
    > Colin
  6.    18 Sep 2006 #6
    Unfortunately that doesn't do it because Vista is looking for a driver for a
    pnp monitor. If I could change the monitor type somewhere it would work I
    think but there is no provison for that. In theory the file I downloaded from
    NEC is executable, but actually its just a bunch of.inf files.
    Thanks anyway. Its hardly worth anybody's effort!
    Colin
  7.    18 Sep 2006 #7
    =?Utf-8?B?SmV3ZWxzSA==?= Guest
    > Colin
  8.    18 Sep 2006 #8
    Well this forum is good for #%&@. I just typed up a detailed list of how I
    installed my monitor and it is gone.
    I downloaded my monitor driver from Envision and ran as an admin. That
    created an Envision folder on my C drive. From there, I right-clicked the
    desktop, chose personalize, display settings, advanced settings, clicked the
    monitor tab, then properties(at which point you need to give windows
    permission to continue), click driver tab, update driver, then browse. Click
    on the browse button and click on the folder that has the drivers. Once that
    is set in the search bar, click on next and let it do it's things. It should
    come up with your monitor or a list of them to chose.
    > Colin
  9.    18 Sep 2006 #9
    I wish it did, but it doesn't. You actually got a driver apparently. All I
    got was a .inf file.
  10.    19 Sep 2006 #10
    Hi:
    Those inf files are all you need.
    I also had the PNP monitor issue and solved it using the method described in
    my earlier post.
    Follow it exactly and you'll be able to use your monitor.
    Carlos
    > Colin
Page 1 of 2 12 LastLast
Vista won't recognise DVD's
Hello, I'm having trouble with getting vista to play my DVD's. It has only recently started to do this. When I put a DVD in it tries to read...
Vista General
Vista won't recognise external HDD sometimes
I use a USB external HDD for backing up data from my Vista Desktop PC. Sometimes I'll connect it and it will either won't recognise the drive, or...
Vista General
Vista does not recognise USB mouse
I was using Vista Ultimate 32bit with this Dell system with PS/2 mouse. I bought a new USB mouse to replace the broken mouse. But when power up...
Vista hardware & devices
Re: Can't get my system to recognise my monitor correctly
It won't be recognized correctly until you have the correct drivers for your graphics card from the graphics card manufacturer's website. -- Cari...
superfleish wrote: > I upgraded to Vista yesterday, and initially the display on my MAG > Innovision widescreen monitor was unchanged. I then...
Did you download updates from Win update or from the vendor of your video card? "superfleish" <superfleish6@yahoo.com> wrote in message...
Vista does not recognise DVD
I just got a media DVD which Vista Home Pemium OS doesn't recognise ! It sees the DVD drive as empty. I have tried it on another computer having...
Vista music pictures video
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • Old server
    About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
