| Guest | Hardware problems... i don't know if anyone has posted this problems with this devices or not...if they did i'm sorry. I've had problems with 3 things on Vista, first of all was my creative audio PCI that was not able to install, then my Lexmark series X1100 (my model is X1190) that installed but was unable to work and then the most important of all and main reason why i went back to my old windows XP, my Philips SNU5600 (usb wireless adapter) and so i wasn't able to go online on vista making it useless on my pc.is there anyway around this?because first time i installed it on my second hard-drive, i managed to go online just ok but then when i decided to make vista my main operating system (formated my hard drives and installed vista on main) it didn't work anymore. |
| hardware problems or virus | Vista performance & maintenance | |||
| setting up new hardware problems | Vista installation & setup | |||
| hardware installation problems | Vista hardware & devices | |||
| Upgrading hardware - will it cause problems? | Vista General | |||
| Hardware problems | Vista installation & setup | |||
