| Guest | External Hard Drive (USB MassStorage Device missing?) Hi, I am trying to connect my Western Digital external hard drive over USB port and it seems vista cannot find the Usb MassStorage Device Driver ![]() Any thoughts? Even scanning my other partition with XP is not of use (it says file not found). I thought MS would include at least these trivial drivers??? Petar |
| Guest | RE: External Hard Drive (USB MassStorage Device missing?) Its no help but I have exactly the same problem... "Lincoln 6 Echo" wrote: > Hi, > > I am trying to connect my Western Digital external hard drive over USB port > and it seems vista cannot find the Usb MassStorage Device Driver |
| Guest | Re: External Hard Drive (USB MassStorage Device missing?) When vista asks you for the drivers, try specifying C:\Windows (or where you installed vista) with the subfolders option enabled. Marco "DuckRyder" <DuckRyder@discussions.microsoft.com> wrote in message news:A36853AC-A38B-4D60-AFC9-0E1D35A4B3DA@microsoft.com... > Its no help but I have exactly the same problem... > > "Lincoln 6 Echo" wrote: > >> Hi, >> >> I am trying to connect my Western Digital external hard drive over USB >> port >> and it seems vista cannot find the Usb MassStorage Device Driver |
| Guest | Re: External Hard Drive (USB MassStorage Device missing?) Same, here. One of my two Maxtor external drives, which originally worked fine is now listed as "local drive" and can't be accessed. "Marco Dalli" wrote: > When vista asks you for the drivers, try specifying C:\Windows (or where you > installed vista) with the subfolders option enabled. > > Marco > > "DuckRyder" <DuckRyder@discussions.microsoft.com> wrote in message > news:A36853AC-A38B-4D60-AFC9-0E1D35A4B3DA@microsoft.com... > > Its no help but I have exactly the same problem... > > > > "Lincoln 6 Echo" wrote: > > > >> Hi, > >> > >> I am trying to connect my Western Digital external hard drive over USB > >> port > >> and it seems vista cannot find the Usb MassStorage Device Driver > > |
| Guest | Re: External Hard Drive (USB MassStorage Device missing?) Did that already and is says best drivers are already installed!! "Marco Dalli" wrote: > When vista asks you for the drivers, try specifying C:\Windows (or where you > installed vista) with the subfolders option enabled. > > Marco > > "DuckRyder" <DuckRyder@discussions.microsoft.com> wrote in message > news:A36853AC-A38B-4D60-AFC9-0E1D35A4B3DA@microsoft.com... > > Its no help but I have exactly the same problem... > > > > "Lincoln 6 Echo" wrote: > > > >> Hi, > >> > >> I am trying to connect my Western Digital external hard drive over USB > >> port > >> and it seems vista cannot find the Usb MassStorage Device Driver > > |
| | #6 (permalink) |
| Guest | Re: External Hard Drive (USB MassStorage Device missing?) I had a similar problem with my Onetouch Drive - ie the OS saw the device but wouldn't allocate a drive letter. I eventually found it was because I had a password security option set on drive - so had to install maxtor secuirty prog on a system with XP, attached the maxtor drive and turned off security. Vista then saw the drive normally - I haven't had the nerve to switch the password option back on! "BAldie" wrote: > Did that already and is says best drivers are already installed!! > > "Marco Dalli" wrote: > > > When vista asks you for the drivers, try specifying C:\Windows (or where you > > installed vista) with the subfolders option enabled. > > > > Marco > > > > "DuckRyder" <DuckRyder@discussions.microsoft.com> wrote in message > > news:A36853AC-A38B-4D60-AFC9-0E1D35A4B3DA@microsoft.com... > > > Its no help but I have exactly the same problem... > > > > > > "Lincoln 6 Echo" wrote: > > > > > >> Hi, > > >> > > >> I am trying to connect my Western Digital external hard drive over USB > > >> port > > >> and it seems vista cannot find the Usb MassStorage Device Driver > > > > |
| | #7 (permalink) |
| Guest | RE: External Hard Drive (USB MassStorage Device missing?) I am having the same problem, It worked fine on XP, and even on Vista using my laptop, but it cannot find any drivers (it shouldn't need any anyway) on Vista Ultimate on my desktop. This is a serious issue, and either Microsoft or Western Digital needs to fix it soon, because this is frankly absurd, and I'm frustrated. I've tried contacting Western Digital, and they have not responded. "Lincoln 6 Echo" wrote: > Hi, > > I am trying to connect my Western Digital external hard drive over USB port > and it seems vista cannot find the Usb MassStorage Device Driver ![]() > > Any thoughts? Even scanning my other partition with XP is not of use (it > says file not found). > > I thought MS would include at least these trivial drivers??? > > Petar > |
| | #8 (permalink) |
| Guest | RE: External Hard Drive (USB MassStorage Device missing?) Sorry, I can't believe there's no solution! Thanks. "luca" wrote: > I have a similar problem with a NEW notebook Acer TM8215 wlmi (Vista > Ultimate) and all sort of usb devices. Hard disk or pen drives work randomly > (also if they are usually shown in the device manager). Often Win searchs for > the driver without being able to install it. The system is not able to remove > them properly (the light keeps on flashing). > There are a lot of threads about Vista and usb problems. The Microsoft patch > did not help. Some times the devices work but with a lot of errors. I can > not believe it (Vista is very expensive). I do not think my problem is > hardware related. Any solutions? |
| | #9 (permalink) |
| Guest | RE: External Hard Drive (USB MassStorage Device missing?) I have a similar problem with a NEW notebook Acer TM8215 wlmi (Vista Ultimate) and all sort of usb devices. Hard disk or pen drives work randomly (also if they are usually shown in the device manager). Often Win searchs for the driver without being able to install it. The system is not able to remove them properly (the light keeps on flashing). There are a lot of threads about Vista and usb problems. The Microsoft patch did not help. Some times the devices work but with a lot of errors. I can not believe it (Vista is very expensive). I do not think my problem is hardware related. Any solutions? |
| | #10 (permalink) |
| Guest | RE: External Hard Drive (USB MassStorage Device missing?) I fixed the issue by installing updated motherboard drivers, and I could find and use the drive, then I restarted and got a BSOD (blue screen of death) and perpetual re-starting before Vista even started. I did a repair install, then restarted and the same thing happened. I got sick of it, and formatted and re-installed XP. I'm done with Vista for now, until Nvidia releases some finalized drivers for my 8800 GTX, and motherboard (nForce 680i). I'm really frustrated with Nvidia and Creative over driver issues with Vista, it's really absurd. |
| Complete PC Backup to external hard drive: share the drive? | Vista General | |||
| External Hard Drive Goes Missing | Vista hardware & devices | |||
| External hard drive appears as dvd drive | Vista General | |||
| Converting my external USB FAT external hard drive to NFTS | Vista hardware & devices | |||
| External DVD Drive / Hard Drive Vista Install | Vista General | |||
