Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Way to force monitor standby when resuming from sleep
LinkBack Thread Tools Display Modes
Old 10-04-2008   #1 (permalink)
Michele
Guest
I am experiencing an issue when i schedule a task that has the "Wake the
computer to run this task" option checked. The computer wakes up as expected
and the task runs but the monitor wakes up too showing only a black screen
with the mouse pointer on it, and i don't want the monitor to wake up.
My notebook has an Ati graphic card (X1600) that is connected to motherboard
through pci express connection.
Since it's a notebook i can't turn off the power of the monitor.
I think that this problem is related with Ati graphic cards or maybe, in
general, to all the graphic cards that are connected to the mother board
through pci express connections. I say so because i added an Ati pci express
ati graphic card on my hp desktop and using this ati card i have experienced
the exact above problem that i have on my notebook. Removing the ati pci
express card from the slot on my desktop pc and using the integrated Nvidia
graphic card my monitor remains correctly in standby mode when the pc wakes
up due to a scheduled task.
I have all the drivers updated, both on ati graphic card of notebook and
desktop.
Is there a way to force monitor to remain in standby state when the computer
wakes up due to a scheduled task?
Really thanks a lot for anyone who can give me any help or suggestion.
Best regards
Michele
Old 10-04-2008   #2 (permalink)
Wandering
Guest
Re: Way to force monitor standby when resuming from sleep
It certainly sounds like you have diagnosed your problem well. Then it is an
ATI problem, and you should be contacting them. Make sure you are getting
the latest drivers for whatever operating system you are running, and that
you are getting them from the ATI site, not from Microsoft Update.
It may well be there is no answer. Remember, computers do not do what you
"want them to" only what you tell them to, and only if they can do it. Good
luck.
"Michele" <Michele@xxxxxx> wrote in message
news:C559F933-1F12-4204-8F20-144C796E5500@xxxxxx
> expected
> motherboard
> express
> experienced
> Nvidia
> wakes
> desktop.
> computer
> Best regards
> Michele
Display Modes
Monitor standby when computer wakes up from sleep Michele Vista General 0 09-30-2008 03:43 AM
Monitor resolution forcibly changed after resuming from sleep whenusing KVM - how to fix? atomice Vista General 0 03-15-2008 05:16 AM
Monitor flashes 3 times after Resuming Vista Vista User Vista General 4 12-20-2007 01:12 PM
BSOD after resuming from sleep Sachin Vista General 0 08-20-2007 08:44 AM
Error when resuming from standby (ASUS SK-06903-XMA) Gakubuchi MSX Vista hardware & devices 0 06-15-2006 02:03 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
