Vista - problem with blue screen caused by ethernet adapter or other cause
Old 10-10-2008   #1 (permalink)
Indrit
Log Name: Application
Source: Windows Error Reporting
Date: 2008-10-11 2:58:15.PD
Event ID: 1001
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Computer: GezimDibra-PC
Description:
Fault bucket X64_0xA_Rtlh64+fa9e, type 0
Event Name: BlueScreen
Response:
http://oca.microsoft.com/resredir.as...xA_Rtlh64+fa9e
Cab Id: 0
Problem signature:
P1:
P2:
P3:
P4:
P5:
P6:
P7:
P8:
P9:
P10:
C:\Windows\Minidump\Mini101108-01.dmp
C:\Users\Indrit\AppData\Local\Temp\WER-50247-0.sysdata.xml
C:\Users\Indrit\AppData\Local\Temp\WERFF16.tmp.version.txt
These files may be available here:
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Report0e7d3948
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Windows Error Reporting" />
<EventID Qualifiers="0">1001</EventID>
<Level>4</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2008-10-11T00:58:15.000Z" />
<EventRecordID>3314</EventRecordID>
<Channel>Application</Channel>
<Computer>GezimDibra-PC</Computer>
<Security />
</System>
<EventData>
<Data>X64_0xA_Rtlh64+fa9e</Data>
<Data>0</Data>
<Data>BlueScreen</Data>
<Data>http://oca.microsoft.com/resredir.aspx?sid=13805&FailureId=X64_0xA_Rtlh64+fa9e</Data>
<Data>0</Data>
<Data>
</Data>
<Data>
</Data>
<Data>
</Data>
<Data>
</Data>
<Data>
</Data>
<Data>
</Data>
<Data>
</Data>
<Data>
</Data>
<Data>
</Data>
<Data>
</Data>
<Data>
C:\Users\Indrit\AppData\Local\Temp\WERFF16.tmp.version.txt</Data>
<Data>C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Report0e7d3948</Data>
</EventData>
</Event>
Finding the driver that caused a double fault blue screen? Vista General
Blue Screen related to Ethernet networking Vista hardware & devices
Blue screen after plugging in ethernet cable Vista hardware & devices
Blue screen caused by spyware Vista security
first boot blue screen caused byCanon scanner Vista installation & setup
