Vista - Lenovo wi-fi driver problem
Old 10-15-2008   #1 (permalink)
crates (Eric Johnson)
After between 1 and 8 hours of use, my Lenovo X60s gives me a BSOD sourced to
athr.sys, the driver for my Atheros wi-fi AP. Event viewer gives fault bucket
0xD1_athr+82f9f ... Anyone seen this? I can't roll the driver back, although
I can probably delete the driver and install an older one which could be
found on the Lenovo site. But every month or two, Windows Update does its
thing and causes the new driver to reappear, with resulting BSODs. Bright
ideas welcome. (I can't trace any particular activity to causing the BSOD--it
can happen without my having touched the computer; but it happens only if the
wi-fi AP is turned on, i.e. if I turn it off and stick with my 802.3 port,
the BSOD won't occur.)
Old 10-15-2008   #2 (permalink)
David B.
Re: Lenovo wi-fi driver problem
The obvious solution would be to deny the driver Windows Update is trying to
feed you, never ever install drivers from Windows Update, get them from the
hardware/PC mfg.
Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm
How to ask a question http://support.microsoft.com/kb/555375
Help Us Help You http://dts-l.net/goodpost.htm
"crates (Eric Johnson)" <crates (Eric Johnson)@discussions.microsoft.com>
wrote in message news:C7D66A17-A182-4C00-9F22-8F71C3FF8E62@xxxxxx
> to
> bucket
> although
> BSOD--it
> the
Old 10-15-2008   #3 (permalink)
Thanks, David. Obviously. Except that this problem driver isn't actually
coming from MS (it's not in any of the Windows Updates)--it's being loaded as
a side-effect of the MS Updates (go figure). Sure, I can disable MS automatic
updates, and lose the benefit of my software being kept up-to-date, but
that's a big price to pay. Anyway. No silver bullet, I guess.
Old 10-15-2008   #4 (permalink)
R. C. White
Hi, Eric.
Uh... What does that mean?
RC
R. C. White, CPA
San Marcos, TX
rc@xxxxxx
Microsoft Windows MVP
(Running Windows Live Mail 2008 in Vista Ultimate x64 SP1)
"crates (Eric Johnson)" <cratesEricJohnson@xxxxxx> wrote
in message news:45B649F1-C0DC-4DAD-96F3-02A542E28F4A@xxxxxx
> as
> automatic
Old 10-15-2008   #5 (permalink)
DL
If the driver isn't being supplied by MS Update who is it coming from?
Check your MS Update history.
MS Update can be set to ignore driver updates and only install critical
updates.
> as
> automatic
Old 10-15-2008   #6 (permalink)
David B.
This makes no sense, it's either coming from MS update or it's not, where do
you see the update when it tries to install?
> as
> automatic
Old 10-15-2008   #7 (permalink)
Wandering
Just set Vista Updater to show you the list of updates available, and pick
the ones you want to stall. DO NOT let it install whatever it wants
automatically. You will lose no functionality, and you just uncheck the
"system" drivers it wants to send you. then when you have the time, go the
the device manufacturers website and download the drivers there. If you
continue to let Vista update automatically, it is only a matter of time till
something on your machine, like video or sound breaks, and you end up having
to roll back and download elsewhere in any event. It's pretty hard to
operate your machine with a black screen.
Good luck.
> as
> automatic
vista driver for lenovo 89p8800 Drivers
IBM Lenovo X60t Tablet Pc wireless card driver doesn't work after x64 Vista Drivers
for user that have the driver problem driver. How do we clean inst Vista installation & setup
New Lenovo Vista General
RE: Vista install problem - Failed to add driver package into driver s Vista installation & setup
