Vista - bluescreen 0xd1_p17+3998b, type 0 Sound Issue
Old 10-18-2008   #1 (permalink)
N1CKJUM4NJ1
I keep getting the bluescreen, first from flash and now from my audio software.
I tried 'Problem Reports and Solutions' but the solutions i found did not
work, and I have searched these boards but I found nothing.
I am on Windows Vista Home Premium.
Sound Card:-
Manufacturor: Creative Technology Incorporated
Driver: P17.sys
I did a scan on the Event Viewer and the Fault Bucket is '0xD1P17+3998b,
type 0'
A solution to the problem would be helpful, thanks.
bluescreen issue Vista General
Bluescreen 0XD1_MRVW13B+23580,type 0 Vista hardware & devices
Windows Vista mouse issue.. Possibly ease of use type issue? Vista hardware & devices
Constant BlueScreen crashes -- driver issue? Vista hardware & devices
Setting per Application Sound Output, or Per Sound Type Outputs... Vista General
