Vista - HEELP!!!!I HAVE A BIG SIGMATEL HD AUDIO DRIVER PROBLEM FOR VISTA
Old 10-22-2008   #1 (permalink)
flare86
(My comp runs on vista)I have an x on my audio icon that's next to the time
on my desktop.When i go to the properties of the audio no driver appears.(no
name or nothin)it used to say sigmatel. When i try to install driver with the
help wizard i get this message..(Windows found driver software for your
device but encountered an error while attempting to install it.) it also says
(A device attached to the system is not functioning.) When i go to device
manager there is a question mark on the Sigmatel high definition audio
CODEC. I tried so many sigmatel drivers from the internet and none of them
work..If anyone can help me i would really aprreshiate it... mayday maydday
help!!!
fl
Old 10-22-2008   #2 (permalink)
DDW
Re: HEELP!!!!I HAVE A BIG SIGMATEL HD AUDIO DRIVER PROBLEM FOR VISTA
On Wed, 22 Oct 2008 11:40:18 -0700, flare86
>CODEC.
DELETE the item and reboot.
>help!!!
All that playing around with "so many sigmatel drivers" probably
screwed your system up worse than it was.
You need to find out EXACTLY what sound card is on your system.
Try Googling "belarc advisor". Find it, install it, run it. Find the
sound card in the list.
DDW
Reply via this group
No email please
Stereo Mix and Sigmatel Audio and driver problem! Sound & Audio
SigmaTel High Definition Audio Driver Vista hardware & devices
Vista/Windows Media Player/SigmaTel Audio Driver ERROR Vista music pictures video
SigmaTel audio driver installation - solved Vista hardware & devices
Sigmatel Audio Driver Vista hardware & devices
