Driver error on USB Stick and other USB devices
  1. #1
    =?Utf-8?B?Q2hyaXM=?= Guest
    After installing an upgrade to 5600 I tried to install
    - a compact flash
    - 2 different usb sticks
    - a cf card, sd card, memory stick card reader on USB
    All have the same issue. The USB storage driver installs but the device
    driver underneath fails with the error
    "Disk Drive"
    The drivers for this device are not installed. (Code 28)
    The parameter is incorrect.
    This are standard USB sticks or Compact flash cards. Do i really need a
    driver from the manufacturer for them, should those standard drivers not be
    included?
    the events I get are like:
    Driver Management concluded the process to install driver
    FileRepository\disk.inf_21f4651a\disk.inf for Device Instance ID
    USBSTOR\DISK&VEN_GENERIC&PROD_USB_SD_READER&REV_1.00\058F312D81B&0 with the
    following status: 87.
    Any help is appreciated!
  2. #2
    rogerlebo Guest
    Re: Driver error on USB Stick and other USB devices
    Hi!
    I run Vista RC1 32-bits.
    I have the same problem but the code is 10.
    So, USB does not work.
    Only USB for mouse and keyboard works well.
    But all my USB work fine with:
    Vista Build 5384 64-bits
    Vista RC1 64-bits
    Windows XP.
    Bonne journée! Roger
    "Chris" <ceckl@nospam.nospam> wrote in message
    news:F183FE59-CD9B-4AD1-AD88-ACB63952252C@microsoft.com...
    > - a compact flash
    > "Disk Drive"
    > be
    > included?
    > the
  3. #3
    =?Utf-8?B?RGVubmlz?= Guest
    RE: Driver error on USB Stick and other USB devices
    Not an answer, but more evidence. My Nikon slide scanner worked just fine in
    the prior beta build, but I'm, seeing the same message from 5600.
    > - a compact flash
    > "Disk Drive"
    > included?
  4. #4
    Pavel A. Guest
    Please do bug reports on this. I'm using all kinds of flash drives on RC1, no problem.
    --PA
    "rogerlebo" <no.spam@no.spam> wrote in message news:uD4$SXP4GHA.1196@TK2MSFTNGP02.phx.gbl...
    > Hi!
    > Vista RC1 64-bits
    > Windows XP.
    > Bonne journee! Roger
    > "Chris" <ceckl@nospam.nospam> wrote in message news:F183FE59-CD9B-4AD1-AD88-ACB63952252C@microsoft.com...
    >> - a compact flash
    >> "Disk Drive"
    >> included?
  5. #5
    Build 5728 fixed the problem. It even let me install Nikon scan 4 normally
    instead of having to find setup.exe and telling vista it was an xp program.
    driver installed normally, all is good with this release and usb on my system.
    > > - a compact flash
    > > "Disk Drive"
    > > included?
  6. #6
    I will try 5728 towards end of next week and will give feedback then.
    Thanks
    > > > - a compact flash
    > > > "Disk Drive"
    > > > included?
  7. #7
    Phil Keogh Guest
    I got the same error with all USB Mass Storage devices from flash drives to
    iPods. I was able to successfully get them working by uninstalling the
    software for my Netgear SC101 network storage unit, which doesn't work in
    Vista anyway. Perhaps there is a similar device with bad drivers on your
    system mucking things up as well.
    Phil
    > - a compact flash
    > "Disk Drive"
    > included?
  8. #8
    funboy3 Guest
    Thanks. This solved my problems. It must have been a conflict
    > Hope this helps,
    > Phil
    > > - a compact flash
    > > "Disk Drive"
    > > included?
  9. #9
    Newbie
    Local Time: 04:46 PM
    I had similar problems with my XP to Vista upgrade. Seems the problem was a conflict with the software / drivers for my Netgear SC101 which was left on the machine after the upgrade. I removed the software and my machine now sees my USB storage devices.
  10. #10
    Laurent I Guest
    GREAT ! I had the same issue. Netgear SC101 software was the problem. Thank
    you !
    > Hope this helps,
    > Phil
    > > - a compact flash
    > > "Disk Drive"
    > > included?
Driver error on USB Stick and other USB devices problems?
Texas Instruments PCI 7420 Memory Stick Driver ? Wonderman Vista hardware & devices 0 08 Aug 2007
Driver Letter Assignments wont stick in Vista IceHockeyJason Vista hardware & devices 1 28 Apr 2007
problems with USB-barcode reader driver / USB-memory-stick drivers Marko P Vista hardware & devices 5 01 Apr 2007
Driver error on USB Stick and other USB devices =?Utf-8?B?Q2hyaXM=?= Vista hardware & devices 0 25 Sep 2006
Texas Instrument PCIxx21 (flashmedia/memory stick reader) Driver jjpacres Vista hardware & devices 1 02 Jul 2006
