Vista - Error installing USB Memory stick or compact flash card
Old 09-25-2006   #1 (permalink)
=?Utf-8?B?Q2hyaXM=?=
After installing an upgrade to 5600 I tried to install
- a compact flash
- 2 different usb sticks
- a cf card, sd card, memory stick card reader on USB
All have the same issue. The USB storage driver installs but the device
driver underneath fails with the error
Disk Drive
The drivers for this device are not installed. (Code 28)
The parameter is incorrect.
This are standard USB sticks or Compact flash cards. Do i really need a
driver from the manufacturer for them, should those standard drivers not be
included?
the events I get are like:
Driver Management concluded the process to install driver
FileRepository\disk.inf_21f4651a\disk.inf for Device Instance ID
USBSTOR\DISK&VEN_GENERIC&PROD_USB_SD_READER&REV_1.00\058F312D81B&0 with the
following status: 87.
Any help is appreciated!
Flash Memory Card Reader - 16 GB SD Card - Won't Read Vista hardware & devices
memory flash stick Vista hardware & devices
Auto protect automaticly erases my USB flash memory stick. Vista General
USB Memory Stick & Flash Drive Vista General
memory stick causes STOP Error Vista hardware & devices
