| | USB external hard drive problem. I had 3 Lacie 250GB USB hard drives connected to my Vista Home Premium HP Quad system, along with USB Hubs and a printer. and all was well with the world until this weekend. I started getting the following message error popping up every 15 seconds every time the USB drives were turned on: "Exception processing message 0xc00000130parameters 0x763392A0 0xc00000004 0x763392A0 0x763392A0". I wasn't sure what was causing it until I disconnected the Lacie drives and it stopped. I tried the drives on my other XP system and they perform normally with no error messages. I tried uninstalling the USB controllers, Hubs and devices through Device Manager thinking Vista would re configure them when I rebooted and reset anything out of the ordinary - bad drivers or conflicting ports or whatever. Still get the same message when they're reconnected. I attached a Cavalry 500GB external USB and that works OK. So do the hubs and printer. but none of the Lacies work. Apparently, Lacie relies on Vista native drivers as none are listed on their site. But then Cavalry does too. I thought it might ne a corrupted native Vista driver but can't find the right info to replace the driver folder contents with fresh native copies on the Microsoft site. Am I on the right track or can anyone decipher the message and point me to a solution? Disco Doc |
| 1 TB External Hard Drive Problem | Vista hardware & devices | |||
| External Hard Drive PROBLEM ~~ Need HELP! | Vista General | |||
| External hard drive problem | Vista General | |||
