| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Guest | Wireless connection stopped working A friend with a vista PC was having problems connecting wirelessly to a router. It had been working OK for months then she decided to download the MS Office 2007 trial. Since then her wireless connection stopped working (though I have no idea why this happened at this time). Their other computer was also having a really slow ethernet connection so I had them buy a new cisco wireles router with his new PC. I told the Vista machine to connect to the new SSID but I had set up WPA on the router and vista didn't have that option. So then I changed it to WEP on the router but vista said it couldn't connect. A help menu had me run some netsh commands about adhoc and infrastructure but it still didn't work so I rebooted. Now the vista PC doesn't even see any wireless networks available, but a laptop I tried as a test still sees three SSIDs including the new one. What are my troubleshooting steps in vista to find out what is wrong with her wireless connection and how to fix it? And how can I find out what is still making the network still slow - the other machine is brand new with WinXP? |
| | #2 (permalink) | ||||||||||||||||||||||||
| Guest | Re: Wireless connection stopped working M Skabialka wrote:
particular, who knows what you managed to do with netsh. But here goes anyway. This is simply wrong:
Start by ensuring that the laptop's wifi adapter is actually turned on and functioning. Check the documentation for a physical switch or Fn+Fkey combination. Check Device Manager. If you get things back to where you can detect the presence of wireless networks, then configure the router to use *no* security at all (no encryption, no IP filters, no MAC filters, etc.) and try to connect. If you can connect when there is no security present, then add back WPA2-Personal encryption and try connecting again. -- Lem -- MS-MVP To the moon and back with 2K words of RAM and 36K words of ROM. http://en.wikipedia.org/wiki/Apollo_Guidance_Computer http://history.nasa.gov/afj/compessay.htm | ||||||||||||||||||||||||
My System Specs![]() | |||||||||||||||||||||||||
| | #3 (permalink) | ||||||||||||
| Guest | Re: Wireless connection stopped working On Nov 20, 2:40*pm, "M Skabialka" <mskabia...@xxxxxx> wrote:
On the Vista PC, look at all anti-virus / firewall settings. These can "block" access to the wireless network SSID. On the Windows XP, turn of the "QoS Scheduler." Most "home" router do not have this "feature" implemented correctly. | ||||||||||||
| | #4 (permalink) | ||||||||||||||||||||||||||||||||||||
| Guest | Re: Wireless connection stopped working When I still could see the wireless networks and couldn't connect I tried an option to manually connect. Under the security setting options were: none, WEP and 802.11x, there wasn't an option for WPA. I tried setting the router to have no security but was still unable to see any networks. Device manager shows no problems - it is not disabled. I am not sure about Vista SP1 so have downloaded it for install next time I go to her house. If that netsh command was a problem - is there a way to reverse the effects and start setting up the wireless card from scratch? I am not near the machine and the command was run from the start menu so I don't even know if I could find it again to see what I did. It was suggested in a troubleshooting menu on the machine. The vista machine is 21 months old and wireless was working until recently. The router is new. What are the steps to remove and reinstall the wireless capabilities in Vista (which I am not very familiar with)? "Lem" <lemp40@xxxxxx> wrote in message news:unDDqJySJHA.5080@xxxxxx
My System Specs![]() | |||||||||||||||||||||||||||||||||||||
| | #5 (permalink) | ||||||||||||
| Guest | Re: Wireless connection stopped working What bothers me is that not seeing the wireless networks is something I have caused somehow - so I have made a bad situation (cannot connect) worse (cannot see networks to connect to). Since I broke it, now I have to fix it..! "smlunatick" <yveslec@xxxxxx> wrote in message news:00e2e985-f6f2-4d54-afda-950d45b07791@xxxxxx On Nov 20, 2:40 pm, "M Skabialka" <mskabia...@xxxxxx> wrote:
| | #6 (permalink) | ||||||||||||||||||||||||||||||||||||||||||||||||
| Guest | Re: Wireless connection stopped working I think this is the help menu I found: 1. Open the Command Prompt window by clicking the Start button , clicking All Programs, clicking Accessories, and then clicking Command Prompt. 2. Type netsh wlan add filter networktype=network type. Where network type is either adhoc or infrastructure. I was unsure of the network type (still am) so tried both adhoc and infrastructure but neither worked. Did this mess things up? "M Skabialka" <mskabialka@xxxxxx> wrote in message news:ORqku2ySJHA.5364@xxxxxx
My System Specs![]() | |||||||||||||||||||||||||||||||||||||||||||||||||
| | #7 (permalink) | ||||||||||||||||||||||||||||||||||||||||||||||||
Unfortunately, I'm not very familiar with Vista either. It's not that there's anything "bad" about netsh, it's just that there's potential for reconfiguring things that normally one ought not to be configuring. You should be able to deal with normal wireless networking issues using the GUI. I assume that because you can see the router's SSID from a Win XP box that you didn't configure the router to not broadcast SSID. If for some reason my assumption is wrong, change the router to permit SSID broadcast. Device Manager showing "enabled" is only part of the issue. You have to ensure that the wifi radio is actually turned on. This will be accomplished either with an actual physical switch or (more likely) Fn+Fkey. -- Lem -- MS-MVP To the moon and back with 2K words of RAM and 36K words of ROM. http://en.wikipedia.org/wiki/Apollo_Guidance_Computer http://history.nasa.gov/afj/compessay.htm | ||||||||||||||||||||||||||||||||||||||||||||||||
| | #8 (permalink) | ||||||||||||
computer-to-computer network; this won't work with your router. I don't know what the command you typed here will do because you omitted the actual filter itself (i.e., permission={allow|block| denyall}). To see how things are configured: In an account with administrative privileges, open a Command Prompt window. Then type "netsh show all" [without quotes, press Enter] Copy/paste the results into your next post. Or you could delete the profile and start over (but I think you have to use netsh for this task). netsh show profiles [to make sure you get the correct ProfileName] netsh delete profile name=ProfileName -- Lem -- MS-MVP To the moon and back with 2K words of RAM and 36K words of ROM. http://en.wikipedia.org/wiki/Apollo_Guidance_Computer http://history.nasa.gov/afj/compessay.htm | ||||||||||||
| | #9 (permalink) | ||||||||||||||||||||||||
| Guest | Re: Wireless connection stopped working I won't be over there for a couple of weeks so will continue this thread then - or maybe a new thread if this is buried too deep. Thanks for the suggestions so far... "Lem" <lemp40@xxxxxx> wrote in message news:eQWT%23ezSJHA.1164@xxxxxx
| | #10 (permalink) | ||||||||||||||||||||||||||||||||||||
| Guest | Re: Wireless connection stopped working I found a very similar issue with my wife's corporate computer on our home network. The issue turned out to be the Intel wireless application installed which overrides the Windows wireless applet. After installing a driver update from Intel - this issue was resolved. Had to use Locksmith to get admin access, but that is another story. "M Skabialka" <mskabialka@xxxxxx> wrote in message news:uIlkEF0SJHA.1164@xxxxxx
| Display Modes | |
| IE7 & Firefox Stopped working as if no Internet Connection | VistaHopeless | Network & Internet | 35 | 01-05-2009 10:47 AM |
| Vista Wireless connection stopped working | WonderWoman | Vista General | 5 | 06-14-2007 12:39 AM |
| Wireless gadget stopped working | Fred B. | Vista General | 1 | 05-07-2007 12:54 PM |
| Wireless suddenly stopped working | =?Utf-8?B?bW9l?= | Vista networking & sharing | 2 | 07-30-2006 08:47 PM |
| Wireless stopped working | Tom Scales | Vista networking & sharing | 2 | 06-20-2006 12:21 AM |
