Vista - Intermitant Mouse Problems
Old 12-01-2008   #1 (permalink)
Vista Home Premium 32bit
I'm using Vista Home Premium 32, a newish MS Wireless Laser Desktop 6000 (tried another set, same problem) set on six month old pc with plenty of everything. I run anti virus/spyware regularly and updates. Periodically, my mouse will suddently start slowing down and I have to bang several times on the buttons to get the response and when it does it is slower than usual. This just happens out of nowhere, lasts for a few days, then goes back to normal. This happens with or without a browser open and on just one window open and is very annoying and frustrating. I didn't have this problem when I used XP.
I would greatly appreciate any assistance I can get on this. Thanks!
Old 12-01-2008   #2 (permalink)
Vista home premium 64 bit
Re: Intermitant Mouse Problems
have you got anything set in program scheduler that may be causing a glitch with your system?
Next time it happens boot into safe mode to see if it resolves the problem.
Post your results.
Old 12-01-2008   #3 (permalink)
trouble
Never use hibernation/sleep, always shut down and reboot your computer.
Also there may be electronic interference with the wireless mouse, a more
common problem than manufacturers will admit.
If your mouse is near a wireless router or other wireless devices (even
telephones) that may be the problem.
Re: Unexpected recurring but very intermitant ding. Vista General
mouse problems Vista hardware & devices
mouse problems Vista General
intermitant email problem Vista mail
Intermitant lag/process spike/whatever @ 60 second intervals Vista performance & maintenance
