| | Bluetooth v1.2 Dongle and Plantronics Voyager 510 ok, once more a bluetooth problem with vista build 5728. when i plug in the bt usb dongle, it is found and installed properly. in the device mangager i can see a plantronics usb bluetooth device, but marked with an asterisk. the details say it is a generic usb driver, but the device would not work. then after a little googling i found out that i should try using the (patched) widcomm bt stack. installed it, and pointed the plantronics device to use one of the widcomm stack drivers (in /bin directory) which let me choose between bt audio and bt high quality audio drivers. i tried both paths, and the plantronics device was no longer wearing the asterisk. i was then able to choose "high quality audio (plantronics usb)" in skype, and tried called the test caller. While the plantronics device makes the proper click sound (connected), i cant either hear the caller nor speak to it. any further ideas? Regards, Sascha |
| | RE: Bluetooth v1.2 Dongle and Plantronics Voyager 510 Sorry for the tripple post.. but i always received the note that my post couldnt be published :-( (next time i really double-check first ehh?) "Sascha" wrote: > ok, once more a bluetooth problem with vista build 5728. > > when i plug in the bt usb dongle, it is found and installed > properly. in the device mangager i can see a plantronics usb > bluetooth device, but marked with an asterisk. the details say > it is a generic usb driver, but the device would not work. > > then after a little googling i found out that i should try using > the (patched) widcomm bt stack. installed it, and pointed the > plantronics device to use one of the widcomm stack drivers (in /bin > directory) which let me choose between bt audio and bt high quality > audio drivers. i tried both paths, and the plantronics device was > no longer wearing the asterisk. > > i was then able to choose "high quality audio (plantronics usb)" > in skype, and tried called the test caller. While the plantronics device > makes the proper click sound (connected), i cant either hear the > caller nor speak to it. > > any further ideas? > > Regards, Sascha > > |
| Bluetooth v1.2 Dongle and Plantronics Voyager 510 | Vista hardware & devices | |||
| Bluetooth v1.2 Dongle + Plantronics Voyager 510 | Vista hardware & devices | |||
| Plantronics 320 Bluetooth Headset issue | Vista hardware & devices | |||
