| Vista Home Premium x64 | Power Supply I have a dell insp. 531s with a 250W power supply. Dell support says upgrading to anything over (like 400W) would potentially fry my components, is this true? Is it safe to upgrade to a higher wattage? |
| | Re: Power Supply On Fri, 12 Dec 2008 16:16:54 -0600, Vista_32bit <guest@xxxxxx-email.com> wrote: Quote: > >I have a dell insp. 531s with a 250W power supply. Dell support says >upgrading to anything over (like 400W) would potentially fry my >components, is this true? Is it safe to upgrade to a higher wattage? power-hungry new components or added any of the latter, you don't need any more power than what was originally supplied. PJ White |
| Vista Home Premium x64 | Re: Power Supply On Fri, 12 Dec 2008 16:16:54 -0600, Vista_32bit <guest@xxxxxx-email.com> wrote: Quote: > >I have a dell insp. 531s with a 250W power supply. Dell support says >upgrading to anything over (like 400W) would potentially fry my >components, is this true? Is it safe to upgrade to a higher wattage? power-hungry new components or added any of the latter, you don't need any more power than what was originally supplied. PJ White |
| | Re: Power Supply The Dell rep is totally wrong a power supply only supplies the power that is required by the components and no more. It would be like saying that if you increase the available bandwidth of your computer's network connection that it would destroy your computer "Vista_32bit" <guest@xxxxxx-email.com> wrote in message news:9945640e2aadfd3369b829fd28cc8051@xxxxxx-gateway.com... Quote: > > I have a dell insp. 531s with a 250W power supply. Dell support says > upgrading to anything over (like 400W) would potentially fry my > components, is this true? Is it safe to upgrade to a higher wattage? > > > -- > Vista_32bit |
| | Re: Power Supply 1. Dell likely does not have one of their customized power supplies of higher wattage that fits the mounting methodology used in your computer. 2. They would rather you buy a new computer anyway. If you can find an after market P/S that fits the mounting configuration used by Dell (which is done so that you "must" go back to them for parts) then by all means - purchase it. You will not damage your computer by going to a higher wattage supply. -- Richard Urban Microsoft MVP Windows Desktop Experience "Vista_32bit" <guest@xxxxxx-email.com> wrote in message news:9945640e2aadfd3369b829fd28cc8051@xxxxxx-gateway.com... Quote: > > I have a dell insp. 531s with a 250W power supply. Dell support says > upgrading to anything over (like 400W) would potentially fry my > components, is this true? Is it safe to upgrade to a higher wattage? > > > -- > Vista_32bit |
| | #6 (permalink) |
| | Re: Power Supply "Vista_32bit" <guest@xxxxxx-email.com> wrote in message news:9945640e2aadfd3369b829fd28cc8051@xxxxxx-gateway.com... Quote: > > I have a dell insp. 531s with a 250W power supply. Dell support says > upgrading to anything over (like 400W) would potentially fry my > components, is this true? Is it safe to upgrade to a higher wattage? > > > -- > Vista_32bit proprietary components is that generic replacements often *do not* fit/connect the same way and thus cannot be used with the Dell hardware. So, before you order a replacement PSU, I'd take the unit to a trustworthy local shop and spend a few bucks extra to have them fit a new PSU. If they look at it and tell you they can't do it, you'll know you're in the situation described above. |
| | #7 (permalink) |
| | Re: Power Supply That is a total BS. Dell probably does not have this PS. Find one and install it or have it installed. Output to MOBO is all the same be it 200W or 400W. The only difference that there is , is the amount of peripherals that it can connect to and safely keep it fed with steady stream of power without starving the rest of the hardware. -- Peter Please Reply to Newsgroup for the benefit of others Requests for assistance by email can not and will not be acknowledged. "Vista_32bit" <guest@xxxxxx-email.com> wrote in message news:9945640e2aadfd3369b829fd28cc8051@xxxxxx-gateway.com... Quote: > > I have a dell insp. 531s with a 250W power supply. Dell support says > upgrading to anything over (like 400W) would potentially fry my > components, is this true? Is it safe to upgrade to a higher wattage? > > > -- > Vista_32bit |
| | #8 (permalink) |
| | Re: Power Supply "Vista_32bit" <guest@xxxxxx-email.com> wrote in message news:9945640e2aadfd3369b829fd28cc8051@xxxxxx-gateway.com... Quote: > > I have a dell insp. 531s with a 250W power supply. Dell support says > upgrading to anything over (like 400W) would potentially fry my > components, is this true? Is it safe to upgrade to a higher wattage? > > > -- > Vista_32bit They say that because they supply specific power supplies for each model, and there is no provision.. Two possible obstacles. There may not be a 400w PS available in the physical size fitted to your machine.. you will have to take out the 250w and compare.. Also, Dell used to customize the order of wires which go into the motherboard plug. I don't think that they do this anymore, but it would be wise to check first.. -- Mike Hall - MVP How to construct a good post.. http://dts-l.com/goodpost.htm How to use the Microsoft Product Support Newsgroups.. http://support.microsoft.com/default...help&style=toc Mike's Window - My Blog.. http://msmvps.com/blogs/mikehall/default.aspx |
| | #9 (permalink) |
| | Re: Power Supply If the OP's PS does have non standard wiring connections then a new PS wired by the normal standard certainly could cause damage if the 12 volts out of the supply was connected to the pin(s) normally used for 5 volts on his MOBO. "Mike Hall - MVP" <mikehall@xxxxxx_mvps.com> wrote in message news:%23l3LBOTXJHA.556@xxxxxx Quote: > "Vista_32bit" <guest@xxxxxx-email.com> wrote in message > news:9945640e2aadfd3369b829fd28cc8051@xxxxxx-gateway.com... Quote: >> >> I have a dell insp. 531s with a 250W power supply. Dell support says >> upgrading to anything over (like 400W) would potentially fry my >> components, is this true? Is it safe to upgrade to a higher wattage? >> >> >> -- >> Vista_32bit > > They say that because they supply specific power supplies for each model, > and there is no provision.. > > Two possible obstacles. There may not be a 400w PS available in the > physical size fitted to your machine.. you will have to take out the 250w > and compare.. > > Also, Dell used to customize the order of wires which go into the > motherboard plug. I don't think that they do this anymore, but it would be > wise to check first.. > > > -- > Mike Hall - MVP > How to construct a good post.. > http://dts-l.com/goodpost.htm > How to use the Microsoft Product Support Newsgroups.. > http://support.microsoft.com/default...help&style=toc > Mike's Window - My Blog.. > http://msmvps.com/blogs/mikehall/default.aspx > > > > |
| | #10 (permalink) |
| | Re: Power Supply In addition to everyone else's good comments, it might be that there isn't enough cooling in your enclosure for 400W of power dissipation. Adding the higher-rated power supply doesn't change the power dissipation, but the new graphic card will. Maybe that's what Dell support meant about frying components. "Curious" <mailmenot@xxxxxx> wrote in message news:%23MOyU7UXJHA.5764@xxxxxx Quote: > If the OP's PS does have non standard wiring connections then a new PS > wired by the normal standard certainly could cause damage if the 12 volts > out of the supply was connected to the pin(s) normally used for 5 volts on > his MOBO. > "Mike Hall - MVP" <mikehall@xxxxxx_mvps.com> wrote in message > news:%23l3LBOTXJHA.556@xxxxxx Quote: >> "Vista_32bit" <guest@xxxxxx-email.com> wrote in message >> news:9945640e2aadfd3369b829fd28cc8051@xxxxxx-gateway.com... Quote: >>> >>> I have a dell insp. 531s with a 250W power supply. Dell support says >>> upgrading to anything over (like 400W) would potentially fry my >>> components, is this true? Is it safe to upgrade to a higher wattage? >>> -- >>> Vista_32bit >> >> They say that because they supply specific power supplies for each model, >> and there is no provision.. >> >> Two possible obstacles. There may not be a 400w PS available in the >> physical size fitted to your machine.. you will have to take out the 250w >> and compare.. >> >> Also, Dell used to customize the order of wires which go into the >> motherboard plug. I don't think that they do this anymore, but it would >> be wise to check first.. >> >> -- >> Mike Hall - MVP >> How to construct a good post.. >> http://dts-l.com/goodpost.htm >> How to use the Microsoft Product Support Newsgroups.. >> http://support.microsoft.com/default...help&style=toc >> Mike's Window - My Blog.. >> http://msmvps.com/blogs/mikehall/default.aspx |
| power supply | General Discussion | |||
| Bad power supply?? | Vista music pictures video | |||
| Need new power supply | General Discussion | |||
| Power Supply | General Discussion | |||
