APC UPS not recognized
  1. #1
    No One Guest
    Hi everyone ...
    I have an APC Smart UPS 700 that works well and was working on an XP machine
    that I replaced with a new Vista Home Premium machine. As with most new
    computers, it does not have a serial port, so I added a new serial/parallel
    card that DOES include a Vista 32 bit driver, and Device Manager says
    everything is fine, no conflicts.
    I hooked up the UPS and there are no options to recognize it. The
    notification setting has power grayed out and I cannot select it. The power
    options offer me nothing about a UPS as XP did. Help simply defines what a
    UPS is, (and I might note that to date Help has not helped me, not even
    once, nor has the Search.) There is a reference to battery meter, but I
    cannot get that to show.
    I take the cable and plug it up to the XP machine and it's recognized after
    reboot. I plug it into Vista and nothing. Any ideas?
    THANKS!
  2. #2
    Richard Urban Guest
    Re: APC UPS not recognized
    APC must supply drivers for the serial port UPS to be recognized by Vista.
    They are not going to do so.
    I have a Smart UPS and am in the same sinking boat.
    Richard Urban
    Microsoft MVP
    Windows Desktop Experience
    "No One" <noone@xxxxxx> wrote in message
    news:865A8B84-440E-4DA7-A5F9-46081B69C0ED@xxxxxx
    > Hi everyone ...
    > machine that I replaced with a new Vista Home Premium machine. As with
    > most new computers, it does not have a serial port, so I added a new
    > serial/parallel card that DOES include a Vista 32 bit driver, and Device
    > Manager says everything is fine, no conflicts.
    > power options offer me nothing about a UPS as XP did. Help simply defines
    > what a UPS is, (and I might note that to date Help has not helped me, not
    > even once, nor has the Search.) There is a reference to battery meter,
    > but I cannot get that to show.
    > after reboot. I plug it into Vista and nothing. Any ideas?
    > THANKS!
  3. #3
    No One Guest
    Ah, once again, abandon technology that WOULD work in an attempt to force
    you to buy new stuff. APC should know better than to cast adrift their
    existing customers and expect us to have any loyalty to them for the
    replacement.
    But so should Microsoft ... this was built in to XP - and did NOT require
    APC's Power Chute or anything else from APC - and should have been carried
    into Vista given such a critical part of the failure process, and a huge
    installed base.
    But thank you for an actual real-world, non-canned answer.
    It so happens that I do also have a Smart UPS 750, which does have the USB
    port, and I was able to swap it with a Smart UPS 700 which does not, and was
    the cause of this missive in the first place. Vista instantly recognized
    the USB connection and installed the driver automatically. Now I have to
    swap the serial/parallel card I bought and installed to make this work in
    the Vista machine to the XP machine. At least I have the technical
    wherewithal to know how to do all this AND that I need to ...
    But here's a thought ... I had originally removed the factory 56k modem from
    the sole PCI slot, put a parallel port in the Vista computer and installed
    it's driver to print to a legacy laser printer. I then changed that to the
    current serial/parallel card so Vista could sense the power status. Now
    I'll be removing the serial/parallel card, and probably sticking the
    parallel port back in. What's happening to all these drivers that I'm
    abandoning? Does this simply become storage bloat, or is Windows still
    looking for the drivers somewhere? And is there any way to get rid of
    unused drivers and all their related files?
    THANKS!!!
    "Richard Urban" <richardurbanREMOVETHIS@xxxxxx> wrote in message
    news:OE0vPkLXJHA.5364@xxxxxx
    > Richard Urban
    > Microsoft MVP
    >> Hi everyone ...
    >> defines what a UPS is, (and I might note that to date Help has not helped
    >> me, not even once, nor has the Search.) There is a reference to battery
    >> meter, but I cannot get that to show.
    >> THANKS!
  4. #4
    Mike Hall - MVP Guest
    news:2373CC94-2D75-4E95-B981-EC229DB72170@xxxxxx
    > replacement.
    > installed base.
    > was
    > from
    > the
    > THANKS!!!
    >> Vista. They are not going to do so.
    >> Richard Urban
    >> Microsoft MVP
    >>> Hi everyone ...
    >>> helped me, not even once, nor has the Search.) There is a reference to
    >>> battery meter, but I cannot get that to show.
    >>> THANKS!
    APC UPS products which connect via USB will work for Vista..
    Mike Hall - MVP
    How to construct a good post..
    http://dts-l.com/goodpost.htm
    How to use the Microsoft Product Support Newsgroups..
    http://support.microsoft.com/default...help&style=toc
    Mike's Window - My Blog..
    http://msmvps.com/blogs/mikehall/default.aspx
  5. #5
    Timothy Davis [MSFT] Guest
    > from
    > the
    You don't need to worry about this. There are registry entries and driver
    files left on your computer - but the impact of this is so small that I
    would not think twice.
    Windows ships with suppport for thousands of devices - so the drivers of
    these devices are already sitting on your machine taking up space until you
    plug in the applicable device. The modem/serial port driver adds 0.5% (made
    up number, of course) more bloat to your driver cache.
  6. #6
    John Guest
    > Richard Urban
    > Microsoft MVP
    My APC UPS 1400 works just fine on Vista Ultimate 64 bit
    connected to a serial port.
    The console software complains about Win32 major version 6
    when it starts but otherwise works fine. I'm using
    APC PowerChute Business Edition Version 7.0.4.
  7. #7
    Richard Urban Guest
    What about "Smart UPS" do you not understand?
    Yours is a later model! It works! Great!
    Mine works also. It just can not be integrated with any APC software and
    Vista does not recognize it when it is plugged into the serial port. But
    during a brown out or a power failure the onboard electronics keeps my
    computer chugging along.
    Richard Urban
    Microsoft MVP
    "John" <noaddress@xxxxxx> wrote in message
    news:e9vciiWXJHA.4944@xxxxxx
    >> Richard Urban
    >> Microsoft MVP
  8. #8
    Paul Shapiro Guest
    Did you use the APC-specific cable? I seem to remember a standard serial
    cable doesn't work with the Smart-UPS products. You might also check APC's
    website for a more recent version of their software. I thought 7.04 was the
    one with an expired java certificate that hosed the host machine, although
    maybe that was an even earlier version. I know that at least 7.05 is
    released.
    news:%23nWqjBXXJHA.2444@xxxxxx
    > Richard Urban
    > Microsoft MVP
    >>> Richard Urban
    >>> Microsoft MVP
  9. #9
    Richard Urban Guest
    The cable is permanently attached to the UPS.
    I am not worried as it protects me. I haven't even had the serial cable
    plugged in for the past 2 years.
    Richard Urban
    Microsoft MVP
    "Paul Shapiro" <paul@xxxxxx> wrote in message
    news:OY6RHwZXJHA.556@xxxxxx
    > the one with an expired java certificate that hosed the host machine,
    > although maybe that was an even earlier version. I know that at least 7.05
    > is released.
    >> Richard Urban
    >> Microsoft MVP
    >>>> Richard Urban
    >>>> Microsoft MVP
  10. #10
    No One Guest
    Yes, there IS a specific serial cable, and yes I am using it.
    APC's site talks about using PowerChute with Vista, points me to the version
    I should use, and I downloaded the latest and greatest, but when I tried
    PowerChute says it cannot find a USB device. THAT I had the same problem
    with on XP, so that's an APC issue.
    And yes, regardless of whether or not Vista can detect the UPC, it
    nevertheless powers the computer until my whole house generator kicks in.
    However, we all know that the batteries in these things fail just when you
    need them the most, and a controlled shutdown by Vista is preferable to
    shutdown through exhausted batteries.
    Thanks everyone. I boil this down to:
    Vista does not and will not recognize serial UPS's.
    APC gives no help, and PowerChute won't resolve the problem either in spite
    of their saying it will.
    So basically, legacy support is out.
    All that said, the UPS still works. It just doesn't communicate that fact
    to Vista.
    Hope everyone has a wonderful Holiday Season!
    Bill
    > is released.
    >> Richard Urban
    >> Microsoft MVP
    >>>> Richard Urban
    >>>> Microsoft MVP
Page 1 of 2 12 LastLast
APC UPS not recognized problems?
cd/dvd not recognized (not the same as others) kimberlee Vista hardware & devices 2 04 Mar 2009
dvd-rw not recognized LEDFinger General Discussion 2 26 Oct 2008
DVD-RW recognized as CD Patience Vista hardware & devices 1 09 Jan 2008
CDs sometimes not recognized Alan Vista General 0 03 Jun 2007
CD/DVD not recognized =?Utf-8?B?WnlwaGVY?= Vista hardware & devices 0 16 Sep 2006
