Vista - Problem with CDRW/DVD Player
Old 09-30-2006   #1 (permalink)
=?Utf-8?B?TW9yYml1cw==?=
After installing both build versions, one of my DVD drives does not recognize
any type of CD, it appears correctly installed at the Device Manager, but
when put a CD or DVD on it, is like there were on the bay.
The hardware with the problem is a LG model HL-DT-ST RW/DVD GCC-4320B
When try to reinstall the drivers, it says that it have the best drivers
available.
The other DVD works fine.
Any suggestion
Problem with TSST Corp CDRW/DVD TSL462D ATA Device Drivers
Problems fomatting CDRW Vista music pictures video
formating CDRW Vista General
Sony CDRW CRX230ES Vista hardware & devices
RC2 Lost CD Rom and CDRW Vista General
