| Vista Home Premium 32 bit | External eSATA Hard Drive Issue I have a Seagate 1TB SATAII hard drive that I put in an external enclosure. The enclosure allows for USB and eSATA connections. When I use the USB connector it works fine. When I connect it to the eSATA port of my card reader using an eSATA cable Windows Vista does not recognize the drive as being there. I already have 3 other Seagate internal drives running fine. Am I missing a driver or is there some special set up I need to do for the system to recognize an external eSATA drive? Looking for any help I can get. Thanks. |
| | Re: External eSATA Hard Drive Issue Does the external enclosure have a separate power supply??? peter -- If you find a posting or message from me offensive,inappropriate or disruptive,please ignore it. If you dont know how to ignore a posting complain to me and I will be only too happy to demonstrate :-) "Luvflt" <guest@xxxxxx-email.com> wrote in message news:7dea007f19d99a2255300d69c8592968@xxxxxx-gateway.com... Quote: > > I have a Seagate 1TB SATAII hard drive that I put in an external > enclosure. The enclosure allows for USB and eSATA connections. When I > use the USB connector it works fine. When I connect it to the eSATA port > of my card reader using an eSATA cable Windows Vista does not recognize > the drive as being there. I already have 3 other Seagate internal drives > running fine. Am I missing a driver or is there some special set up I > need to do for the system to recognize an external eSATA drive? Looking > for any help I can get. Thanks. > > > -- > Luvflt |
| Vista Home Premium 32 bit | Re: External eSATA Hard Drive Issue Sorry, wasn't aware there were external enclosures that didn't have an external power supply. Yes, mine does have an external power supply. Thanks |
| | Re: External eSATA Hard Drive Issue You have to enable the external SATA port in the BIOS of many if not most motherboards. It is rarely turned on by default. |
| | Re: External eSATA Hard Drive Issue I haven't seen that option in my Asus motherboard, no mention of eSata. By the way my eSata works on my Asus motherboard. "D Lirious" <fac_187@xxxxxx> wrote in message news:uCZGXQlZJHA.5520@xxxxxx Quote: > You have to enable the external SATA port in the BIOS of many if not most > motherboards. It is rarely turned on by default. |
| | #6 (permalink) |
| Vista Home Premium 32 bit | Re: External eSATA Hard Drive Issue D Lirious, Thanks for the info. I chcked my BIOS and all I could find was Sata ACHI MOde (Enable/Disable) and SATA Port 0-3 Native Mode (Enable Native IDE Mode or Disable Legacy IDE Mode) I am not familiary with either of these. Could one of them possibly be the ticket? Thanks |
| HELP. Maxtor OneTouch 4 (500 GB) External Hard Drive ISSUE! | General Discussion | |||
| DVD drive scans when external eSATA off | General Discussion | |||
| External Hard Drive Issue | General Discussion | |||
| eSATA External drive keeps vanishing | Vista hardware & devices | |||
| Issue with external hard drive | Vista General | |||
