Vista - No sound using HDMI cabling
Old 01-04-2009   #1 (permalink)
Charles W Davis
I assisted a Computer Club member setting up his new Acer computer running
Window Vista Home Premium. The cabling to the Samsung 35in TV/Monitor is
HDMI. All manuals state no other audio cables are necessary. I have been
unable to start sound. If I plug standard speakers into the output jacks on
the computer, all is well....
Any thoughts?
Old 01-04-2009   #2 (permalink)
Re: No sound using HDMI cabling
Hello Charles,
The sound card or chip will also need to support HDMI audio passthrough to the graphics card for it to work like this. Otherwise, you will need to use a separate audio connection from the audio output jacks on the computer to the monitor.
Hope this helps some,
Quote  Quote: Originally Posted by Charles W Davis View Post
Any thoughts?
Old 01-04-2009   #3 (permalink)
Curious
What graphics card are you using that supports HDMI with sound output?
"Charles W Davis" <Anthemwebs@xxxxxx> wrote in message
news:98F5B353-81F9-46A3-A9DB-04278DE2D8DA@xxxxxx
> Any thoughts?
Old 01-04-2009   #4 (permalink)
Hi Curious,
I do not have one, but the ATI Raden HD 4800 series support HDMI audio.
ATI Radeon™ HD 4800 Series - Overview
Quote  Quote: Originally Posted by Curious View Post
> Any thoughts?
Old 01-05-2009   #5 (permalink)
Richard G. Harper [MVP]
Right-click the speaker icon in the taskbar and select "Playback Devices".
Is the HDMI output available to be selected? If so select it, connect your
HDMI cable, you should be all set. Be sure to put it back onto speakers
when the HDMI is disconnected. If there is no HDMI output to be selected
your system does not support sound-out on the HDMI cable and you won't be
able to send sound to it.
Richard G. Harper [MVP Desktop] rgharper@xxxxxx
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
> Any thoughts?
Old 01-05-2009   #6 (permalink)
Curious
I should have said WHICH instead of What graphic card do you have that
supports HDMI with sound output.
I am aware of several ATI and several Nvidia cards that do.
"Brink" <guest@xxxxxx-email.com> wrote in message
news:37936e1e4697986480486ab5a0c7a004@xxxxxx-gateway.com...
Quote:
> Hi Curious,
> 'ATI Radeon™ HD 4800 Series - Overview'
> (http://ati.amd.com/products/radeonhd4800/index.html)
> Shawn
>> news:98F5B353-81F9-46A3-A9DB-04278DE2D8DA@xxxxxx> > >
>> > running
>> > is
>> > been
>> > jacks on
>> > > Any thoughts? > >
> Brink
> *There are no dumb questions, just the people that do not ask
> them.*
> '*Windows 7 Forums*'
> (http://www.sevenforums.com/) *and* '*::Vista Forums::*'
> (http://www.vistax64.com)
> *Please post feedback to help others.*
Old 01-05-2009   #7 (permalink)
No problem Curious.
I may get one the next time I upgrade. Whenever that may be.
Quote:
> Hi Curious,
> (ATI Radeon™ HD 4800 Series - Overview)
> Shawn
> Brink
> them.*
> (Windows 7 Forums) *and* '*::Vista Forums::*'
Old 01-05-2009   #8 (permalink)
vista home premium,32bit
hi brink,at the moment im using standard audio connections for my pc sound output,it also has spidf output,is it worth using that?i will need to buy new amp and optical lead.so before i do that i was wondering what every1 nelse uses and wots the dif,,,thanks to all.
Old 01-05-2009   #9 (permalink)
Quote  Quote: Originally Posted by garyboy View Post
Hi Gary,
For the best quality is to have the audio to run through HDMI. Optical is second, and S/PDIF is third in quality.
Personally I just use the standard audio output jacks on the back of the computer since I have no need for high quality sound. Unless you just want or need the higher quality sound for movies or games, then it would not be worth the costs for it over the standard jacks.
Old 01-06-2009   #10 (permalink)
Charles W Davis
Richard, that worked. Our computer club member thanks you.
"Richard G. Harper [MVP]" <rgharper@xxxxxx> wrote in message
news:BABBE61F-0568-4D69-95DA-3DB1C6F43DCA@xxxxxx
> your HDMI cable, you should be all set. Be sure to put it back onto
> speakers when the HDMI is disconnected. If there is no HDMI output to be
> selected your system does not support sound-out on the HDMI cable and you
> won't be able to send sound to it.
>>on the computer, all is well....
>> Any thoughts?
HDMI to amp no sound Sound & Audio
Optical or HDMI to amp for sound? Sound & Audio
No sound from TV with HDMI cable Sound & Audio
no sound through hdmi?? Sound & Audio
HDMI sound problem Vista installation & setup
