Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
creative sound blaster 5.1
LinkBack Thread Tools Display Modes
Old 01-06-2009   #1 (permalink)
udey rishi
Guest
i have a creative sound blaster 5.1...i removed d windows xp that i earlier
had n installed a fresh copy of windows vista......d drivers that i gt in d
CD with the sound card worked very well with xp....i tried 2 install d
drivers from d cd that i got.....d setup said that d drivers are not made for
this version of windows...but i tried to install d drivers using the
compatibility wizard feature of vista..d drivers were installed....n d card
started working,...but when i restarted d pc...d blue screen error came....i
started d pc by 'starting in last good configuration mode'.....and restarted
d pc again....the blue screen again came...i thought it is due to the drivers
that i installed using the compatibility wizard.....i uninstalled the drivers
and then tried restarting the pc.....then everything went normal...this means
that the drivers aren't compatible with vista.....so can anyone help me what
to do??
how to make d drivers work with vista without any problems.....??
or can u give me any link that can gimme d drivers for my creative sound
blaster 5.1 compatible with vista??
my email id is udey.rishi@xxxxxx...
Old 01-06-2009   #2 (permalink)
Gordon
Guest
Re: creative sound blaster 5.1
"udey rishi" <udey rishi@xxxxxx> wrote in message
news:FE544FF0-C8A4-46DB-BAD4-BF97C071087D@xxxxxx
> d
> for
> card
> came....i
> restarted
> drivers
> drivers
> means
> what
> to do??
Using the search terms of "Creative Soundblaster 5.1 Vista drivers" in
Google this was the THIRD hit:
http://www.aeonity.com/david/creativ...vista-download
Did you do ANY searching AT ALL?
Asking a question?
Please tell us the version of the application you are asking about,
your OS, Service Pack level
and the FULL contents of any error message(s)
Old 01-06-2009   #3 (permalink)
udey rishi
Guest
ya...i opened dis site.....it is giving drivers of some sound blaster
live!.....isn't it a dfrnt card??
or d same....if it is d same one....den do reply...........
Old 01-06-2009   #4 (permalink)
udey rishi
Guest
i'm having Windows Vista Service Pack1 installed in my pc....and my sound
card is Creative Sound Blaster 5.1............i searched 4 d drivers on d
site of creative....bt as usual...dey r givin drivers comaptible wid windows
xp n windows 2000
Old 01-06-2009   #5 (permalink)
Gordon
Guest
"udey rishi" <udeyrishi@xxxxxx> wrote in message
news:FC2EE086-3FC7-4EC3-B985-92A56B95DBB5@xxxxxx
Eh? Please post in STANDARD English, not some sort of SMS speak....
Asking a question?
Old 01-06-2009   #6 (permalink)
Joe Buck
Guest
On Tue, 6 Jan 2009 07:13:02 -0800, udey rishi
>xp n windows 2000
Does your SHIFT key work?
Is your PERIOD key sticking?
Is English your primary language?
Old 01-06-2009   #7 (permalink)
RalfG
Guest
Sound Blaster Live and some other hardware devices from Creative were
abandoned as far as Vista support.
news:1EF79A0B-3474-454A-B859-908D9F081223@xxxxxx
> windows
> xp n windows 2000
Old 01-06-2009   #8 (permalink)
RalfG
Guest
... except maybe the Sound Blaster 5.1 VX model.
The person at this link says he got SB drivers downloaded from Dell to work
in Vista. I haven't tried it but might be worth a look.
http://www.aeonity.com/david/476
> windows
> xp n windows 2000
Display Modes
Creative sound blaster live! value bigkrisspcs Drivers 4 12-28-2008 04:31 PM
Creative Sound Blaster Live! Charlie Vista hardware & devices 4 12-08-2008 02:45 AM
Creative Sound Blaster X-Fi Problem. Dave Vista hardware & devices 1 11-10-2007 07:13 AM
Creative Sound Blaster Audigy 2 ZX Platinum Sparhawk Vista hardware & devices 1 12-01-2006 01:48 AM
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Kevin John Panzke Vista General 1 10-14-2006 05:36 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
