Vista - Wireless Mouse not functioning
Old 01-07-2009   #1 (permalink)
Mircrosoft® Windows Vista™ Home Premium
I had a wireless mouse that came with my PC and then suddenly after a while it just stopped working and all it does when I put batteries in it, is flash it's little red light. I press the 'connect' button on the bottom of it but to no avail. I don't even think it's installed correctly or something like that. It's been a while since it stopped working. I'm not sure if I have the hand manuels for this wireless mouse either, I'll have to look if it's required to fix it.
I'm just using a Wheel Mouse Optical USB and PS/2 Compatible in the place of the 'broken' wireless mouse.
I'll probably just buy a new one but was wondering if there was a way to make sure it was broken at least? I mean like where specifically can I go to find the install directories (if that is something to look for)?
Or rather, how can I make my PC pick up the signal when I press the 'connect' button on the bottom of the mouse? It appears that a receiver is built into the PC since whenever I use the Media Center 'remote' that also came with my PC, a light flashes on the PC as if it was the receiver. Am I making sense lol??
Model No. MR-0601T
Power Rating: 3V 50mA
Serial No. 7L23600174B
Version: TP
FCC ID: E8HMR-0601T
Great! Thank You Very Much
Old 01-08-2009   #2 (permalink)
Andrew Murray
Re: Wireless Mouse not functioning
Is this a laptop or PC? Can you provide full specs of the machine -
including Make and Model, also provide the operating system you're using.
Is this mouse a "generic" mouse or "branded" the same as the PC make (e.g.
Acer/Dell/HP) or is it a brand such as Microsoft or Logitech?
Generally a wireless mouse requires a receiver, that plugs into a USB port.
See the product below on www.ht.com.au:
http://www.ht.com.au/keyword/Wireles...ack/detail.hts
You mention a built-in receiver - which I suspect is not actually for the
mouse, but for the Remote control (for Media Centre/TV) and another
receiver/transmitter that enables your wireless internet (if you use that).
"Mike92" <guest@xxxxxx-email.com> wrote in message
news:2b6f03085eeb5cff124d838e7b4c7bea@xxxxxx-gateway.com...
> Model No. MR-0601T
> Version: TP
> FCC ID: E8HMR-0601T
> Mike92
> If you enjoy what you do, you'll never work another day in your life.
> -Master Kung
Old 01-09-2009   #3 (permalink)
Computer Model: GM5664
Computer Manufacturer: Gateway
OS Name: Microsoft® Windows Vista™ Home Premium |C:\Windows|\Device\Harddisk0\Partition2
OS Version: 6.0.6001
System Type: X86-based PC
Total Physical Memory: 3070 MB
Windows Directory: C:\Windows
BIOS Version: )Phoenix - Award WorkstationBIOS v6.00PG
CPU: AMD Phenom(tm) 9600 Quad-Core Processor
Video Card: ATI Radeon HD 2400 XT
Resolution: 1680 x 1050 x 4294967296 colors
That sufficient? Thank you, you probably could not view my specs because you are a guest, I apologize. Thank you for any advice you can give.
Quote  Quote: Originally Posted by Andrew Murray View Post
ht.com.au | Logitech V220 Cordless Optical Mouse for Notebooks - Mouse - optical - wireless - RF - USB wireless receiver - black
> Model No. MR-0601T
> Version: TP
> FCC ID: E8HMR-0601T
> Mike92
> -Master Kung
Old 01-09-2009   #4 (permalink)
Ok problem solved, it was soo simple of a task too...just had to press the connect button on the bottom of the mouse and then press the one on the receiver...heh..and that was it!!
Quote  Quote: Originally Posted by Mike92 View Post
Model No. MR-0601T
Version: TP
FCC ID: E8HMR-0601T
Old 01-12-2009   #5 (permalink)
Andrew Murray
I'm using a newsreader, not the web interface.
news:7d7f8922f9781949103b99916b7f2fc7@xxxxxx-gateway.com...
Quote:
> COMPUTER MODEL: GM5664
> COMPUTER MANUFACTURER: GATEWAY
> OS NAME: MICROSOFT® WINDOWS VISTAT HOME PREMIUM
> |C:\WINDOWS|\DEVICE\HARDDISK0\PARTITION2
> OS VERSION: 6.0.6001
> SYSTEM TYPE: X86-BASED PC
> TOTAL PHYSICAL MEMORY: 3070 MB
> WINDOWS DIRECTORY: C:\WINDOWS
> BIOS VERSION: )PHOENIX - AWARD WORKSTATIONBIOS V6.00PG
> CPU: AMD PHENOM(TM) 9600 QUAD-CORE PROCESSOR
> VIDEO CARD: ATI RADEON HD 2400 XT
> RESOLUTION: 1680 X 1050 X 4294967296 COLORS
> give.
>> using.
>> (e.g.
>> port.
>> See the product below on 'www.ht.com.au:' (http://www.ht.com.au:)
>> 'ht.com.au | Logitech V220 Cordless Optical Mouse for Notebooks - Mouse
>> - optical - wireless - RF - USB wireless receiver - black'
>> (http://www.ht.com.au/keyword/Wireles...ack/detail.hts)
>> the
>> that).
>> news:2b6f03085eeb5cff124d838e7b4c7bea@xxxxxx-gateway.com...> > >
>> > the
>> > mouse
>> > can
>> > for)?
>> > receiver
>> > that
>> > > Model No. MR-0601T
>> > > Version: TP
>> > > FCC ID: E8HMR-0601T
>> > > Mike92
>> > > -Master Kung > >
> Mike92
> -Master Kung
Old 04-12-2009   #6 (permalink)
Vista 64
If the wireless mouse is not functioning the best thing we can do is do a power drain on the laptop and select Last Known good configuration, and check the setting of the mouse, It will be functioning.
If it still doesn't work just power off the wireless mouse and keyboard from USB and restart the same,
That's it will be functioning....
Regards,
Sandeep Kumar Seeram
Old 04-12-2009   #7 (permalink)
John Huecksteadt
Thanks, Sandeep. The mouse is functioning, but
1) Rotating the wheel does not scroll content (pages, lines, etc.)
2) One cannot assign "Double-click" to a wheel press
3) One cannot automatically position the cursor the the default button in
new dialog boxes
These are all desired features in the Intellipoint software in question. I
hope this clarifies my post. Thank you. -John
"remoteagents" <guest@xxxxxx-email.com> wrote in message
news:2b7b8ada9e6a6add0ddcfe423c7c4ff9@xxxxxx-gateway.com...
> Regards,
> s'andeep@xxxxxx' (sandeep@xxxxxx)
> remoteagents
Old 04-13-2009   #8 (permalink)
Bogey Man
It sounds like your mouse driver is corrupted.
"John Huecksteadt" <johnh@xxxxxx> wrote in message
news:e6ITd86uJHA.1916@xxxxxx
> in new dialog boxes
>> Regards,
>> remoteagents
wireless mouse Vista hardware & devices
mouse not functioning after upgrade of vista Vista hardware & devices
mouse driver not functioning Vista hardware & devices
Wireless mouse Vista mail
Wireless Mouse Vista security
