| Vista Home Premium x32 | Does this sound like a Graphics card hardware error? Hello everyone, I just want to know if a graphics card is not working, would it prevent me logging into vista? like there isn't enough graphics to boot vista? is this possible? Also would a malfunctioning graphics card cause weird symbols in the BIOS, like weird vertical lines, dollar signs replacing spaces, E's replacing F's, A's replacing N's etc.? Also could a power surge possibly damage the graphics card? in terms of hardware? I am not asking for a fix here; i just want to know if this can happen ![]() Thank you for your time |
| | Re: Does this sound like a Graphics card hardware error? chand wrote: Quote: > Hello everyone, > > I just want to know if a graphics card is not working, would it prevent > me logging into vista? like there isn't enough graphics to boot vista? > is this possible? > Also would a malfunctioning graphics card cause weird symbols in the > BIOS, like weird vertical lines, dollar signs replacing spaces, E's > replacing F's, A's replacing N's etc.? > Also could a power surge possibly damage the graphics card? in terms of > hardware? > I am not asking for a fix here; i just want to know if this can > happen ![]() > > Thank you for your time > > for sure is to try another graphics card and see what happens. There are other hardware problems that could cause these symptoms as well. I'd suggest you take the system in to a computer shop for diagnosis and repair, or return to manufacturer if still under warranty. There is no easy answer to diagnosing over the internet the symptoms you describe. |
| | Re: Does this sound like a Graphics card hardware error? A pwr surge could have damaged all most any of your hardware eg motherboard "chand" <guest@xxxxxx-email.com> wrote in message news:5be6de705f9732b68f472756d17397a0@xxxxxx-gateway.com... Quote: > > Hello everyone, > > I just want to know if a graphics card is not working, would it prevent > me logging into vista? like there isn't enough graphics to boot vista? > is this possible? > Also would a malfunctioning graphics card cause weird symbols in the > BIOS, like weird vertical lines, dollar signs replacing spaces, E's > replacing F's, A's replacing N's etc.? > Also could a power surge possibly damage the graphics card? in terms of > hardware? > I am not asking for a fix here; i just want to know if this can > happen ![]() > > Thank you for your time > > > -- > chand |
| Vista Home Premium x32 | Re: Does this sound like a Graphics card hardware error? Thank you for all your replies. I will be sending my computer for warranty in a few days. |
| | Re: Does this sound like a Graphics card hardware error? On Jan 18, 8:21*am, chand <gu...@xxxxxx-email.com> wrote: Quote: > Thank you for all your replies. I will be sending mycomputerfor > warranty in a few days. classic of a bad memory chip on the video controller. If true, then heating that controller with a hair dryer on high will make the problem even more obvious. Of cause, if a computer manufacturer is responsible, then comprehensive hardware diagnostics could be executed to make this failure obvious. No doubt what needs repair. A perfect example of why responsible computer manufacturers routinely provide these diagnostics. |
| Sound Stopped Working After ATI Radeon 3870 HD graphics card was installed | Sound & Audio | |||
| Does this sound like a graphics card error? | Graphic cards | |||
| installed new graphics card sound has gone!!! plz help :S | Sound & Audio | |||
| no sound after i got a new graphics card. | Vista hardware & devices | |||
| Graphics Card Error. | Vista hardware & devices | |||
