| | USB HDD Volume is RAW?? I have an external hdd in a caddie that is showing up in Vista RC1 as having a RAW volume yet when I remove it and place it on a XP SP2 PC it's an NTFS volume and my data is accessible. I just started messing with Vista, anyone know of this happening? |
| | Re: USB HDD Volume is RAW?? It's possible the particular enclosure is causing the problem. The first USB enclosures I tried would not permit me to format the hard drive in the enclosure. I sent them back for a different brand and they work perfectly. I just tried mine on both Vista x86 & x64 and it works fine. The drive is recognized as NTFS formatted and I can access the files. I also change the drive letter to "U" as I have in in XP & XPx64. Matt wrote: > I have an external hdd in a caddie that is showing up in Vista RC1 as having > a RAW volume yet when I remove it and place it on a XP SP2 PC it's an NTFS > volume and my data is accessible. I just started messing with Vista, anyone > know of this happening? |
| | Re: USB HDD Volume is RAW?? Thanks, I suppose it's no big deal. I simply transferred the files to another external that worked. "Theo" wrote: > It's possible the particular enclosure is > causing the problem. The first USB enclosures I > tried would not permit me to format the hard > drive in the enclosure. I sent them back for a > different brand and they work perfectly. > > I just tried mine on both Vista x86 & x64 and it > works fine. The drive is recognized as NTFS > formatted and I can access the files. I also > change the drive letter to "U" as I have in in > XP & XPx64. > > > Matt wrote: > > I have an external hdd in a caddie that is showing up in Vista RC1 as having > > a RAW volume yet when I remove it and place it on a XP SP2 PC it's an NTFS > > volume and my data is accessible. I just started messing with Vista, anyone > > know of this happening? > |
| pc volume | Vista music pictures video | |||
| Volume ID | Vista hardware & devices | |||
| Volume | Vista General | |||
| Red X on Volume Icon and Volume Mixer has disappeared | Vista General | |||
| Volume Help | Vista music pictures video | |||
