| | "Base system device" snag I have an HP DV2020ca Turion 1.6, 2gb RAM, etc etc. Everything works fine (never even had the dreaded audio bug) except for my built-in mic and headphone/spdif/mic ports. As far as I know, it uses the conexant audio system people seem to be having all kinds of problems with. Just wondering if anyone else has a similar laptop with the same problem, and if they've found a solution. |
| error code 39 on all device type: "Modems" & "Ports (COM & LPT)" | Vista hardware & devices | |||
| "Device Manager" link under Tasks in System not working | Vista General | |||
| Error: "Cannot convert "System.Object[]" to "System.Int32"." | PowerShell | |||
| "A device attached to the system is not functioning" error when trying to backup credentials | Vista General | |||
| "Base system device" snag | Vista hardware & devices | |||
