Vista - USB mouse via PS2 KVM works when 2nd USM mouse plugged in
Old 01-19-2009   #1 (permalink)
Vista Ultimate x64 SP1
Odd behaviour. IOGear PS2 KVM 2-port built in cables.
USB MS optical wheel mouse using its included USB->PS2 adapter.
With Vista x32 Business with SP1, I have no issues. The setup works as expected.
But with Vista x64 Ultimate with SP1, the mouse via the KVM mouse only works if I have a 2nd USB mouse plugged directly into the PC while Vista boots up. After it's booted, I can unplug the extra mouse and the PS2 KVM mouse will keep working. BUT if the USB mouse is not connected when I boot Vista, then the PS2 KVM mouse does not work.
Fresh install of Vista Ultimate x64 with SP1 and all windows updates. I want to solve this before I start adding my software.
As of right now, I only know of 3 possible solutions.
1. Leave a spare USB mouse plugged into Vista x64 all the time and wrap it up behind the PC. Lame, but that's what I am doing right now.
2. Buy a USB based KVM. I really don't want to spend the money on that since option 1 above is working at no extra cost to me.
3. Buy a different PS2 based KVM to test with. Again, don't want to spend the money.
Also, seems silly to buy another KVM when the one I have works fine with x32 Vista and only has this oddity with x64 Vista, yet it does work in x64 Vista with the spare USB mouse plugged in at boot up and can be removed after bootup. So it seems there should be a software solution to solve the issue.
vista freezes only mouse works Vista General
MS Wired Optical Mouse only Works Sometime Vista General
Vista Freezing but Mouse Works. General Discussion
Touchpad not working, usb mouse does, touchpad never works even w/o usb mouse Drivers
mouse pointer is hidden in ms works and msn Vista General
