| | Dell Inspiron 530 - Networking problem Hi, I have been asked to look at a problem with a computer at our local social club. It's a Dell Inspiron 530. It was not showing anything to do with Networking in the device manager so I went to the BIOS and enabled the network. When I restarted Vista this time the network device was showing in the device manager but that there were no drivers installed for it. If I can manage to locate the Vista installation CD would that help me to get it working? If I cannot locate the original CD would it be okay to use my own CD instead? Thank you very much for any replies! Jim |
| | Re: Dell Inspiron 530 - Networking problem If the system does have dial up support then I suggest that you run Win Update it will probably install the driver for you. Or go the Dell website from another system and see if you can download the driver and copy it to CD and then install it in the target system. "Jim Robin" <jim.robin@xxxxxx> wrote in message news:eydaWa2kJHA.1248@xxxxxx Quote: > Hi, > > I have been asked to look at a problem with a computer at our local social > club. It's a Dell Inspiron 530. It was not showing anything to do with > Networking in the device manager so I went to the BIOS and enabled the > network. > > When I restarted Vista this time the network device was showing in the > device manager but that there were no drivers installed for it. If I can > manage to locate the Vista installation CD would that help me to get it > working? If I cannot locate the original CD would it be okay to use my > own CD instead? > > Thank you very much for any replies! > > Jim > |
| | Re: Dell Inspiron 530 - Networking problem Thanks very much! I think I can plug in a wireless USB device to get on the Internet as the club has wireless Internet. I shall try windows update. Good suggestion and very prompt - thanks again! Jim "Curious" <mailmenot@xxxxxx> wrote in message news:u8%23e0f2kJHA.1928@xxxxxx Quote: > > If the system does have dial up support then I suggest that you run Win > Update it will probably install the driver for you. > Or go the Dell website from another system and see if you can download the > driver and copy it to CD and then install it in the target system. > > "Jim Robin" <jim.robin@xxxxxx> wrote in message > news:eydaWa2kJHA.1248@xxxxxx Quote: >> Hi, >> >> I have been asked to look at a problem with a computer at our local >> social club. It's a Dell Inspiron 530. It was not showing anything to >> do with Networking in the device manager so I went to the BIOS and >> enabled the network. >> >> When I restarted Vista this time the network device was showing in the >> device manager but that there were no drivers installed for it. If I can >> manage to locate the Vista installation CD would that help me to get it >> working? If I cannot locate the original CD would it be okay to use my >> own CD instead? >> >> Thank you very much for any replies! >> >> Jim >> |
| | Re: Dell Inspiron 530 - Networking problem Personnally I would'nt reccommend MS update for a driver, since its a Dell obtain the driver from Dell, that way you'll get the correct one "Jim Robin" <jim.robin@xxxxxx> wrote in message news:OtWJXk2kJHA.1928@xxxxxx Quote: > Thanks very much! > > I think I can plug in a wireless USB device to get on the Internet as the > club has wireless Internet. I shall try windows update. Good suggestion > and very prompt - thanks again! > > Jim > > "Curious" <mailmenot@xxxxxx> wrote in message > news:u8%23e0f2kJHA.1928@xxxxxx Quote: >> >> If the system does have dial up support then I suggest that you run Win >> Update it will probably install the driver for you. >> Or go the Dell website from another system and see if you can download >> the driver and copy it to CD and then install it in the target system. >> >> "Jim Robin" <jim.robin@xxxxxx> wrote in message >> news:eydaWa2kJHA.1248@xxxxxx Quote: >>> Hi, >>> >>> I have been asked to look at a problem with a computer at our local >>> social club. It's a Dell Inspiron 530. It was not showing anything to >>> do with Networking in the device manager so I went to the BIOS and >>> enabled the network. >>> >>> When I restarted Vista this time the network device was showing in the >>> device manager but that there were no drivers installed for it. If I >>> can manage to locate the Vista installation CD would that help me to get >>> it working? If I cannot locate the original CD would it be okay to use >>> my own CD instead? >>> >>> Thank you very much for any replies! >>> >>> Jim >>> > |
| | Re: Dell Inspiron 530 - Networking problem Thanks DL - will check that out too. Jim "DL" <address@xxxxxx> wrote in message news:uHfybl6kJHA.1388@xxxxxx Quote: > Personnally I would'nt reccommend MS update for a driver, since its a Dell > obtain the driver from Dell, that way you'll get the correct one > > "Jim Robin" <jim.robin@xxxxxx> wrote in message > news:OtWJXk2kJHA.1928@xxxxxx Quote: >> Thanks very much! >> >> I think I can plug in a wireless USB device to get on the Internet as the >> club has wireless Internet. I shall try windows update. Good suggestion >> and very prompt - thanks again! >> >> Jim >> >> "Curious" <mailmenot@xxxxxx> wrote in message >> news:u8%23e0f2kJHA.1928@xxxxxx Quote: >>> >>> If the system does have dial up support then I suggest that you run Win >>> Update it will probably install the driver for you. >>> Or go the Dell website from another system and see if you can download >>> the driver and copy it to CD and then install it in the target system. >>> >>> "Jim Robin" <jim.robin@xxxxxx> wrote in message >>> news:eydaWa2kJHA.1248@xxxxxx >>>> Hi, >>>> >>>> I have been asked to look at a problem with a computer at our local >>>> social club. It's a Dell Inspiron 530. It was not showing anything to >>>> do with Networking in the device manager so I went to the BIOS and >>>> enabled the network. >>>> >>>> When I restarted Vista this time the network device was showing in the >>>> device manager but that there were no drivers installed for it. If I >>>> can manage to locate the Vista installation CD would that help me to >>>> get it working? If I cannot locate the original CD would it be okay to >>>> use my own CD instead? >>>> >>>> Thank you very much for any replies! >>>> >>>> Jim >>>> >> > |
| Dell Inspiron 530, problem with Nvidia.... | General Discussion | |||
| Dell Inspiron 1420 display problem | Vista hardware & devices | |||
| Re: Problem with dell inspiron laptop | Vista General | |||
| Dell Inspiron 1720 Vista Wireless Problem | Vista networking & sharing | |||
| Dell Inspiron - problem with Roxio | Vista General | |||
