Warning: Long post- Help with connecting an external hard drive please?
  1. #1
    Newbie
    Seattle
    Vista Home Premium 64bit
    Local Time: 10:13 AM
    I will make this as short as I can but I don’t even know where to start… I purchased a Fantom Drives 1 TB GreenDrive and connected it to my laptop (HP Pavilion dv7 notebook with Vista 64) using an eSATA cable because it supposedly makes a major difference in transfer speeds. The drive is no faster than with a USB cable, so I googled to find info about slow eSATA transfers and read through a LOT of posts on different forums & now I’m more confused than ever! I found that I needed to format the drive to NTFS, so I did. I read that I need to create partitions (or that creating them will make things run faster) but I really don’t know how to do that or why. THEN I read to use HD Tune to check the speed of the drive which tested at a maximum of 79 MB/sec. So I looked for more info on making it faster. Then I looked at my device manager and the hard drive isn’t even listed on there. I have another external hard drive (a smaller one that’s a FAT32 that I am returning) connected up with a USB cable and that is listed but not the new one. The new one shows up when I open My Computer to save files but it’s not in the device manager or the computer manager. Now I see all this stuff about checking BIOS & making sure all the settings are correct for eSATA on my laptop, which I know nothing about. So like I said, I don’t even know where to start with my questions. I just want to know in layman’s terms (is there such a thing? Where I don’t have to go from one Wikipedia definition to 15 more) how to connect the external hard drive to my laptop via eSATA and have it operate at the 300 MB/sec that it’s supposed to. I also want to make sure it’s formatted and set up to get the best/safest performance as well, though. Sorry for the book but my head is seriously spinning and I don’t know what to do. Is there a forum for dummies like me to get simple information about these things? God I hope so……
    PLEASE HELP!?
  2. #2
    Hula Baloo Guest
    Re: Warning: Long post- Help with connecting an external hard driveplease?
    > God I hope so……
    > PLEASE HELP!?
    There's a lot of marketing hype out there about TRANSFER RATES.
    However the thing that most of the time limits disk access speed is arm
    movement and rotational delay. Only after these two things have taken
    place with the actual data transfer take place. The limited exception
    to this is when the data is in the relatively small cache. A 16 meg
    cache might sound big to some, but compared to a TERABYTE, it's a drop
    in the bucket, so in most cases you're stuck with seek time and
    rotational delay being the critical factors. And when these two things
    have gotten you to the right spot on the disk, you've still got to
    transfer the data into memory, which again is limited by the rotational
    speed of the disk (usually 7200 RPM). So yes the TRANSFER RATE with
    eSATA can be faster than USB, but the disk doesn't spin any faster
    regardless, nor does the access arm (seeking) move any faster.
    Now regarding NTFS, once you get above about 8 gig, using FAT32
    becomes incredibly ineffecient, wasting more and more space because
    "cluster" size increases until it can waste a ton of disk space to store
    small amounts of stuff.
    Finally partitioning. It does NOT speed things up. In fact if you
    frequently access stuff across multiple partitions, you've got to move
    the access arm further, slowing everything down. The main advantage to
    partitioning is separation of things like software and data. This is
    particularly convenient for things like backup/restore and reorgs. If
    you keep all your software on C: and your data on say E:, then you can
    backup your C: and reorg it relatively infrequently, since it doesn't
    change as fast as your data. And when you back up or reorg your data,
    you don't have to do it to your C: partition. It's very convenient, and
    the backups and reorgs go faster (a tradeoff with the increased seek
    time if you have to move between C: and E: frequently).
    Clear as mud? Welcome to disk management! :-)
  3. #3
    Newbie
    Seattle
      Thread Starter
    Re: Warning: Long post- Help with connecting an external hard drive please?
    Wow! thanks for the quick, precise and most importantly SIMPLE answer, Hula! Can you also tell me if I need to change any settings in my BIOS or anywhere else in my computer in order to use the eSATA drive? Also, it's not showing up on my device manager. I can open it when I go to computer in order to save files but it's not showing up other than that.... Any idea why that is? Thanks again!
  4. #4
    Hula Baloo Guest
    I must confess to not having gotten around to trying eSATA. I've got
    at least 2 external drives that would work with it, but I don't have a
    PC with an eSATA port; and since I'm not convinced it would be any
    faster than USB, I haven't bothered with it. I will say that external
    devices can be quirky in whether and how they show up in Device Manager.
    Re BIOS settings, run SETUP and look to see if there's anything about
    enabling/disabling eSATA. If there is, of course you'd want to make
    sure it's ENABLED. It's hard to generalize about that because there're
    so many different versions of BIOS setups.
    Good luck!
  5. #5
    David Guest
    "Hula Baloo" <eepyeep@xxxxxx> wrote in message
    news:uEzAdlJlJHA.6124@xxxxxx
    >> SIMPLE answer,
    >> settings in my BIOS
    >> drive? Also,
    >> when I go to
    >> other than
    > eSATA. I've got at least 2 external drives that would
    > work with it, but I don't have a PC with an eSATA port;
    > and since I'm not convinced it would be any faster than
    > Device Manager.
    > anything about enabling/disabling eSATA. If there is, of
    > course you'd want to make sure it's ENABLED. It's hard to
    > generalize about that because there're so many different
    > Good luck!
    I can relate my experience with external SATA drives. There
    are two standards, IDE mode and AHCI mode (ignoring RAID).
    The latter is hot pluggable and the former is not. You must
    boot the computer with the drive attached and turned on if
    using IDE mode. If you installed VISTA with an internal SATA
    drive without AHCI enabled in the bios and enable it later,
    VISTA will not boot without making a registry change first
    to allow it to load the AHCI driver during boot up.
    My external drive has SATA, USB, and IEEE 1934 ports on it
    and after getting AHCI working, it is well worth it. The
    transfer rate is 2-3 times faster than with either of the
    other interfaces. I image my internal hard drives onto the
    external drive and the speed increase is remarkable.
    David
  6. #6
    Newbie
    Seattle
      Thread Starter
    Hey David, the faster speed you are talking about sounds great but like I said, I have NO idea what you were talking about with the whole IDE - ACHI stuff....
  7. #7
    David Guest
    "jezterking" <guest@xxxxxx-email.com> wrote in message
    news:3c46b679bda8beaaea057a6fff73fed7@xxxxxx-gateway.com...
    > great but like
    > the whole IDE -
    > ACHI stuff....
    > jezterking
    I agree that understanding the various SATA interfaces takes
    a bit of research to fully comprehend. Unless you are doing
    huge multi-GB transfers such as I do with backups or using
    it for video editing, your simplest approach would be to
    stay with USB for your external drive. The advantages of a
    SATA connection to an external drive become worthwhile when
    a lot of data transfer is involved. What is your application
    for the external drive?
    David
Warning: Long post- Help with connecting an external hard drive please? problems?
Vista Blue Screen on connecting External Hard Drive vjnag81 Drivers 1 24 May 2009
hard drive failing warning lost896 General Discussion 9 01 Dec 2008
seagate freeagent external hard drive just stopped connecting Brian Thomas Vista General 4 12 May 2008
Long Goodbye & Magically Vanishing Hard Drive Robert Robinson Vista General 8 22 May 2007
Converting my external USB FAT external hard drive to NFTS ladymsvee Vista hardware & devices 2 22 Feb 2007
