| | Partition Problems - I think my Vista Partition is hosed Environment AMD 64 2.8g FX Dual ASUS M2N-E- SLI 4 GIG RAM HD1 (SATA) Western Dig. Raptor - 140 gig. 2 other HDs on pATA Dual Boot on the same HD1: Vista SP1 - HD1 (rougly 95 gig) XP SP2 - HD1 (roughly 38gig ) Unallocated (6 Gig) Partition Master v3.02 A lot of this is from memory as I can’t see my Vista OS Partition any more. It’s a dual boot environment; I was trying to gain space in my Vista drive and shrink my Rarely used XP partition. I used the ‘built in’ Vista partitioning to "shrink" my 45gig XP installation on HD1. That was successful. I then was left with 6 gig 'unallocated' that I was not able to recover using Vista's partitioning tools (ie enlarge Vista was greyed out). I then used EASUS Partition Master on my Vista partition to increase Vista’s partition using the available 6 gigs of unallocated space. Partition Master rebooted & a DOS like status screen came up and the process began- it was slow - so I left it. Several hours later, I came back and the computer was completely off. I booted the computer, and literally, nothing happened (monitor was in “no signal” state). However, after booting, the disk light was constantly on – which I found odd since the computer had been completely off but still had no signal to the monitor. I left it like this for a while and after another ½ hour, I rebooted. Now, when I am offered the standard “Windows Boot Manager” and choose “MS Windows Vista” I receive a “Windows failed to start. A recent hw or sw change might be the cause – to fix: 1) Insert CD 2) choose Languge 3) click repair. File: \Windows\system32\winload.exe Status: 0xc0000225 Info: the selected entry could not be loaded b/c the app is missing or corrupt. I am able to choose and get into my XP install. When I go into XP, and select the drive Vista was on, I get a “Disk is not formatted – do you want to format it?” Meanwhile, back at the Vista DVD recovery (Windows RE) – when I choose “Startup Repair” and run diagnostics/repair, I get a “Root Cause Found: The partition table does not have valid system partition. Repair Action: Partition Table repair Result: Completed successfully. Error Code 0x0 Time taken = 4976 ms So it should be all good, right? NO…..same error as above: “Windows failed to start File: \Windows\system32\winload.exe Status: 0xc0000225 Info: the selected entry could not be loaded b/c the app is missing or corrupt. I’ve run this on the recovery console like 5 times already and each time, it reports a successful Partition Table repair. Finally, I tried the following with Vista Boot DVD: bootrec /fixmbr bootrec /fixboot bootrec /RebuildBcd and results are as follows: test with bootrec /fixmbr = the command has completed successfully test with bootrec /fixboot = element not found tets with bootrec /RebuildBcd = scanning all disks for windows installation. please wait, sine this may take a while... successfult scanned windows installations. total identified windows installations: 0 the operation completed successfully. Same state as beginning (Status: 0xc0000225 error) and boot manager startup screen. While I do have a backup, it will be a painful exercise. One final note - in Computer Mgmt - G:\ drive (where vista lives - shows 95gigs and "Healthy" Any ideas on how I can a) restore Vista b) "browse this area to snag files if "a" doesn't work? MANY Thanks for any insight |
| | Re: Partition Problems - I think my Vista Partition is hosed You have done some nasty things to your Vista partition. Been there, done that. If the partition table had been fixed you should be able to read your vista data when in XP, which I have been fortunate enough to do under similar circumstances recently, however from your post I am not sure you are able to boot into XP at this point either. If you are able to boot into XP there are a number of data recovery programs you can try to see if they can read anything off the Vista partition so you can try to rescue documents, images etc. I doubt it is possible to fix and reboot that Vista installation. Otherwise I think it is time for a reinstall of everything, unless you have a pristine disc image that you know will actually reinstall. I would rethink the dual boot thing and stick to one OS. Which OS you choose is up to you. If XP works for you, and if you have programs that will not work in Vista, there is no compelling reason to use Vista at all. If Vista works for you there is no reason not to use it. If you stop dual booting you will soon not notice how much slower Vista 32 is than XP. If you want to dual boot you may want to get a copy of Vista 64: at least on my quad core uber machine Vista 64 seems a performance match for XP whereas Vista 32 is clearly not. |
| | RE: Partition Problems - I think my Vista Partition is hosed Sorry for the delay as my response may no longer be pertinent It sounds likes this is affecting your system - GUID partition table (GPT) volume on Extensible Firmware Interface (EFI) x64-compatible hardware :Proposed Solution: We cannot guarantee that these problems can be solved. Modify the registry at your own risk. Restart to Windows Recovery, and then run to Command Prompt. Type regedit, and then enter. Locate the following registry key: HKEY_LOCAL_MACHINE\System\MountedDevices Locate the DosDevices drive letter registry values. These values resemble the following value: \DosDevices\C: Locate the drive letter that you want to modify. Right-click the registry value, and then click Rename. Change the name of the registry value to the original correct drive letter. Do not change the value itself. There may be an extra registry entry per drive that is corrupted that you should delete. Note To do this, you must know how the drive letters have been interchanged. Restart the computer. "Captainkwe" wrote: Quote: > Environment > > AMD 64 2.8g FX Dual > ASUS M2N-E- SLI > 4 GIG RAM > HD1 (SATA) Western Dig. Raptor - 140 gig. > 2 other HDs on pATA > > Dual Boot on the same HD1: > Vista SP1 - HD1 (rougly 95 gig) > XP SP2 - HD1 (roughly 38gig ) > Unallocated (6 Gig) > Partition Master v3.02 > > A lot of this is from memory as I can’t see my Vista OS Partition any more. > It’s a dual boot environment; I was trying to gain space in my Vista drive > and shrink my Rarely used XP partition. > > I used the ‘built in’ Vista partitioning to "shrink" my 45gig XP > installation on HD1. That was successful. I then was left with 6 gig > 'unallocated' that I was not able to recover using Vista's partitioning tools > (ie enlarge Vista was greyed out). I then used EASUS Partition Master on my > Vista partition to increase Vista’s partition using the available 6 gigs of > unallocated space. Partition Master rebooted & a DOS like status screen came > up and the process began- it was slow - so I left it. Several hours later, I > came back and the computer was completely off. I booted the computer, and > literally, nothing happened (monitor was in “no signal” state). However, > after booting, the disk light was constantly on – which I found odd since the > computer had been completely off but still had no signal to the monitor. I > left it like this for a while and after another ½ hour, I rebooted. Now, when > I am offered the standard “Windows Boot Manager” and choose “MS Windows > Vista” I receive a “Windows failed to start. A recent hw or sw change might > be the cause – to fix: 1) Insert CD 2) choose Languge 3) click repair. > File: \Windows\system32\winload.exe > Status: 0xc0000225 > Info: the selected entry could not be loaded b/c the app is missing or > corrupt. > > I am able to choose and get into my XP install. When I go into XP, and > select the drive Vista was on, I get a “Disk is not formatted – do you want > to format it?” > > Meanwhile, back at the Vista DVD recovery (Windows RE) – when I choose > “Startup Repair” and run diagnostics/repair, I get a > “Root Cause Found: > The partition table does not have valid system partition. > Repair Action: Partition Table repair > Result: Completed successfully. Error Code 0x0 > Time taken = 4976 ms > > So it should be all good, right? NO…..same error as above: > “Windows failed to start > File: \Windows\system32\winload.exe > Status: 0xc0000225 > Info: the selected entry could not be loaded b/c the app is missing or > corrupt. > > I’ve run this on the recovery console like 5 times already and each time, it > reports a successful Partition Table repair. > > Finally, I tried the following with Vista Boot DVD: > > bootrec /fixmbr > bootrec /fixboot > bootrec /RebuildBcd > > and results are as follows: > > test with bootrec /fixmbr = the command has completed successfully > test with bootrec /fixboot = element not found > tets with bootrec /RebuildBcd = scanning all disks for windows installation. > please wait, sine this may take a while... > successfult scanned windows installations. > total identified windows installations: 0 > > the operation completed successfully. > > Same state as beginning (Status: 0xc0000225 error) and boot manager startup > screen. > > While I do have a backup, it will be a painful exercise. > > One final note - in Computer Mgmt - G:\ drive (where vista lives - shows > 95gigs and "Healthy" > > Any ideas on how I can a) restore Vista b) "browse this area to snag files > if "a" doesn't work? > > MANY Thanks for any insight |
| Vista Partition Tool - will not shrink partition | Vista performance & maintenance | |||
| Moving free space from one extended partition to the Vista partition | Vista General | |||
| Partition Hosed? | Vista General | |||
| Allow GPT Partition for Boot Partition (not System Partition) | Vista installation & setup | |||
| Vista partition preventing XP partition from connecting online | Vista networking & sharing | |||
