Vista - Mobo Front Panel Header Help
Old 04-03-2009   #1 (permalink)
Windows Server 2008, Windows Vista Enterprise, Windows 7 Ultimate (all x64)
I am installing a new Gigabyte mobo (MA78GM-US2H) in an HP Media Center Case. The pin layout between the case & mobo is nearly the same except that the HD LED and the Power LED are reversed on the new mobo. The power switch pins are correct. The case does not have reset capability.
Does it matter that the two LED pin connectors are reversed or should I attempt to change the wires coming from the case?
Old 04-03-2009   #2 (permalink)
Bob Knowlden
Re: Mobo Front Panel Header Help
I'm unfamiliar with HP Media Center cases, but I guess from what you say
that the front panel connector is a one piece block, rather than the set of
two or three pin connectors common in third-party cases.
If it was my system, I'd be tempted to rewire the connector so that the LEDs
would function normally with a new mainboard. (Are the polarities correct as
well?)
I hope that those are the only HP-proprietary features of the case. I have
unpleasant memories of Dell Dimension PCs from the 1990s: they had enough
proprietary features to make a motherboard swap more trouble than would be
worth it to most people.
"merkat106" <guest@xxxxxx-email.com> wrote in message
news:0cbb6868c9433024267ba1bf79f2efab@xxxxxx-gateway.com...
> merkat106
> Mer Hathaway,
> A+ Certified &
> Former in-store Circuit City firedog PC tech
Old 04-03-2009   #3 (permalink)
Pretty sure that the front connector is the only proprietary feature. I was given only the HP case, the old mobo and hard drive. The unit was thouroughly cannalbalized. All the 3rd party components I had originally bought for it worked.
I'll try rewiring the connector
P5N-D Front Panel not working on Vista Ult.64 Sound & Audio
front audio panel issues Sound & Audio
front SPDIF out header only work when back is in use Sound & Audio
front panel video inputs Vista music pictures video
Front Panel Audio Sound & Audio
