| | usb 2.0 wifi (wlan) driver My planex usb 54mini (wifi) cannot work under the vista environment, I cannot install the original XP driver and the error message said the usb 2.0 wlan driver does not work , can anyone tell me where to find the proper usb 2.0 wlan driver in the vista environment |
| | Re: usb 2.0 wifi (wlan) driver You will probably have to wait until Planex makes one available. Have you contacted Planex about a Vista driver for it? kwan0381 wrote: > My planex usb 54mini (wifi) cannot work under the vista environment, I cannot > install the original XP driver and the error message said the usb 2.0 wlan > driver does not work , can anyone tell me where to find the proper usb 2.0 > wlan driver in the vista environment |
| WIFI driver re-set problem | Vista hardware & devices | |||
| Nc8000 WLAN driver | Vista hardware & devices | |||
| Nc6000 WLAN driver Solution!!! | Vista hardware & devices | |||
| WLAN Driver Acer Centrino C302 | Vista networking & sharing | |||
