| | Re: Installed Acronis True Image Home 2009 & Card Reader would notinatall - Code 10 "unable to load device driver" -Solution trtlservices@xxxxxx wrote: Quote: > If your Card Readers will not install (code 10, "working" but "unable > to load drivers" and you installed Acronis True Image Home 2009, True > Image may be the problem. > > Purchased and download Acronis True Image Home 2009 on 2/19/2009. > Installed. (Acronis did not provide the latest version).) > > Spent hours, actually I mean days, trying to discover why my card > reader devices disappeared. > > Only after a careful, painful rebuild of my system that a known > problem in some versions of Acronis True Image Home 2009 was causing > the problem. > > If you are experiencing this problem, uninstall True Image. If the > card readesr appear, you may wish to update Acronis True Image Home > 2009 and share your experience with Acronis: info@xxxxxx > > Acronis True Image Home v. 12.0.9608 caused the problem.Version > 12.0.9709 does not cause the problem but installs very slowly and > starts slowly. > > I think that Acronis True Image Home was (is?) a good product but > version 2009 Home (under MS Vista) does not encouage me to recommend > a purchase or an upgrade. > > Hope this helps those like me that are very unhappy with Acronis > communications. > > Substantive feedback from Acronis is welcomed. version of acronis, had it on my computer for a couple of weeks, put the box (containing the CD) in the trash. There are folks in these NG's that are members of a cult that worship acronis. Need to take care that they don't sneak up behind you. |
| Acronis True Image Home 2009 Unable to backup | Software | |||
| Acronis True Image Home 11 | Software | |||
| Acronis True Image Home 2009 | Vista General | |||
| Acronis True Image Home | Vista General | |||
| Acronis True Image Home - v10 | Vista file management | |||
