| | Help choosing Video Card Hey guys, I was wondering if someone can recommend a decent video card to upgrade to. I am not a gamer nor do graphic design so when i bought my pc 2 years ago i went with a cheap card, works fine for me but obviously it won't do the trick for Vista as far as Aero goes. I have a GForce4 I guess must be a pretty old one cos obvoiusly Vista doesn't like it too much. I'm just looking form something that will be good enough to run Vista comfortably. Again since I dont play games or do any graphic work in my PC, i am not loking for a high end card. Any suggestions are apppreciated... |
| | RE: Help choosing Video Card Hi I would also like help if possible on selecting a video card so i will be able to use the new vista. Current system dell dimension 2350 1 gb of memory what video card can i replace the existing card with i think the current card is a intergated intel extreme 3d graphics also what size of screen should i upgrade to to make it all work if not possible with this system i now have what lap top would be a good buy so i can keep this desktop . Thanks Any suggestions are apppreciated Jessie a flower "pbateman" wrote: > Hey guys, I was wondering if someone can recommend a decent video card to > upgrade to. I am not a gamer nor do graphic design so when i bought my pc 2 > years ago i went with a cheap card, works fine for me but obviously it won't > do the trick for Vista as far as Aero goes. I have a GForce4 I guess must be > a pretty old one cos obvoiusly Vista doesn't like it too much. I'm just > looking form something that will be good enough to run Vista comfortably. > Again since I dont play games or do any graphic work in my PC, i am not > loking for a high end card. Any suggestions are apppreciated... |
| | Re: Help choosing Video Card I installed an ASUS EAX1600PRO with 512MB (on the advice of a sales guy at my local systems builder). I wanted something that works well with Vista, and is good for video editing (Movie Maker, DVD Maker). The fan is a little noisy, but the price was right ($140), and it works really well. On RC1 I used the ATI Catalyst drivers; on RC2 I'm using the MS supplied drivers. |
| Choosing new graphics card | Graphic cards | |||
| Need Help Choosing New Graphics Card | Graphic cards | |||
| What two-head video card can play a HD video on a secondary monito | Vista General | |||
| Need video drivers for Intel 810/810e/815/815e series video card | Vista hardware & devices | |||
| Nforce 430, onboard sound card and video card issues | Vista hardware & devices | |||
