Vista - problems with external display
Old 05-17-2009   #1 (permalink)
Vista Home Premium x64
I have a brand-new LG 32" 1080p LCD TV, and a Dell laptop with Windows x64 Home Premium. My laptop has an HDMI out port, and I just got an HDMI cable today, so I figured hey why not let's hook the computer up to the TV. It does work, but when I set it to display only on the TV, the image is stretched out as though it is too big for the screen. The display settings on the laptop are set to 1920x1080, so I dont understand why it is stretching like this. Any help would be greatly appreciated.
Old 05-17-2009   #2 (permalink)
Richard Urban
Re: problems with external display
Your video output must be set to the resolution of your TV set. It is not
the same as your built in monitor. Check your TV specs for the information -
you know, the instruction book that came with!
Richard Urban
Microsoft MVP
Windows Desktop Experience
"shadowxclone" <guest@xxxxxx-email.com> wrote in message
news:2b26ddaad670b26d1a02d15763442e21@xxxxxx-gateway.com...
> appreciated.
> shadowxclone
Old 05-17-2009   #3 (permalink)
Curious
Your TV is probably over scanning all input over HDMI which is very common
with HDTVs so that they emulate traditional CRT TVs.
Check to see if your TV has a picture size setting of dot-to-dot or 1-to-1
to emulate this overscan.
> appreciated.
> shadowxclone
Old 05-18-2009   #4 (permalink)
The TV is 1080p, so the resolution should be 1920x1080. And I couldn't find anything about dot-to-dot or 1-to-1 in the settings anywhere...
Old 05-18-2009   #5 (permalink)
Curious
If you have the 32LH40 see the instructions for the Picture wizard on page
70 of your user's manual and select Just Scan
http://www.lge.com/us/tv-audio-video...tv-32LH40.jsp#
news:23eac22699101c06d0459447449f591c@xxxxxx-gateway.com...
Quote:
> The TV is 1080p, so the resolution -should- be 1920x1080. And I
> anywhere...
> shadowxclone
Old 05-18-2009   #6 (permalink)
Bill Kearney
Try reading the threads on www.avsforum.com
Search for your specific LG model number, or nearest similar model.
Not all HDMI devices interact properly. They're "supposed to" but they
often don't. Combine that with how some video chipsets do a bad job of
adjusting their output resolution and, well, you may be in for bad news.
Old 05-19-2009   #7 (permalink)
I actually have the 32LG70, but the "Just Scan" option worked perfectly, my Xbox 360 and laptop both now display perfectly on my screen. Thanks for all the assistance guys
Old 05-19-2009   #8 (permalink)
Vista Home Premium 32bit.
i need some help. my brother managed to get rid of the viruses on the comp,
as well as clearing a lot of space. it worked fine earlier, but for some
reason, when i logged in earlier there was nothing on the desktop. the only
way i can access anything is by ctrl + alt + del and then using new task.
i've tried restoring it, and tried going into safe mode but i still have the
same problem under safe mode. any help?
Old 05-19-2009   #9 (permalink)
Curious
Have you tried right clicking on your desktop then selecting View and then
making sure that show all icons is selected?
"aparna" <guest@xxxxxx-email.com> wrote in message
news:85ac4180ca20679c094f5b98caa318ce@xxxxxx-gateway.com...
> comp,
> some
> only
> task.
> have the
> aparna
Help connecting external display (TV) Graphic cards
External monitor display Vista hardware & devices
External Display problems Vista hardware & devices
External Display Vista hardware & devices
Problems using external T.V as external second monitor vai S-Video Vista installation & setup
