1.    21 May 2009 #1
    32bit
    Local Time: 07:03
    Burner Problem
    Help! I cannot burn stuff from my burner...i tried burning music, selected the correct format, then it proceeds to windows media player. it doesn't have any problems until it finalizes the cd or dvd although a message appears that burning was completed O.o when i check the cd/dvd there's nothing on there! i have no problems playing music or movies on my dvd-rom...thanks in advance!
  2.    22 May 2009 #2
    THE C. [MSFT MVP] Guest
    RE: Burner Problem
    Try using a different burning software. Look at filehippo.com, do a search
    form there type CDBrunerxp. Download and install. Try to create and burn your
    cd/dvd's again. I think you will like it, and it is really easy to use. Good
    Luck!
    Computer/Software Tech.
    Make it a great day!
    Charles Richmond
    > tyanak
  3.    23 May 2009 #3
    Peter Foldes Guest
    Re: Burner Problem
    You are a fake wanabee MVP. At least give the correct answer which you are not
    capable of . Go away and get a life
    Peter
    Please Reply to Newsgroup for the benefit of others
    Requests for assistance by email can not and will not be acknowledged.
    "THE C. [MSFT MVP]" <THEC.@xxxxxx> wrote in message
    news:C150F7EA-D9C3-4771-8178-D27D675B2EFA@xxxxxx
    > Luck!
    > Charles Richmond
    >> tyanak
  4.    23 May 2009 #4
    Peter Foldes Guest
    Re: Burner Problem
    This can occur when your computer incorrectly detects the drive as a non-recordable
    device.
    Step 1: Back up the registry
    To back up the registry so that you can restore it if you have problems later,
    follow these steps:
    1.. Click Start, and then click Run.
    2.. In the Open box, type regedit, and then click OK.
    3.. Click to open the following folder:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD
    Burning\Drives
    4.. On the File menu, click Export.
    5.. In the File name box, type backup of drives key, note the location where you
    are saving the file, and then click Save.
    Note If you have problems later, you can restore this registry subkey by
    double-clicking the backup of drives key.reg file that you saved.
    Step 2: Edit the drive type value of the volume folder
    To edit the drive type so that Windows recognizes the drive as recordable, follow
    these steps:
    1.. In the navigation pane of the Registry Editor window, click the Volume{GUID}
    folder under Drives, where GUID is a 32-character identifier.
    Note If your computer has more than one CD drive, an additional Volume{GUID}
    folder is listed for each drive.
    2.. In the right side of the Registry Editor window, double-click Drive Type.
    3.. In the Value data box, type 1 if the drive is a CD-R drive or 2 if it is a
    CD-RW drive.
    4.. Click OK, and then close Registry Editor.
    Step 3: Verify that Windows recognizes the drive as a recordable device
    To see whether Windows recognizes the drive as a recordable device now, follow these
    steps:
    1.. Click Start, and then click My Computer.
    2.. Under Devices with Removable Storage, right-click the CD-R drive or CD-RW
    drive, and then click Properties.
    3.. If the Recording tab is displayed, Windows recognizes the drive as a
    recordable device.
    4.. Click Cancel
    Peter
    "tyanak" <guest@xxxxxx-email.com> wrote in message
    news:9406922519b803c78e45f0c65efca40d@xxxxxx-gateway.com...
    > tyanak
  5.    24 May 2009 #5
    LQ Guest
    Re: Burner Problem
    On 5月22日, 上午1时51分, tyanak <gu...@xxxxxx-email.com> wrote:
    > Help! I cannotburnstuff from my burner...i tried burning music,
    > it doesn't have any problems until it finalizes the cd ordvdalthough a
    > mydvd-rom...thanks in advance!
    > tyanak
    Did you hear of the Total Video2Dvd?I think it is your best
    choice.it's safe and works pretty well.It is the most powerful
    conversion tool that it can “Auto Convert and Burn MKV, Blu-ray TS,
    M2TS, AVCHD MTS, HDV1080i, Divx, Rm, Wmv, Avi to DVD Video Disc
    directly.”It is very easy to use, and offer the better quality,.You
    can try it.
    Source(s):
    http://www.google.com/search?hl=en&q...earch&aq=o&oq=
    http://www.effectmatrix.com/total_vi...thor/index.htm
  6.    24 May 2009 #6
    Curious Guest
    Re: Burner Problem
    tyanak,
    Here is a MS link to the problem on XP with recognizing optical drives. It
    appears that Peter has quoted most of it for your problem on Vista even
    though you have no problem recognizing the drives since the writing starts
    but does not complete on Vista. So his advice does not appear to apply to
    your problem and possibly "THE C's" suggestion is a good one.
    http://support.microsoft.com/kb/316529
    Also we do not really know if "The C" is or is not a MVP since MVPs can
    elect that they not be listed in the MVP listing available to the public,
    "Peter Foldes" <okf22@xxxxxx> wrote in message
    news:eTp1lj82JHA.1416@xxxxxx
    > non-recordable device.
    > later, follow these steps:
    > Burning\Drives
    > where you are saving the file, and then click Save.
    > follow these steps:
    > Volume{GUID} folder under Drives, where GUID is a 32-character identifier.
    > Volume{GUID} folder is listed for each drive.
    > Type.
    > is a CD-RW drive.
    > follow these steps:
    > CD-RW drive, and then click Properties.
    > recordable device.
    > 4.. Click Cancel
    > Peter
    >> tyanak
  7.    24 May 2009 #7
    Peter Foldes Guest
    Re: Burner Problem
    Curious
    >Also we do not really know if "The C" is or is not a MVP since MVPs can elect that
    Take it from me and others that ( The C ) he is not an MVP. And oh yes. My advice
    was good since the OP posted the following ( "it doesn't have any problems until it
    finalizes the cd"). The MS KB you posted does not apply since the OP can start the
    burn without issues and go through to the finish but has problems finalizing it.
    Read the post correctly next time out.
    BTW the advice that "The C " gave to use another burner software is not the answer
    here
    Peter
    "Curious" <spammenot@xxxxxx> wrote in message
    news:OF15wqL3JHA.2656@xxxxxx
    > tyanak,
    > appears that Peter has quoted most of it for your problem on Vista even though you
  8.    25 May 2009 #8
    Curious Guest
    Re: Burner Problem
    What I do not understand is how come the burning even started if the cause
    of not being able to finalize is as you posted:
    "This can occur when your computer incorrectly detects the drive as a
    non-recordable
    device.."
    news:efVMwOP3JHA.1096@xxxxxx
    > Curious
    > advice was good since the OP posted the following ( "it doesn't have any
    > problems until it finalizes the cd"). The MS KB you posted does not apply
    > since the OP can start the burn without issues and go through to the
    > finish but has problems finalizing it. Read the post correctly next time
    > out.
    > the answer here
    > Peter
    >> tyanak,
    >> It appears that Peter has quoted most of it for your problem on Vista
    >> even though you have no problem recognizing the drives since the writing
    >> starts
  9.    25 May 2009 #9
    32bit
    Local Time: 07:03
      Thread Starter
    Re: Burner Problem
    Thanks for the suggestions, guys! I did the step 3 of Peter's suggestion and my computer does recognize my dvd-rom as a recording device...I can't say that my dvd-rom is damaged since it still can read any disc I play on it. -_-
Burner problem
Firstly apologies if this is in the wrong section. I have a compaq laptop - only had it a month! & have Vista Premium home edition. Things were...
Sound & Audio
problem with dvd burner
I am having problems with my burner in vista... I was using freeware software (burnaware) to burn dvd's and it was working fine the past 3 weeks......
General Discussion
CD Burner Problem
Hi, I am using an audio editor called WaveLab Essential 6. When I create a CD Montage of songs and try to WRITE to CD, it opens up the WRITE CD...
Software
Problem with Pioneer Dvd burner
My SONY VAIO VGN-Cr290 Laptop has a PIONEER DVD-RW DVR-K17 ATA. When I am trying to burn a data DVD, burning speed is only 2.3X I am using DVD+R...
Drivers
windows DVD burner problem
It seems like I had a problem that many other did when i upgraded from XP to Vista Home Premium, my DVD burner no longer worked (error code 39). To...
Vista music pictures video
Installing new dvd burner problem?
Hi, I have been running release 5728 now for a few weeks without problem but today have tried to install new dvd burner but Vista will not even...
Vista General
CD Burner problem
Vista 64 My Sony DW-G120A DVD RW drive tries to format CD-R or at least prompts to prepare the drive for burning. The system has installed the...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
