Vista - Laptop dvd-drive grinding noise
Old 05-21-2009   #1 (permalink)
Windows Server 2008, Windows Vista Enterprise, Windows 7 Ultimate (all x64)
One of my HP laptops, HP Pavilion dv9650us, went off warranty about two months ago. I was using the machine to help fix another computer's problem when I noticed that its dvd-drive is making loud grinding noises and is slowing down the computer whenever I would access the drive. I suspect that the drive is about to die.
I am not sure how long the drive has been doing this since the laptop is being used primarily by another family member.
I purchased an extended warranty through Office Depot, but that family member cannot afford for that computer to be sent off for an unknown amount of time so I am actively considering replacing the drive myself.
I am looking at drives on amazon.com and unsure if a 'universal laptop slimline drive' will fit. Are the drives fairly universal between manufactorers? The current drive is an HD-DVD drive so I was hoping to upgrade to a blu-ray drive. Is it possible?
FYI: These kind of internal laptop dvd drives are not available from newegg or even frys. I'd rather not buy directly through hp.
Old 05-22-2009   #2 (permalink)
THE C. [MSFT MVP]
RE: Laptop dvd-drive grinding noise
Do a Google search under "SLIM TYPE BLUERAY DRIVES" will give you alot of
choices! Good Luck.
Computer/Software Tech.
Make it a great day!
Charles Richmond
> merkat106
Old 05-22-2009   #3 (permalink)
Re: Laptop dvd-drive grinding noise
Am I hearing that any slim type drive will fit an HP laptop?
Old 05-22-2009   #4 (permalink)
DL
no
"merkat106" <guest@xxxxxx-email.com> wrote in message
news:313830351c01910b30ddda0c629f75b0@xxxxxx-gateway.com...
> merkat106
Old 05-23-2009   #5 (permalink)
Peter Foldes
Still impersonating as an MS MVP. Go get a life and go away
Peter
Please Reply to Newsgroup for the benefit of others
Requests for assistance by email can not and will not be acknowledged.
"THE C. [MSFT MVP]" <THEC.@xxxxxx> wrote in message
news:FCD77B05-AE8A-4502-B5C8-9390F6B715AF@xxxxxx
> choices! Good Luck.
> Charles Richmond
>> merkat106
Old 05-23-2009   #6 (permalink)
Jake Marley
On Sat, 23 May 2009 13:09:22 -0400, "Peter Foldes" <okf22@xxxxxx>
How much effort would it take for you to just killfile that guy!??
You KNOW your messages aren't doing any good - and they're just plain
annoying.
dvd drive grinding noise General Discussion
Laptop CPU Noise Vista performance & maintenance
Disk Drive grinding away all the time Vista General
Laptop noise Vista hardware & devices
My hard drive is constantly grinding away Vista General
