Vista - VISTA SOUND COMPAQ PRESARIO 2199US build 5600
Old 10-17-2006   #1 (permalink)
matasvytautas
Does anybody have a driver that works? Step by step installation instructions
please...and link to driver that works..realtec vista driver does not
work..neither does hp driver link..help!!!
Old 10-17-2006   #2 (permalink)
OLC Ministries
Re: VISTA SOUND COMPAQ PRESARIO 2199US build 5600
I had a similar proablem with drivers and found that by putting the original
hardware install software in the drive and then let windows search for the
driver on that drive, it found it and installed it. You will likely not be
able to install the hardware the normal way.
"matasvytautas" <matasvytautas@discussions.microsoft.com> wrote in message
news:76B2AF6A-0357-4091-9526-52CAF8F56931@microsoft.com...
> instructions
Vista and Compaq Presario C700 General Discussion
Compaq presario c700 and surround sound Sound & Audio
Desperately need vista sound driver for presario 2199us Sound & Audio
Windows Vista Build 5600 and Ess1869f Sound Vista hardware & devices
no sound on compaq presario v2000 Vista General
