Normally... if you choose a low-consuming power-saving profile... you have
the option to switch off the optical drive (to save battery).
HOWEVER! In XP... when you switched by to a non-saving power-profile, the
optical drive would switch back on immediately.
In Vista, once the optical drive has been put to sleep... there's no waking
it up unless i reboot. Help?!
