How to increase system system performance
  1. #1
    Tae Song Guest
    I thought I would share this with you all, a few little tricks to boost
    Windows performance.
    If you have a spare USB flash drive or you are willing to get a cheap say
    1GB flash drive.
    First we plug in the flash drive.
    Go to Disk Manager and assign it a drive letter, like Z: (this is just to
    get it out of the way and optional)
    Go to Advanced system settings, Evironment variables.
    Change the Temp variable under User to Z:\ (I didn't see any point creating
    folders, but that's optional)
    Change the Temp variable under System variable to Z:\
    This will cut down on I/O traffic to the hard drive. Starting an app like
    Word, would cause the HD to read the program into memory while at the same
    time writing into the drive, temporary files. This causes an I/O queue to
    form and degrade Windows performance. By off loading some of the I/O
    traffic to another storage device, the hard drive read/write head doesn't
    have to move around as much either. All performance gains.
    Another trick I tried was moving Windows Search Index to a flash drive, but
    it won't let me select even a 16GB flash drive. Even though the Index
    doesn't grow beyond 1GB. It's max size seems to be just under 1GB. You can
    move to it to a removable drive, though. I rebuilt the Index on an external
    500GB USB drive. Again, this cuts down I/O traffic to the internal hard
    drive. More performance gain.
    Another idea I tried was creating a pagefile on a 16GB USB flash drive. I
    found out you can only have 4095MB pagefile or just under 25% of total
    capacity. I don't know what the rule of thumb is though, because on the
    internal 1TB hard drive I could create up to the max free space, which was
    about 700,000GB. Not that I needed that much, but just to test. I'm
    actually running with 4GB RAM and no page file, at the moment. Even with
    lots of 100MB picture (scanned documents/photos) open, virtual memory wasn't
    required. I would like to use most of an 8GB flash drive. Possibly use it
    for both temp files and virtual memory.
    I don't know if pagefile is the same thing as running ReadyBoost. I don't
    think it is, but I will have to look into that. I am not using Readyboost,
    since I read it doesn't do much good if you have more than 2GB of RAM.
    Now, if you have a 2nd or 3rd internal hard drive, you can create a pagefile
    on the 2nd drive and search index on the 3rd or index on 2nd and page file
    on 3rd. I highly recommended using a USB drive for temp files. 1-2GB are
    pretty cheap. I don't think you need a larger one unless you are working
    with full length movies, but I don't for certain.
    They do something like this on big database servers, some might refer to as
    "mainframes". The index and database are each on their own storage device.
    The aggregated bandwidth offers even better performance then RAID and the
    best part is you can implement it along side with RAID for insane amount of
    storage I/O performance.
    Anyways, that's it.
    If you need more detailed info on setting this up, leave a little note in
    the newsgroup. If I don't get to it, I'm sure someone else will help you
    out.
  2. #2
    Tae Song Guest
    Re: How to increase system system performance
    "Tae Song" <tae_song@xxxxxx> wrote in message
    news:E4A312C4-33A9-4FD8-8FF7-59C4B4914442@xxxxxx
    > 1GB flash drive.
    > creating folders, but that's optional)
    > but it won't let me select even a 16GB flash drive. Even though the Index
    > can move to it to a removable drive, though. I rebuilt the Index on an
    > external 500GB USB drive. Again, this cuts down I/O traffic to the
    > internal hard drive. More performance gain.
    > wasn't required. I would like to use most of an 8GB flash drive.
    > Possibly use it for both temp files and virtual memory.
    > Readyboost, since I read it doesn't do much good if you have more than 2GB
    > of RAM.
    > pagefile on the 2nd drive and search index on the 3rd or index on 2nd and
    > page file on 3rd. I highly recommended using a USB drive for temp files.
    > 1-2GB are pretty cheap. I don't think you need a larger one unless you
    > are working with full length movies, but I don't for certain.
    > as "mainframes". The index and database are each on their own storage
    > device. The aggregated bandwidth offers even better performance then RAID
    > and the best part is you can implement it along side with RAID for insane
    > amount of storage I/O performance.
    > Anyways, that's it.
    > out.
    I forgot to mention, putting pagefile on USB flash drive doesn't work. I
    think Windows tries to create it during boot, but USB drivers don't get
    loaded so it can't access the flash drive to create it. (Probably why you
    can't boot in to Windows from USB drives, I even tried enabling BIOS support
    for USB drive which works for booting Linux). When I got into Windows and
    checked, the pagefile never got created. But if you have another internal
    hard drive or maybe even eSATA (in non-ACHI/RAID mode) you can create a
    pagefile there.
    Done. I think.
  3. #3
    Bill in Co. Guest
    > 1GB flash drive.
    > creating
    I don't think so!! There will be a performance LOSS, in large part due to
    the much longer write times to a flash drive. Also, it's generally a poor
    idea to have so many continuous writes to a flash drive, as flash drives
    have a more limited number of write cycles.
    <snip> rest of this post
  4. #4
    Pegasus [MVP] Guest
    Seeing that flash drives are much slower than hard disks, I wonder if your
    measures have the desired effect. Could we have some performance figures,
    complete with the test methods you applied so that anyone can perform the
    same tests on his machine?
  5. #5
    Jerry Guest
    Why not just create and RAMDRIVE and use it for the TMP/TEMP variables?
    > 1GB flash drive.
    > of RAM.
    > Anyways, that's it.
    > out.
  6. #6
    Tae Song Guest
    "Pegasus [MVP]" <news@xxxxxx> wrote in message
    news:O8a9Ndg6JHA.5012@xxxxxx
    You have to take in to account access hard drives are mechanical and have
    access time of ms, where as flash drives have an access time down in to
    nanoseconds.
  7. #7
    Tae Song Guest
    "Jerry" <ChiefZekeNoSpam@xxxxxx> wrote in message
    news:#6nvo$g6JHA.6136@xxxxxx
    >> 1GB flash drive.
    >> to get it out of the way and optional)
    >> like Word, would cause the HD to read the program into memory while at
    >> the same time writing into the drive, temporary files. This causes an
    >> I/O queue to form and degrade Windows performance. By off loading some
    >> of the I/O traffic to another storage device, the hard drive read/write
    >> head doesn't have to move around as much either. All performance gains.
    >> Index doesn't grow beyond 1GB. It's max size seems to be just under 1GB.
    >> You can move to it to a removable drive, though. I rebuilt the Index on
    >> an external 500GB USB drive. Again, this cuts down I/O traffic to the
    >> I found out you can only have 4095MB pagefile or just under 25% of total
    >> was about 700,000GB. Not that I needed that much, but just to test. I'm
    >> don't think it is, but I will have to look into that. I am not using
    >> 2GB of RAM.
    >> Anyways, that's it.
    >> out.
    That would work. But how much memory are you going to allocate to RAM
    drive? 1GB flash are practically free these days. They were giving them
    out for free at a community college if you signed up for a computer class.
    Well... technically that's not free... but... they gave you one 1GB flash
    drive if you signed up for a class, that's more accurate.
  8. #8
    Pegasus [MVP] Guest
    news:4E87102D-4004-4699-8BF6-3235EC1A5735@xxxxxx
    >> your measures have the desired effect. Could we have some performance
    >> figures, complete with the test methods you applied so that anyone can
    >> perform the same tests on his machine?
    > nanoseconds.
    I recommend you do some reading about the difference between RAM and flash
    memory. It's huge! Did you actually bother to measure the change in
    performance or is this just an idea you have, not backed up by any
    reproducible measurements?
  9. #9
    Bill in Co. Guest
    >> your
    > nanoseconds.
    The write time is much larger for a flash drive.
  10. #10
    Bill in Co. Guest
    >> nanoseconds.
    > memory. It's huge!
    Seconded.
    the latter - obviously. The bottom line here is that it was, and is, very
    bad advice.
Page 1 of 5 123 ... LastLast
How to increase system system performance problems?
How to increase system system performance Tae Song Vista General 43 13 Jun 2009
How to increase the File System Caching Memory? totalz Vista performance & maintenance 4 24 Dec 2008
Solved System Performance Frank-here General Discussion 3 09 Sep 2008
Increase Size Of System Tray Icons Dell Boy Vista General 3 15 May 2007
System Restore increase disk space used Bronskimac Vista General 0 17 Jun 2006
