Realtek HD Audio and SP2
  1. #1
    Rojo Habe Guest
    After installing SP2 I noticed that Windows had replaced my Realtek HD Audio
    driver with its own older version. It also now appears twice in the Device
    Manager; I can remove one of them with no ill effects but it is redetected
    at next boot and reinstalled.
    So I removed both of them, installed the latest Realtek driver and rebooted.
    Now I still have two instances - one (called Realtek High Definition Audio)
    with the Realtek driver and the other (simply called High Definition Audio
    Device) with the Microsoft drivers. If I force the Microsoft one to use the
    Realtek drivers it crashes horribly with a BSoD (so I won't be doing that
    again!).
    Once again I can remove the Microsoft one with no ill effects but it's
    redetected and installed again on the next boot.
    Something in my memory tells me I always had two entries under 'Sound, Video
    and game controllers' but the second one wasn't called "High Definition
    Audio Device" and the Driver Provider was Realtek, not Microsoft. Trouble
    is, I can't remember what it was called, or what it was for.
    Anybody help? I could always do a System Restore to pre-SP2 and find out
    that way but it's probably worth finding out here first whether I'm worrying
    about nothing or not. It seems I've got two components of the same chip
    with drivers from different releases.
  2. #2
    vista 64-bit ulimate sp1
    Local Time: 08:57 PM
    Re: Realtek HD Audio and SP2
    i came across the same issue:
    d/l the new driver version- place where you can find it
    unistall both
    reboot
    install the new drivers 1st step
    reboot
    go install 2nd step
    reboot
    it will show only one driver
    with the new software version
Realtek HD Audio and SP2 problems?
Realtek HD Audio Leevis Sound & Audio 8 11 Nov 2008
Microsoft HD audio & Realtek HD audio Rob Vista General 2 16 Mar 2008
realtek HD audio davenemz Vista hardware & devices 4 27 Feb 2008
Realtek AC'97 audio driver provided by Microsoft. Audio error MCE GT Vista hardware & devices 1 03 Mar 2007
Realtek Audio comes and goes =?Utf-8?B?RGFuNzM=?= Vista General 0 16 Sep 2006
