| Guest | Linksys Wireless-N PCI Adapter Has anyone used the Linksys Wireless-N PCI Adapter? It's an internal, that plugs into the PCI bus of your computer. |
| Guest | Re: Linksys Wireless-N PCI Adapter "Patrick Whittle" <patrick_whittle@xxxxxx> wrote: Quote: >Has anyone used the Linksys Wireless-N PCI Adapter? It's an internal, that >plugs into the PCI bus of your computer. PCI Adapter... ya think? |
| Guest | Re: Linksys Wireless-N PCI Adapter "Patrick Whittle" <patrick_whittle@xxxxxx> wrote in message news:OumsNPm9JHA.1540@xxxxxx Quote: > Has anyone used the Linksys Wireless-N PCI Adapter? It's an internal, > that plugs into the PCI bus of your computer. > No, I have not, but it's just a wireless adapter, and all adapters are pretty similar in functionality. Do you have a question regarding a problem or how to use it? -- Ace This posting is provided "AS-IS" with no warranties or guarantees and confers no rights. Please reply back to the newsgroup/forum to benefit from collaboration among responding engineers, as well as to help others benefit from your resolution. Ace Fekay, MCSE 2003 & 2000, MCSA 2003 & 2000, MCSA Messaging, MCT Microsoft Certified Trainer aceman@xxxxxx http://twitter.com/acefekay For urgent issues, you may want to contact Microsoft PSS directly. Please check http://support.microsoft.com for regional support phone numbers. |
| Guest | Re: Linksys Wireless-N PCI Adapter I have it, and it is great. But other brands probably would work just as well. "Ace Fekay [Microsoft Certified Trainer]" <aceman@xxxxxx> a écrit dans le message de news:O0y8kwm9JHA.4948@xxxxxx Quote: > "Patrick Whittle" <patrick_whittle@xxxxxx> wrote in message > news:OumsNPm9JHA.1540@xxxxxx Quote: >> Has anyone used the Linksys Wireless-N PCI Adapter? It's an internal, >> that plugs into the PCI bus of your computer. >> > > No, I have not, but it's just a wireless adapter, and all adapters are > pretty similar in functionality. > > Do you have a question regarding a problem or how to use it? > > -- > Ace > > This posting is provided "AS-IS" with no warranties or guarantees and > confers no rights. > > Please reply back to the newsgroup/forum to benefit from collaboration > among responding engineers, as well as to help others benefit from your > resolution. > > Ace Fekay, MCSE 2003 & 2000, MCSA 2003 & 2000, MCSA Messaging, MCT > Microsoft Certified Trainer > aceman@xxxxxx > http://twitter.com/acefekay > > For urgent issues, you may want to contact Microsoft PSS directly. Please > check http://support.microsoft.com for regional support phone numbers. > |
| Guest | Re: Linksys Wireless-N PCI Adapter "Natéag" <cqui3@xxxxxx> wrote in message news:eCifJfn9JHA.4220@xxxxxx Quote: >I have it, and it is great. > But other brands probably would work just as well. Good to hear. Hopefully your feedback will help others when making a decision on which brand and model to choose. Ace |
| | #6 (permalink) |
| Guest | Re: Linksys Wireless-N PCI Adapter "Natéag" <cqui3@xxxxxx> wrote in message news:eCifJfn9JHA.4220@xxxxxx Quote: >I have it, and it is great. > But other brands probably would work just as well. I meant to add that I hope it also helps the original poster, but then again, based on his post, I'm not sure if he had a problem or not with the NIC. Cheers! Ace |
| | #7 (permalink) |
| Guest | Re: Linksys Wireless-N PCI Adapter Hi Wireless is about signal propagation. Place the system so that it is High and away from the wall so it would not be stifled between the Case and the Wall. Jack (MS, MVP-Networking) "Patrick Whittle" <patrick_whittle@xxxxxx> wrote in message news:OumsNPm9JHA.1540@xxxxxx Quote: > Has anyone used the Linksys Wireless-N PCI Adapter? It's an internal, > that plugs into the PCI bus of your computer. > |
| | #8 (permalink) |
| Guest | Re: Linksys Wireless-N PCI Adapter As I wrote it works flawlessly. That may be due to the antenna, which is lets say, gigantic. "Jack [MVP-Networking]" <jack@xxxxxx> a écrit dans le message de news:eOL6Flp9JHA.5780@xxxxxx Quote: > Hi > Wireless is about signal propagation. > Place the system so that it is High and away from the wall so it would not > be stifled between the Case and the Wall. > Jack (MS, MVP-Networking) > > "Patrick Whittle" <patrick_whittle@xxxxxx> wrote in message > news:OumsNPm9JHA.1540@xxxxxx Quote: >> Has anyone used the Linksys Wireless-N PCI Adapter? It's an internal, >> that plugs into the PCI bus of your computer. >> |
| | #9 (permalink) |
| Guest | Re: Linksys Wireless-N PCI Adapter I ended up buying an external D-Link Xtreme N Dual Band gigbit router. I know enough about 802.11n from previous, but do you know streaming... High-Definition, and other media? ... the 5GHz band. http://support.dlink.ca/products/vie...ctid=DIR%2D825 "Ace Fekay [Microsoft Certified Trainer]" <aceman@xxxxxx> wrote in message news:OFkTVjp9JHA.1252@xxxxxx Quote: > "Natéag" <cqui3@xxxxxx> wrote in message > news:eCifJfn9JHA.4220@xxxxxx Quote: >>I have it, and it is great. >> But other brands probably would work just as well. > Natéag, > > I meant to add that I hope it also helps the original poster, but then > again, based on his post, I'm not sure if he had a problem or not with the > NIC. > > Cheers! > > Ace > > |
| | #10 (permalink) |
| Guest | Re: Linksys Wireless-N PCI Adapter We have had no problems!! "Natéag" <cqui3@xxxxxx> wrote in message news:ujFgm0r9JHA.4560@xxxxxx Quote: > As I wrote it works flawlessly. That may be due to the antenna, > which is lets say, gigantic. > > > "Jack [MVP-Networking]" <jack@xxxxxx> a écrit dans le message > de news:eOL6Flp9JHA.5780@xxxxxx Quote: >> Hi >> Wireless is about signal propagation. >> Place the system so that it is High and away from the wall so it would >> not be stifled between the Case and the Wall. >> Jack (MS, MVP-Networking) >> >> "Patrick Whittle" <patrick_whittle@xxxxxx> wrote in message >> news:OumsNPm9JHA.1540@xxxxxx Quote: >>> Has anyone used the Linksys Wireless-N PCI Adapter? It's an internal, >>> that plugs into the PCI bus of your computer. >>> |
| Linksys wireless-G adapter v4.0...x64 driver? | Drivers | |||
| Linksys Wireless Adapter WUSB54GC | Vista hardware & devices | |||
| What could I do with my Linksys wireless adapter?? | Vista hardware & devices | |||
| Linksys wireless adapter | Vista General | |||
| Linksys wireless usb adapter | Vista networking & sharing | |||
