| | Printer Problem with Lexmark 6200 I installed a Lexmark 6200 printer on a Acer Laptop runing Vista Home Premium. The installation took a long time but went to completion. I used the Lexmark disk for the install. The 6200 displays on the Control Panel screen as "Ready." I made it the default. The printer is pluged into one of the USB ports. The problem: nothing prints. I sometimes get in an error message - can't find printer. But typically, when I do File>Print nothing prints. I have tried using Works, NotePad and Open Office Writer with the same results. Your help would be appreciated. |
| | Re: Printer Problem with Lexmark 6200 old volunteer <oldvolunteer@xxxxxx> wrote: Quote: >I installed a Lexmark 6200 printer on a Acer Laptop runing Vista Home >Premium. The installation took a long time but went to completion. I used >the Lexmark disk for the install. The 6200 displays on the Control Panel >screen as "Ready." I made it the default. The printer is pluged into one of >the USB ports. > >The problem: nothing prints. I sometimes get in an error message - can't >find printer. But typically, when I do File>Print nothing prints. I have >tried using Works, NotePad and Open Office Writer with the same results. > >Your help would be appreciated. |
| | Re: Printer Problem with Lexmark 6200 I'm not sure. I used the original disk that came with the printer. How can I get the driver that works with Vista? "Manny Weisbord" wrote: Quote: > old volunteer <oldvolunteer@xxxxxx> wrote: > Quote: > >I installed a Lexmark 6200 printer on a Acer Laptop runing Vista Home > >Premium. The installation took a long time but went to completion. I used > >the Lexmark disk for the install. The 6200 displays on the Control Panel > >screen as "Ready." I made it the default. The printer is pluged into one of > >the USB ports. > > > >The problem: nothing prints. I sometimes get in an error message - can't > >find printer. But typically, when I do File>Print nothing prints. I have > >tried using Works, NotePad and Open Office Writer with the same results. > > > >Your help would be appreciated. > Are you sure you've installed the proper drivers for Vista? > |
| | Re: Printer Problem with Lexmark 6200 By going to the Lexmark Website/ "old volunteer" <oldvolunteer@xxxxxx> wrote in message news:9C46E5EF-652E-4D9D-A6B6-95354F3A6395@xxxxxx Quote: > I'm not sure. I used the original disk that came with the printer. How > can > I get the driver that works with Vista? > > "Manny Weisbord" wrote: > Quote: >> old volunteer <oldvolunteer@xxxxxx> wrote: >> Quote: >> >I installed a Lexmark 6200 printer on a Acer Laptop runing Vista Home >> >Premium. The installation took a long time but went to completion. I >> >used >> >the Lexmark disk for the install. The 6200 displays on the Control >> >Panel >> >screen as "Ready." I made it the default. The printer is pluged into >> >one of >> >the USB ports. >> > >> >The problem: nothing prints. I sometimes get in an error message - >> >can't >> >find printer. But typically, when I do File>Print nothing prints. I >> >have >> >tried using Works, NotePad and Open Office Writer with the same results. >> > >> >Your help would be appreciated. >> Are you sure you've installed the proper drivers for Vista? >> |
| | Re: Printer Problem with Lexmark 6200 old volunteer wrote: Quote: > I installed a Lexmark 6200 printer on a Acer Laptop runing Vista Home > Premium. The installation took a long time but went to completion. I used > the Lexmark disk for the install. The 6200 displays on the Control Panel > screen as "Ready." I made it the default. The printer is pluged into one of > the USB ports. > > The problem: nothing prints. I sometimes get in an error message - can't > find printer. But typically, when I do File>Print nothing prints. I have > tried using Works, NotePad and Open Office Writer with the same results. > > Your help would be appreciated. http://downloads.lexmark.com/perl/do...29:1:0:462:0:0 Here is a good resource for these things; http://www.microsoft.com/windows/compatibility/ Good luck, and post back if this works. Dave T. |
| | #6 (permalink) |
| | Re: Printer Problem with Lexmark 6200 old volunteer <oldvolunteer@xxxxxx> wrote: Quote: >I'm not sure. I used the original disk that came with the printer. How can >I get the driver that works with Vista? drivers. Looks as if it's time to buy a new printer. Where do you live? Quote: >"Manny Weisbord" wrote: > Quote: >> old volunteer <oldvolunteer@xxxxxx> wrote: >> Quote: >> >I installed a Lexmark 6200 printer on a Acer Laptop runing Vista Home >> >Premium. The installation took a long time but went to completion. I used >> >the Lexmark disk for the install. The 6200 displays on the Control Panel >> >screen as "Ready." I made it the default. The printer is pluged into one of >> >the USB ports. >> > >> >The problem: nothing prints. I sometimes get in an error message - can't >> >find printer. But typically, when I do File>Print nothing prints. I have >> >tried using Works, NotePad and Open Office Writer with the same results. >> > >> >Your help would be appreciated. >> Are you sure you've installed the proper drivers for Vista? >> |
| | #7 (permalink) |
| | Re: Printer Problem with Lexmark 6200 If there is no Vista driver from Lexmark you may be able to both install and run the XP driver from your installation CD in XP compatibility mode. I was able to do that with an old scanner I had till I replaced it. "Manny Weisbord" <mannyweisbord@xxxxxx> wrote in message news:rvvc455qcj7vrrlmepmvu5o9baf3tue5p0@xxxxxx Quote: > old volunteer <oldvolunteer@xxxxxx> wrote: > Quote: >>I'm not sure. I used the original disk that came with the printer. How >>can >>I get the driver that works with Vista? > A quick search of the Lexmark site (U.S.) doesn't show any Vista > drivers. Looks as if it's time to buy a new printer. > > Where do you live? > Quote: >>"Manny Weisbord" wrote: >> Quote: >>> old volunteer <oldvolunteer@xxxxxx> wrote: >>> >>> >I installed a Lexmark 6200 printer on a Acer Laptop runing Vista Home >>> >Premium. The installation took a long time but went to completion. I >>> >used >>> >the Lexmark disk for the install. The 6200 displays on the Control >>> >Panel >>> >screen as "Ready." I made it the default. The printer is pluged into >>> >one of >>> >the USB ports. >>> > >>> >The problem: nothing prints. I sometimes get in an error message - >>> >can't >>> >find printer. But typically, when I do File>Print nothing prints. I >>> >have >>> >tried using Works, NotePad and Open Office Writer with the same >>> >results. >>> > >>> >Your help would be appreciated. >>> >>> Are you sure you've installed the proper drivers for Vista? >>> |
| Lexmark X5650 Printer Problem | Vista print fax & scan | |||
| Lexmark Z515 Printer Sharing Problem | Vista print fax & scan | |||
| Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer | Vista print fax & scan | |||
| Lexmark Printer / Error problem communicating with printer | Vista print fax & scan | |||
| lexmark printer problem | Vista General | |||
