| | #11 (permalink) |
| | Re: mouse and keyboard problem. I don't have a way of telling if they are enabled or not as keyboard and mouse are non-functioning. The wired mouse and keyboard don't work. The wireless mouse doesn't work, not sure about the keyboard as I am no where near the PC right now, but will check later. Tried changing the battery, no luck. It occurs from fresh boot. Not aware of any driver update unless windows has done it automatically. Anyway, thanks for the response! "Curious" <spammenot@xxxxxx> wrote in message news:OqEXKQl%23JHA.3544@xxxxxx Quote: > Do I understand that when logged in both the the wired keyboard and mouse > are enabled as well as the wireless keyboard and mouse and that the wired > keyboard and mouse work but the wireless ones do not? > This could be caused by a dead battery in the wireless units or by a > defective driver update for the wireless units. > Does the problem occur on both a fresh boot and from waking up from sleep > mode? > "Tim" <timvieweg@xxxxxx> wrote in message > news:93537520-0895-4CDA-9BC4-BE978D09AA56@xxxxxx Quote: >> Hi, Got those model numbers for you: MICROSOFT WIRELESS LASER MOUSE 5000 >> MICROSOFT >> DIGITAL MEDIA PRO KEYBOARD >> MODEL NO: 1031 >> WIRELESS MOUSE >> RECEIVER V 1.0 MODEL NO:1053 >> >> Many thanks, >> >> Tim Vieweg >> >> >> "Tim" <timvieweg@xxxxxx> wrote in message >> news:19F049D0-DA5B-4421-B3BF-4C2566E5CB76@xxxxxx Quote: >>> Yes, sorry about the description I gave. I can log into windows but the >>> mouse pointer won't move at all and similarly when I use the keyboard it >>> doesn't type and doesn't provide access to anything in windows.i.e when >>> I usethe keyboard to type or use the keyboard shortcuts nothing happens >>> the- keyboard is non responsive. >>> >>> To answer your question more directly-the mouse doesn't scroll. >>> >>> I'll get make and model later today. >>> >>> Many thanks Tim Vieweg. >>> >>> >>> >>> "R. C. White" <rc@xxxxxx> wrote in message >>> news:eJTg6If%23JHA.3768@xxxxxx, yes sorry about the >>> descSFTNGP04.phx.gbl... >>>> Hi, Tim. >>>> >>>> Thanks for the additional details. But we still don't know what you >>>> mean by "not working". >>>> >>>> For example, MY Microsoft Wireless Laser 6000 Desktop Set, with the >>>> 6000 v.2.0 mouse and 6000 v.3.0 keyboard are working, but the keyboard >>>> is not working right because it often goes to sleep right in the middle >>>> of a word that I'm typing. >>>> >>>> Does your mouse refuse to scroll? Does your keyboard insist on ALL >>>> CAPS? What do they do wrong? >>>> >>>> With or without an MCP tag, you should be able to tell us HOW yours is >>>> "not working". So far, we haven't a clue. >>>> >>>> RC >>>> -- >>>> R. C. White, CPA >>>> San Marcos, TX >>>> rc@xxxxxx >>>> Microsoft Windows MVP >>>> Windows Live Mail 2009 (14.0.8064.0206) in Win7 Ultimate x64 RC 7100 >>>> >>>> "Tim" <timvieweg@xxxxxx> wrote in message >>>> news:A810A271-52D6-47DE-A84D-5EDCEC300B1B@xxxxxx >>>>> I knew I shouldn't have put the MCP tag! I can get into Windows just >>>>> fine >>>>> with no error messages. >>>>> The keyboard is Microsoft and so is the mouse i'll let u know the >>>>> model >>>>> later not by the machine right now. >>>>> I installed the drivers a few years ago so I can't remember how I >>>>> installed >>>>> them! >>>>> Thats all I know right now. >>>>> >>>>> Thanks for the help. >>>>> >>>>> Tim Vieweg (MCP)! >>>> >>>>> >>>>> "R. C. White" <rc@xxxxxx> wrote in message >>>>> news:uFaZBdZ%23JHA.5092@xxxxxx >>>>>> Hi, Tim. >>>>>> >>>>>> An MCP should know that we can't even begin to help you without more >>>>>> information than that. :>( >>>>>> >>>>>> First, please define "aren't working". Can you start the BIOS >>>>>> utility? Does Vista boot at all? At what point does it stop (if it >>>>>> does)? Are there any error messages? What do they say? >>>>>> >>>>>> What make and model keyboard and mouse? Did you install the >>>>>> beginning drives from the CD or floppy that came with them? >>>>>> >>>>>> Lots more questions, but those will do for now. >>>>>> >>>>>> RC >>>>>> >>>>>> "Tim" <timvieweg@xxxxxx> wrote in message >>>>>> news:OLXM1GX#JHA.1608@xxxxxx >>>>>>> Hi, >>>>>>> >>>>>>> I've got a custom built pc- athlonxp 3000+ ,2 gb mem, Windows Vista >>>>>>> home basic . >>>>>>> The problem is the wired keyboard and wireless mouse aren't working. >>>>>>> I swapped out the wireless mouse for a wired one and the problem >>>>>>> stayed the same. Any ideas? >>>>>>> >>>>>>> regards, >>>>>>> >>>>>>> Tim Vieweg MCP. >>>> >>> |
| | #12 (permalink) |
| | Re: mouse and keyboard problem. Have you tried booting and getting into the BIOS using the wired keyboard and mouse and with the adapter for the wireless keyboard removed from the system? Are the wired keyboard and mouse connected using PS2 ports or a USB port? "Tim" <timvieweg@xxxxxx> wrote in message news B495DF9-A356-4615-95D3-29BAA7298D0D@xxxxxxQuote: > I don't have a way of telling if they are enabled or not as keyboard and > mouse are non-functioning. The wired mouse and keyboard don't work. The > wireless mouse doesn't work, not sure about the keyboard as I am no where > near the PC right now, but will check later. > > Tried changing the battery, no luck. It occurs from fresh boot. Not aware > of any driver update unless windows has done it automatically. > > Anyway, thanks for the response! > > > "Curious" <spammenot@xxxxxx> wrote in message > news:OqEXKQl%23JHA.3544@xxxxxx Quote: >> Do I understand that when logged in both the the wired keyboard and mouse >> are enabled as well as the wireless keyboard and mouse and that the wired >> keyboard and mouse work but the wireless ones do not? >> This could be caused by a dead battery in the wireless units or by a >> defective driver update for the wireless units. >> Does the problem occur on both a fresh boot and from waking up from sleep >> mode? >> "Tim" <timvieweg@xxxxxx> wrote in message >> news:93537520-0895-4CDA-9BC4-BE978D09AA56@xxxxxx Quote: >>> Hi, Got those model numbers for you: MICROSOFT WIRELESS LASER MOUSE 5000 >>> MICROSOFT >>> DIGITAL MEDIA PRO KEYBOARD >>> MODEL NO: 1031 >>> WIRELESS MOUSE >>> RECEIVER V 1.0 MODEL NO:1053 >>> >>> Many thanks, >>> >>> Tim Vieweg >>> >>> >>> "Tim" <timvieweg@xxxxxx> wrote in message >>> news:19F049D0-DA5B-4421-B3BF-4C2566E5CB76@xxxxxx >>>> Yes, sorry about the description I gave. I can log into windows but the >>>> mouse pointer won't move at all and similarly when I use the keyboard >>>> it doesn't type and doesn't provide access to anything in windows.i.e >>>> when I usethe keyboard to type or use the keyboard shortcuts nothing >>>> happens the- keyboard is non responsive. >>>> >>>> To answer your question more directly-the mouse doesn't scroll. >>>> >>>> I'll get make and model later today. >>>> >>>> Many thanks Tim Vieweg. >>>> >>>> >>>> >>>> "R. C. White" <rc@xxxxxx> wrote in message >>>> news:eJTg6If%23JHA.3768@xxxxxx, yes sorry about the >>>> descSFTNGP04.phx.gbl... >>>>> Hi, Tim. >>>>> >>>>> Thanks for the additional details. But we still don't know what you >>>>> mean by "not working". >>>>> >>>>> For example, MY Microsoft Wireless Laser 6000 Desktop Set, with the >>>>> 6000 v.2.0 mouse and 6000 v.3.0 keyboard are working, but the >>>>> keyboard is not working right because it often goes to sleep right in >>>>> the middle of a word that I'm typing. >>>>> >>>>> Does your mouse refuse to scroll? Does your keyboard insist on ALL >>>>> CAPS? What do they do wrong? >>>>> >>>>> With or without an MCP tag, you should be able to tell us HOW yours is >>>>> "not working". So far, we haven't a clue. >>>>> >>>>> RC >>>>> -- >>>>> R. C. White, CPA >>>>> San Marcos, TX >>>>> rc@xxxxxx >>>>> Microsoft Windows MVP >>>>> Windows Live Mail 2009 (14.0.8064.0206) in Win7 Ultimate x64 RC 7100 >>>>> >>>>> "Tim" <timvieweg@xxxxxx> wrote in message >>>>> news:A810A271-52D6-47DE-A84D-5EDCEC300B1B@xxxxxx >>>>>> I knew I shouldn't have put the MCP tag! I can get into Windows just >>>>>> fine >>>>>> with no error messages. >>>>>> The keyboard is Microsoft and so is the mouse i'll let u know the >>>>>> model >>>>>> later not by the machine right now. >>>>>> I installed the drivers a few years ago so I can't remember how I >>>>>> installed >>>>>> them! >>>>>> Thats all I know right now. >>>>>> >>>>>> Thanks for the help. >>>>>> >>>>>> Tim Vieweg (MCP)! >>>>> >>>>>> >>>>>> "R. C. White" <rc@xxxxxx> wrote in message >>>>>> news:uFaZBdZ%23JHA.5092@xxxxxx >>>>>>> Hi, Tim. >>>>>>> >>>>>>> An MCP should know that we can't even begin to help you without more >>>>>>> information than that. :>( >>>>>>> >>>>>>> First, please define "aren't working". Can you start the BIOS >>>>>>> utility? Does Vista boot at all? At what point does it stop (if it >>>>>>> does)? Are there any error messages? What do they say? >>>>>>> >>>>>>> What make and model keyboard and mouse? Did you install the >>>>>>> beginning drives from the CD or floppy that came with them? >>>>>>> >>>>>>> Lots more questions, but those will do for now. >>>>>>> >>>>>>> RC >>>>>>> >>>>>>> "Tim" <timvieweg@xxxxxx> wrote in message >>>>>>> news:OLXM1GX#JHA.1608@xxxxxx >>>>>>>> Hi, >>>>>>>> >>>>>>>> I've got a custom built pc- athlonxp 3000+ ,2 gb mem, Windows >>>>>>>> Vista home basic . >>>>>>>> The problem is the wired keyboard and wireless mouse aren't >>>>>>>> working. I swapped out the wireless mouse for a wired one and the >>>>>>>> problem stayed the same. Any ideas? >>>>>>>> >>>>>>>> regards, >>>>>>>> >>>>>>>> Tim Vieweg MCP. >>>>> >>>> >>> |
| | #13 (permalink) |
| | Re: mouse and keyboard problem. No I haven't tried that,I'll give that a try . The mouse I tried ps/2. cheers, Tim Vieweg. "Curious" <spammenot@xxxxxx> wrote in message news:Ow8z6zl%23JHA.1608@xxxxxx Quote: > Have you tried booting and getting into the BIOS using the wired keyboard > and mouse and with the adapter for the wireless keyboard removed from the > system? > Are the wired keyboard and mouse connected using PS2 ports or a USB port? > "Tim" <timvieweg@xxxxxx> wrote in message > news B495DF9-A356-4615-95D3-29BAA7298D0D@xxxxxxQuote: >> I don't have a way of telling if they are enabled or not as keyboard and >> mouse are non-functioning. The wired mouse and keyboard don't work. The >> wireless mouse doesn't work, not sure about the keyboard as I am no where >> near the PC right now, but will check later. >> >> Tried changing the battery, no luck. It occurs from fresh boot. Not aware >> of any driver update unless windows has done it automatically. >> >> Anyway, thanks for the response! >> >> >> "Curious" <spammenot@xxxxxx> wrote in message >> news:OqEXKQl%23JHA.3544@xxxxxx Quote: >>> Do I understand that when logged in both the the wired keyboard and >>> mouse are enabled as well as the wireless keyboard and mouse and that >>> the wired keyboard and mouse work but the wireless ones do not? >>> This could be caused by a dead battery in the wireless units or by a >>> defective driver update for the wireless units. >>> Does the problem occur on both a fresh boot and from waking up from >>> sleep mode? >>> "Tim" <timvieweg@xxxxxx> wrote in message >>> news:93537520-0895-4CDA-9BC4-BE978D09AA56@xxxxxx >>>> Hi, Got those model numbers for you: MICROSOFT WIRELESS LASER MOUSE >>>> 5000 >>>> MICROSOFT >>>> DIGITAL MEDIA PRO KEYBOARD >>>> MODEL NO: 1031 >>>> WIRELESS MOUSE >>>> RECEIVER V 1.0 MODEL NO:1053 >>>> >>>> Many thanks, >>>> >>>> Tim Vieweg >>>> >>>> >>>> "Tim" <timvieweg@xxxxxx> wrote in message >>>> news:19F049D0-DA5B-4421-B3BF-4C2566E5CB76@xxxxxx >>>>> Yes, sorry about the description I gave. I can log into windows but >>>>> the mouse pointer won't move at all and similarly when I use the >>>>> keyboard it doesn't type and doesn't provide access to anything in >>>>> windows.i.e when I usethe keyboard to type or use the keyboard >>>>> shortcuts nothing happens the- keyboard is non responsive. >>>>> >>>>> To answer your question more directly-the mouse doesn't scroll. >>>>> >>>>> I'll get make and model later today. >>>>> >>>>> Many thanks Tim Vieweg. >>>>> >>>>> >>>>> >>>>> "R. C. White" <rc@xxxxxx> wrote in message >>>>> news:eJTg6If%23JHA.3768@xxxxxx, yes sorry about the >>>>> descSFTNGP04.phx.gbl... >>>>>> Hi, Tim. >>>>>> >>>>>> Thanks for the additional details. But we still don't know what you >>>>>> mean by "not working". >>>>>> >>>>>> For example, MY Microsoft Wireless Laser 6000 Desktop Set, with the >>>>>> 6000 v.2.0 mouse and 6000 v.3.0 keyboard are working, but the >>>>>> keyboard is not working right because it often goes to sleep right in >>>>>> the middle of a word that I'm typing. >>>>>> >>>>>> Does your mouse refuse to scroll? Does your keyboard insist on ALL >>>>>> CAPS? What do they do wrong? >>>>>> >>>>>> With or without an MCP tag, you should be able to tell us HOW yours >>>>>> is "not working". So far, we haven't a clue. >>>>>> >>>>>> RC >>>>>> -- >>>>>> R. C. White, CPA >>>>>> San Marcos, TX >>>>>> rc@xxxxxx >>>>>> Microsoft Windows MVP >>>>>> Windows Live Mail 2009 (14.0.8064.0206) in Win7 Ultimate x64 RC 7100 >>>>>> >>>>>> "Tim" <timvieweg@xxxxxx> wrote in message >>>>>> news:A810A271-52D6-47DE-A84D-5EDCEC300B1B@xxxxxx >>>>>>> I knew I shouldn't have put the MCP tag! I can get into Windows just >>>>>>> fine >>>>>>> with no error messages. >>>>>>> The keyboard is Microsoft and so is the mouse i'll let u know the >>>>>>> model >>>>>>> later not by the machine right now. >>>>>>> I installed the drivers a few years ago so I can't remember how I >>>>>>> installed >>>>>>> them! >>>>>>> Thats all I know right now. >>>>>>> >>>>>>> Thanks for the help. >>>>>>> >>>>>>> Tim Vieweg (MCP)! >>>>>> >>>>>>> >>>>>>> "R. C. White" <rc@xxxxxx> wrote in message >>>>>>> news:uFaZBdZ%23JHA.5092@xxxxxx >>>>>>>> Hi, Tim. >>>>>>>> >>>>>>>> An MCP should know that we can't even begin to help you without >>>>>>>> more information than that. :>( >>>>>>>> >>>>>>>> First, please define "aren't working". Can you start the BIOS >>>>>>>> utility? Does Vista boot at all? At what point does it stop (if it >>>>>>>> does)? Are there any error messages? What do they say? >>>>>>>> >>>>>>>> What make and model keyboard and mouse? Did you install the >>>>>>>> beginning drives from the CD or floppy that came with them? >>>>>>>> >>>>>>>> Lots more questions, but those will do for now. >>>>>>>> >>>>>>>> RC >>>>>>>> >>>>>>>> "Tim" <timvieweg@xxxxxx> wrote in message >>>>>>>> news:OLXM1GX#JHA.1608@xxxxxx >>>>>>>>> Hi, >>>>>>>>> >>>>>>>>> I've got a custom built pc- athlonxp 3000+ ,2 gb mem, Windows >>>>>>>>> Vista home basic . >>>>>>>>> The problem is the wired keyboard and wireless mouse aren't >>>>>>>>> working. I swapped out the wireless mouse for a wired one and the >>>>>>>>> problem stayed the same. Any ideas? >>>>>>>>> >>>>>>>>> regards, >>>>>>>>> >>>>>>>>> Tim Vieweg MCP. >>>>>> >>>>> >>>> |
| | #14 (permalink) |
| | Re: mouse and keyborad problem. Many thanks guys for your help. I can't give any feedback for a while but will post what worked in the next few weeks. Tim Vieweg. "pacinitaly" <guest@xxxxxx-email.com> wrote in message news:0c383d7d9c3902eb5d97a961b9836fec@xxxxxx-gateway.com... Quote: > > try to uninstall drivers in device manager and reboot > > > -- > pacinitaly > > SpellCherkers aren't worth a shirt |
| Mouse problem in cs 1.6 | Gaming | |||
| Mouse Problem | General Discussion | |||
| MOUSE PROBLEM | Vista General | |||
| Mouse Problem | Vista hardware & devices | |||
| Help me: mouse problem | Vista General | |||
