Wireless Networking
  1. #1
    Rowan Troy Guest
    Wireless Networking
    I managed to get Vista installed on my laptop at work - works fine which is
    pretty good as I tried to install it at home and it didn't want to know. I
    was connected to my works wireless network which I set up and it was great.
    I went home that night connected to my home one - fine no issues. Came to
    work this morning and it now won't connect to the work one. Says either
    there is limited or no connectivity or it just allows domain access and won't
    go out to the Internet.
    Now I heard somewhere that there is something built into Vista that allows
    workers who leave their wireless network to connect to other networks but
    when they return they cannot connect straight away they need to do something.
    If anyone can tell me what that something is or how to fix this issue please
    HELP!
    Its an Intel Pro Wireless 2200BG built in adapter to my Alienware.
    Thanks
  2. #2
    Chris Guest
    RE: Wireless Networking
    gfhgfghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
    > HELP!
    > Thanks
    hi
    just used windows vista wireless Configuration from Microsoft
  3. #3
    Rowan Troy Guest
    Well that is what I am doing - I am not using anything else. Just it doesn't
    want to pick up DHCP anymore from my server. Every other wireless client in
    the office has no problem. It appears to only be my WEP enabled network.
    The network downstairs that is open and doesn't belong to us works fine and
    it allows me to connect to the Internet. It seems that Vista doesn't want to
    make more than one hop to get DHCP addresses. I guess this is before it
    locates the wireless point and assumes thats the only device it can get to
    and therefore it doesn't think "oh hold on perhaps if I cannot get a DHCP
    packet from this wireless point should I go off and get one from somewhere
    else?"
    Thats my main problem and its starting to get up in my grill. I know it is
    trying to map my network but because my wireless Access Point is plugged into
    my switch, which then has a connection from my server which provides DHCP, it
    doesn't want to map things any further!!!!!
    Help still needed!
    > > HELP!
    > > Thanks
    > hi
Wireless Networking problems?
Wireless networking help MikeB Vista General 7 28 Dec 2008
wireless networking saju Vista networking & sharing 1 10 Nov 2007
Networking and Wireless 1xnyer Vista networking & sharing 2 30 Aug 2007
Wireless Networking Nero Vista networking & sharing 6 27 Jul 2007
Wireless Networking Bill Condie Vista General 0 24 Feb 2007
