| | nvidia GeForce FX 5200 problem with Aero I used the FX 5200 with Vista RC1, and was able to use Aero with no problems, but after installing RC2, I cannot use Aero. The only choices I have are basic, standard and classic. I've updated the graphics driver from nvidia to 9.6.8.5 (the newest for vista) and it's still the same. Any idea how to enable Aero again? |
| | Re: nvidia GeForce FX 5200 problem with Aero I have the same problem but I am using the GeForce 6200 card. Again with RC1 I have full aero, but not with RC2 I have trawled around this news group and the nvidia web site and the only suggestion I have found is to either update the bios on my Shuttle MK32 motherboard or to update my motherboard to a newer one. If anyone from nvidia or microsoft can offer an explanation, I'd be grateful. "arthur" <arthur@discussions.microsoft.com> wrote in message news:300EA67D-0BFF-46C8-A51C-C417DBB5547C@microsoft.com... >I used the FX 5200 with Vista RC1, and was able to use Aero with no >problems, > but after installing RC2, I cannot use Aero. The only choices I have are > basic, standard and classic. I've updated the graphics driver from nvidia > to > 9.6.8.5 (the newest for vista) and it's still the same. Any idea how to > enable Aero again? |
| | Re: nvidia GeForce FX 5200 problem with Aero I had this same problem when in RC1 when Windows Update installed a newer driver. I don't know if this solved my problem or if it fixed itself, but what I did was rerun the performance test to update the performance ranking. After doing that I was able to run Aero again. "Stuart" <stuart.cross@blueyonder.co.uk> wrote in message news:C7CE6B6B-7F89-4A49-AC67-F77BEE856ABC@microsoft.com... >I have the same problem but I am using the GeForce 6200 card. > Again with RC1 I have full aero, but not with RC2 > I have trawled around this news group and the nvidia web site and the only > suggestion I have found is to either update the bios on my Shuttle MK32 > motherboard or to update my motherboard to a newer one. > If anyone from nvidia or microsoft can offer an explanation, I'd be > grateful. > "arthur" <arthur@discussions.microsoft.com> wrote in message > news:300EA67D-0BFF-46C8-A51C-C417DBB5547C@microsoft.com... >>I used the FX 5200 with Vista RC1, and was able to use Aero with no >>problems, >> but after installing RC2, I cannot use Aero. The only choices I have are >> basic, standard and classic. I've updated the graphics driver from nvidia >> to >> 9.6.8.5 (the newest for vista) and it's still the same. Any idea how to >> enable Aero again? > |
| | Re: nvidia GeForce FX 5200 problem with Aero From extensive reading about this problem when upgrading from RC1 to RC2, it seems you need at least 1gig of RAM to enable this feature in RC2. Does that tie in with any of your circumstances? Regards, Mike L "John Doe" wrote: > I had this same problem when in RC1 when Windows Update installed a newer > driver. I don't know if this solved my problem or if it fixed itself, but > what I did was rerun the performance test to update the performance ranking. > After doing that I was able to run Aero again. > > "Stuart" <stuart.cross@blueyonder.co.uk> wrote in message > news:C7CE6B6B-7F89-4A49-AC67-F77BEE856ABC@microsoft.com... > >I have the same problem but I am using the GeForce 6200 card. > > Again with RC1 I have full aero, but not with RC2 > > I have trawled around this news group and the nvidia web site and the only > > suggestion I have found is to either update the bios on my Shuttle MK32 > > motherboard or to update my motherboard to a newer one. > > If anyone from nvidia or microsoft can offer an explanation, I'd be > > grateful. > > "arthur" <arthur@discussions.microsoft.com> wrote in message > > news:300EA67D-0BFF-46C8-A51C-C417DBB5547C@microsoft.com... > >>I used the FX 5200 with Vista RC1, and was able to use Aero with no > >>problems, > >> but after installing RC2, I cannot use Aero. The only choices I have are > >> basic, standard and classic. I've updated the graphics driver from nvidia > >> to > >> 9.6.8.5 (the newest for vista) and it's still the same. Any idea how to > >> enable Aero again? > > > |
| | Re: nvidia GeForce FX 5200 problem with Aero I only have 512 Mb of RAM at the moment, I'll upgrade and let you all know of the outcome, thanks for your advice:-) Stuart "Mike" <Mike@discussions.microsoft.com> wrote in message news:6D792268-F97E-4F43-9DB0-4F627D5E3D2D@microsoft.com... > From extensive reading about this problem when upgrading from RC1 to RC2, > it > seems you need at least 1gig of RAM to enable this feature in RC2. Does > that > tie in with any of your circumstances? > Regards, > Mike L > > > "John Doe" wrote: > >> I had this same problem when in RC1 when Windows Update installed a newer >> driver. I don't know if this solved my problem or if it fixed itself, but >> what I did was rerun the performance test to update the performance >> ranking. >> After doing that I was able to run Aero again. >> >> "Stuart" <stuart.cross@blueyonder.co.uk> wrote in message >> news:C7CE6B6B-7F89-4A49-AC67-F77BEE856ABC@microsoft.com... >> >I have the same problem but I am using the GeForce 6200 card. >> > Again with RC1 I have full aero, but not with RC2 >> > I have trawled around this news group and the nvidia web site and the >> > only >> > suggestion I have found is to either update the bios on my Shuttle MK32 >> > motherboard or to update my motherboard to a newer one. >> > If anyone from nvidia or microsoft can offer an explanation, I'd be >> > grateful. >> > "arthur" <arthur@discussions.microsoft.com> wrote in message >> > news:300EA67D-0BFF-46C8-A51C-C417DBB5547C@microsoft.com... >> >>I used the FX 5200 with Vista RC1, and was able to use Aero with no >> >>problems, >> >> but after installing RC2, I cannot use Aero. The only choices I have >> >> are >> >> basic, standard and classic. I've updated the graphics driver from >> >> nvidia >> >> to >> >> 9.6.8.5 (the newest for vista) and it's still the same. Any idea how >> >> to >> >> enable Aero again? >> > >> |
| | #6 (permalink) |
| | Re: nvidia GeForce FX 5200 problem with Aero Hi Stuart, Please don't blame me if this is NOT true... but as you DO have 512meg it seems quite likely that this IS the case! As I said, I have researched it quite a bit! I only have 512meg RAM too, and I'm looking to buy an NVidia card to get aero/glass. The 1gig RAM has tended to put me off... I have 4 DDR slots and they are full! Hence I need to replace NOT add! Good luck and let us all know if this does cure the problem. Regards, Mike "Stuart" wrote: > I only have 512 Mb of RAM at the moment, I'll upgrade and let you all know > of the outcome, thanks for your advice:-) > Stuart > "Mike" <Mike@discussions.microsoft.com> wrote in message > news:6D792268-F97E-4F43-9DB0-4F627D5E3D2D@microsoft.com... > > From extensive reading about this problem when upgrading from RC1 to RC2, > > it > > seems you need at least 1gig of RAM to enable this feature in RC2. Does > > that > > tie in with any of your circumstances? > > Regards, > > Mike L > > > > > > "John Doe" wrote: > > > >> I had this same problem when in RC1 when Windows Update installed a newer > >> driver. I don't know if this solved my problem or if it fixed itself, but > >> what I did was rerun the performance test to update the performance > >> ranking. > >> After doing that I was able to run Aero again. > >> > >> "Stuart" <stuart.cross@blueyonder.co.uk> wrote in message > >> news:C7CE6B6B-7F89-4A49-AC67-F77BEE856ABC@microsoft.com... > >> >I have the same problem but I am using the GeForce 6200 card. > >> > Again with RC1 I have full aero, but not with RC2 > >> > I have trawled around this news group and the nvidia web site and the > >> > only > >> > suggestion I have found is to either update the bios on my Shuttle MK32 > >> > motherboard or to update my motherboard to a newer one. > >> > If anyone from nvidia or microsoft can offer an explanation, I'd be > >> > grateful. > >> > "arthur" <arthur@discussions.microsoft.com> wrote in message > >> > news:300EA67D-0BFF-46C8-A51C-C417DBB5547C@microsoft.com... > >> >>I used the FX 5200 with Vista RC1, and was able to use Aero with no > >> >>problems, > >> >> but after installing RC2, I cannot use Aero. The only choices I have > >> >> are > >> >> basic, standard and classic. I've updated the graphics driver from > >> >> nvidia > >> >> to > >> >> 9.6.8.5 (the newest for vista) and it's still the same. Any idea how > >> >> to > >> >> enable Aero again? > >> > > >> > > |
| | #7 (permalink) |
| | Re: nvidia GeForce FX 5200 problem with Aero i have the same video card, i.e. nvidea gforce fx5200. the only one problem i had with rc1 (so far) was i needed to update the video card to watch DVD'S, aero though no problems before i updated the video card, i do have though 1.25 GB of ram. so i think your right. "Mike" wrote: > Hi Stuart, > Please don't blame me if this is NOT true... but as you DO have 512meg it > seems quite likely that this IS the case! As I said, I have researched it > quite a bit! I only have 512meg RAM too, and I'm looking to buy an NVidia > card to get aero/glass. The 1gig RAM has tended to put me off... I have 4 > DDR slots and they are full! Hence I need to replace NOT add! > Good luck and let us all know if this does cure the problem. > Regards, > Mike > > > > "Stuart" wrote: > > > I only have 512 Mb of RAM at the moment, I'll upgrade and let you all know > > of the outcome, thanks for your advice:-) > > Stuart > > "Mike" <Mike@discussions.microsoft.com> wrote in message > > news:6D792268-F97E-4F43-9DB0-4F627D5E3D2D@microsoft.com... > > > From extensive reading about this problem when upgrading from RC1 to RC2, > > > it > > > seems you need at least 1gig of RAM to enable this feature in RC2. Does > > > that > > > tie in with any of your circumstances? > > > Regards, > > > Mike L > > > > > > > > > "John Doe" wrote: > > > > > >> I had this same problem when in RC1 when Windows Update installed a newer > > >> driver. I don't know if this solved my problem or if it fixed itself, but > > >> what I did was rerun the performance test to update the performance > > >> ranking. > > >> After doing that I was able to run Aero again. > > >> > > >> "Stuart" <stuart.cross@blueyonder.co.uk> wrote in message > > >> news:C7CE6B6B-7F89-4A49-AC67-F77BEE856ABC@microsoft.com... > > >> >I have the same problem but I am using the GeForce 6200 card. > > >> > Again with RC1 I have full aero, but not with RC2 > > >> > I have trawled around this news group and the nvidia web site and the > > >> > only > > >> > suggestion I have found is to either update the bios on my Shuttle MK32 > > >> > motherboard or to update my motherboard to a newer one. > > >> > If anyone from nvidia or microsoft can offer an explanation, I'd be > > >> > grateful. > > >> > "arthur" <arthur@discussions.microsoft.com> wrote in message > > >> > news:300EA67D-0BFF-46C8-A51C-C417DBB5547C@microsoft.com... > > >> >>I used the FX 5200 with Vista RC1, and was able to use Aero with no > > >> >>problems, > > >> >> but after installing RC2, I cannot use Aero. The only choices I have > > >> >> are > > >> >> basic, standard and classic. I've updated the graphics driver from > > >> >> nvidia > > >> >> to > > >> >> 9.6.8.5 (the newest for vista) and it's still the same. Any idea how > > >> >> to > > >> >> enable Aero again? > > >> > > > >> > > > > |
| | #8 (permalink) |
| | Re: nvidia GeForce FX 5200 problem with Aero Hi Billmc, I am still looking for definitive answers to this, but there really doesn't seem to be any! I have read, here, that others have aero / glass enabled with on-board graphics with 64meg, others with dedicated graphics cards with just 256meg! That just doesn't make sense! It seems, in RC2 at least, that the O/S does a hardware check and, if below spec, disables aero/glass. There is a registry hack that, apparently, gets round this... I tried it and can't get it to work! Does ANYBODY have the full answer to this? The last thing I want to do is spend loads of cash on a new card and find I still have this problem! Regards to all, Mike L "Billmc" wrote: > i have the same video card, i.e. nvidea gforce fx5200. the only one problem i > had with rc1 (so far) was i needed to update the video card to watch DVD'S, > aero though no problems before i updated the video card, i do have though > 1.25 GB of ram. so i think your right. > > "Mike" wrote: > > > Hi Stuart, > > Please don't blame me if this is NOT true... but as you DO have 512meg it > > seems quite likely that this IS the case! As I said, I have researched it > > quite a bit! I only have 512meg RAM too, and I'm looking to buy an NVidia > > card to get aero/glass. The 1gig RAM has tended to put me off... I have 4 > > DDR slots and they are full! Hence I need to replace NOT add! > > Good luck and let us all know if this does cure the problem. > > Regards, > > Mike > > > > > > > > "Stuart" wrote: > > > > > I only have 512 Mb of RAM at the moment, I'll upgrade and let you all know > > > of the outcome, thanks for your advice:-) > > > Stuart > > > "Mike" <Mike@discussions.microsoft.com> wrote in message > > > news:6D792268-F97E-4F43-9DB0-4F627D5E3D2D@microsoft.com... > > > > From extensive reading about this problem when upgrading from RC1 to RC2, > > > > it > > > > seems you need at least 1gig of RAM to enable this feature in RC2. Does > > > > that > > > > tie in with any of your circumstances? > > > > Regards, > > > > Mike L > > > > > > > > > > > > "John Doe" wrote: > > > > > > > >> I had this same problem when in RC1 when Windows Update installed a newer > > > >> driver. I don't know if this solved my problem or if it fixed itself, but > > > >> what I did was rerun the performance test to update the performance > > > >> ranking. > > > >> After doing that I was able to run Aero again. > > > >> > > > >> "Stuart" <stuart.cross@blueyonder.co.uk> wrote in message > > > >> news:C7CE6B6B-7F89-4A49-AC67-F77BEE856ABC@microsoft.com... > > > >> >I have the same problem but I am using the GeForce 6200 card. > > > >> > Again with RC1 I have full aero, but not with RC2 > > > >> > I have trawled around this news group and the nvidia web site and the > > > >> > only > > > >> > suggestion I have found is to either update the bios on my Shuttle MK32 > > > >> > motherboard or to update my motherboard to a newer one. > > > >> > If anyone from nvidia or microsoft can offer an explanation, I'd be > > > >> > grateful. > > > >> > "arthur" <arthur@discussions.microsoft.com> wrote in message > > > >> > news:300EA67D-0BFF-46C8-A51C-C417DBB5547C@microsoft.com... > > > >> >>I used the FX 5200 with Vista RC1, and was able to use Aero with no > > > >> >>problems, > > > >> >> but after installing RC2, I cannot use Aero. The only choices I have > > > >> >> are > > > >> >> basic, standard and classic. I've updated the graphics driver from > > > >> >> nvidia > > > >> >> to > > > >> >> 9.6.8.5 (the newest for vista) and it's still the same. Any idea how > > > >> >> to > > > >> >> enable Aero again? > > > >> > > > > >> > > > > > > |
| | #9 (permalink) |
| | Re: nvidia GeForce FX 5200 problem with Aero Hi All, I took Mike's advice and increased my RAM from 512 to 1 gig....... YES, I now have aero enabled. Thanks Mike, you seem to cracked this problem for me. I am surprised that vista RC2 needs this amont of RAM to run aero as RC1 doesn't Stuart "Mike" <Mike@discussions.microsoft.com> wrote in message news:AA666489-BC34-4C7F-9021-1DE5B8090FC4@microsoft.com... > Hi Billmc, > > I am still looking for definitive answers to this, but there really > doesn't > seem to be any! I have read, here, that others have aero / glass enabled > with on-board graphics with 64meg, others with dedicated graphics cards > with > just 256meg! That just doesn't make sense! It seems, in RC2 at least, > that > the O/S does a hardware check and, if below spec, disables aero/glass. > There > is a registry hack that, apparently, gets round this... I tried it and > can't > get it to work! Does ANYBODY have the full answer to this? The last > thing I > want to do is spend loads of cash on a new card and find I still have this > problem! > Regards to all, > Mike L > > > "Billmc" wrote: > >> i have the same video card, i.e. nvidea gforce fx5200. the only one >> problem i >> had with rc1 (so far) was i needed to update the video card to watch >> DVD'S, >> aero though no problems before i updated the video card, i do have though >> 1.25 GB of ram. so i think your right. >> >> "Mike" wrote: >> >> > Hi Stuart, >> > Please don't blame me if this is NOT true... but as you DO have 512meg >> > it >> > seems quite likely that this IS the case! As I said, I have researched >> > it >> > quite a bit! I only have 512meg RAM too, and I'm looking to buy an >> > NVidia >> > card to get aero/glass. The 1gig RAM has tended to put me off... I >> > have 4 >> > DDR slots and they are full! Hence I need to replace NOT add! >> > Good luck and let us all know if this does cure the problem. >> > Regards, >> > Mike >> > >> > >> > >> > "Stuart" wrote: >> > >> > > I only have 512 Mb of RAM at the moment, I'll upgrade and let you all >> > > know >> > > of the outcome, thanks for your advice:-) >> > > Stuart >> > > "Mike" <Mike@discussions.microsoft.com> wrote in message >> > > news:6D792268-F97E-4F43-9DB0-4F627D5E3D2D@microsoft.com... >> > > > From extensive reading about this problem when upgrading from RC1 >> > > > to RC2, >> > > > it >> > > > seems you need at least 1gig of RAM to enable this feature in RC2. >> > > > Does >> > > > that >> > > > tie in with any of your circumstances? >> > > > Regards, >> > > > Mike L >> > > > >> > > > >> > > > "John Doe" wrote: >> > > > >> > > >> I had this same problem when in RC1 when Windows Update installed >> > > >> a newer >> > > >> driver. I don't know if this solved my problem or if it fixed >> > > >> itself, but >> > > >> what I did was rerun the performance test to update the >> > > >> performance >> > > >> ranking. >> > > >> After doing that I was able to run Aero again. >> > > >> >> > > >> "Stuart" <stuart.cross@blueyonder.co.uk> wrote in message >> > > >> news:C7CE6B6B-7F89-4A49-AC67-F77BEE856ABC@microsoft.com... >> > > >> >I have the same problem but I am using the GeForce 6200 card. >> > > >> > Again with RC1 I have full aero, but not with RC2 >> > > >> > I have trawled around this news group and the nvidia web site >> > > >> > and the >> > > >> > only >> > > >> > suggestion I have found is to either update the bios on my >> > > >> > Shuttle MK32 >> > > >> > motherboard or to update my motherboard to a newer one. >> > > >> > If anyone from nvidia or microsoft can offer an explanation, I'd >> > > >> > be >> > > >> > grateful. >> > > >> > "arthur" <arthur@discussions.microsoft.com> wrote in message >> > > >> > news:300EA67D-0BFF-46C8-A51C-C417DBB5547C@microsoft.com... >> > > >> >>I used the FX 5200 with Vista RC1, and was able to use Aero with >> > > >> >>no >> > > >> >>problems, >> > > >> >> but after installing RC2, I cannot use Aero. The only choices I >> > > >> >> have >> > > >> >> are >> > > >> >> basic, standard and classic. I've updated the graphics driver >> > > >> >> from >> > > >> >> nvidia >> > > >> >> to >> > > >> >> 9.6.8.5 (the newest for vista) and it's still the same. Any >> > > >> >> idea how >> > > >> >> to >> > > >> >> enable Aero again? >> > > >> > >> > > >> >> > > >> > > |
| | #10 (permalink) |
| | Re: nvidia GeForce FX 5200 problem with Aero Yes, this is strange... if RC1 can run Aero with 512 MB of RAM just fine (which is what I have), I don't see why RC2 should need 1GB... I'm not sure if I want to upgrade just to run Aero. "Stuart" wrote: > Hi All, > I took Mike's advice and increased my RAM from 512 to 1 gig....... > YES, I now have aero enabled. > Thanks Mike, you seem to cracked this problem for me. > I am surprised that vista RC2 needs this amont of RAM to run aero as RC1 > doesn't > Stuart > > "Mike" <Mike@discussions.microsoft.com> wrote in message > news:AA666489-BC34-4C7F-9021-1DE5B8090FC4@microsoft.com... > > Hi Billmc, > > > > I am still looking for definitive answers to this, but there really > > doesn't > > seem to be any! I have read, here, that others have aero / glass enabled > > with on-board graphics with 64meg, others with dedicated graphics cards > > with > > just 256meg! That just doesn't make sense! It seems, in RC2 at least, > > that > > the O/S does a hardware check and, if below spec, disables aero/glass. > > There > > is a registry hack that, apparently, gets round this... I tried it and > > can't > > get it to work! Does ANYBODY have the full answer to this? The last > > thing I > > want to do is spend loads of cash on a new card and find I still have this > > problem! > > Regards to all, > > Mike L > > > > > > "Billmc" wrote: > > > >> i have the same video card, i.e. nvidea gforce fx5200. the only one > >> problem i > >> had with rc1 (so far) was i needed to update the video card to watch > >> DVD'S, > >> aero though no problems before i updated the video card, i do have though > >> 1.25 GB of ram. so i think your right. > >> > >> "Mike" wrote: > >> > >> > Hi Stuart, > >> > Please don't blame me if this is NOT true... but as you DO have 512meg > >> > it > >> > seems quite likely that this IS the case! As I said, I have researched > >> > it > >> > quite a bit! I only have 512meg RAM too, and I'm looking to buy an > >> > NVidia > >> > card to get aero/glass. The 1gig RAM has tended to put me off... I > >> > have 4 > >> > DDR slots and they are full! Hence I need to replace NOT add! > >> > Good luck and let us all know if this does cure the problem. > >> > Regards, > >> > Mike > >> > > >> > > >> > > >> > "Stuart" wrote: > >> > > >> > > I only have 512 Mb of RAM at the moment, I'll upgrade and let you all > >> > > know > >> > > of the outcome, thanks for your advice:-) > >> > > Stuart > >> > > "Mike" <Mike@discussions.microsoft.com> wrote in message > >> > > news:6D792268-F97E-4F43-9DB0-4F627D5E3D2D@microsoft.com... > >> > > > From extensive reading about this problem when upgrading from RC1 > >> > > > to RC2, > >> > > > it > >> > > > seems you need at least 1gig of RAM to enable this feature in RC2. > >> > > > Does > >> > > > that > >> > > > tie in with any of your circumstances? > >> > > > Regards, > >> > > > Mike L > >> > > > > >> > > > > >> > > > "John Doe" wrote: > >> > > > > >> > > >> I had this same problem when in RC1 when Windows Update installed > >> > > >> a newer > >> > > >> driver. I don't know if this solved my problem or if it fixed > >> > > >> itself, but > >> > > >> what I did was rerun the performance test to update the > >> > > >> performance > >> > > >> ranking. > >> > > >> After doing that I was able to run Aero again. > >> > > >> > >> > > >> "Stuart" <stuart.cross@blueyonder.co.uk> wrote in message > >> > > >> news:C7CE6B6B-7F89-4A49-AC67-F77BEE856ABC@microsoft.com... > >> > > >> >I have the same problem but I am using the GeForce 6200 card. > >> > > >> > Again with RC1 I have full aero, but not with RC2 > >> > > >> > I have trawled around this news group and the nvidia web site > >> > > >> > and the > >> > > >> > only > >> > > >> > suggestion I have found is to either update the bios on my > >> > > >> > Shuttle MK32 > >> > > >> > motherboard or to update my motherboard to a newer one. > >> > > >> > If anyone from nvidia or microsoft can offer an explanation, I'd > >> > > >> > be > >> > > >> > grateful. > >> > > >> > "arthur" <arthur@discussions.microsoft.com> wrote in message > >> > > >> > news:300EA67D-0BFF-46C8-A51C-C417DBB5547C@microsoft.com... > >> > > >> >>I used the FX 5200 with Vista RC1, and was able to use Aero with > >> > > >> >>no > >> > > >> >>problems, > >> > > >> >> but after installing RC2, I cannot use Aero. The only choices I > >> > > >> >> have > >> > > >> >> are > >> > > >> >> basic, standard and classic. I've updated the graphics driver > >> > > >> >> from > >> > > >> >> nvidia > >> > > >> >> to > >> > > >> >> 9.6.8.5 (the newest for vista) and it's still the same. Any > >> > > >> >> idea how > >> > > >> >> to > >> > > >> >> enable Aero again? > >> > > >> > > >> > > >> > >> > > > >> > > > |
| nvidia GeForce FX 5200 card driver incompatible with GeForce 7600GS ?? - 4 monitors | Vista installation & setup | |||
| NVIDIA GeForce FX 5200 not compatible with VGA?? | Vista hardware & devices | |||
| nVidia GeForce FX 5200 | Vista hardware & devices | |||
| Nvidia Geforce 5200 | Vista hardware & devices | |||
